Author Topic: Topre sliders, MX caps  (Read 122393 times)
Re: Topre sliders, MX caps
« Reply #150 on: Mon, 31 March 2014, 23:28:38 »
Has anyone tried acetone vapor smoothing of the prints yet?  I wonder if that might help with some of the issues.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #151 on: Tue, 01 April 2014, 02:39:08 »
I did the feet a bit wider than necessary so they should work on all materials. It they hit the side of the housing you can simply sand them a little. It is important the they fit very well otherwise the switch wobbles. Anyway as soon as I get all your reports I'll try to make a new batch (hopefully cheaper)
Offline kelske
  • The North Borders
« Reply #152 on: Tue, 01 April 2014, 03:51:49 »
wwwwwwwwwwoooooooooooOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!!!!!!
Fits perfectly!! Frosted ultra-detail. Only thing is that it's based off the standard stem, rather than Type-S (with slightly deeper barrel) - but of course that's no biggie!
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #153 on: Tue, 01 April 2014, 03:57:32 »
 :thumb:
you can file the bottom of the slider a little to make it shorter. et-voila, silent slider :)
« Last Edit: Fri, 04 April 2014, 02:45:07 by Matt3o »
Offline SSIPAK
  • ★ Bootlegcaps ★
« Reply #154 on: Thu, 03 April 2014, 20:48:37 »
Any updates on cheaper options that you were talking about? Btw great work Matt3o! I really want your PBT granite keycaps for my topre :(
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #155 on: Fri, 04 April 2014, 02:46:24 »
I'll try to work on the new grouped 3D model these days. I talked with SP about feasibility and I'm waiting for a quote.
Offline Rewind
  • Street Fighter
  • Drive slow, homie
« Reply #156 on: Fri, 04 April 2014, 16:34:38 »
Just received my MX compatible Topre slider!
I'm really impressed with the handling time :D I placed my order on the 31st of March, I received the key today on the 4th of April, IN EUROPE.  :eek: [I just check their website, it turns out they have an office here in the netherlands!]
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #157 on: Fri, 04 April 2014, 16:47:19 »
let us know how it works out
Offline Rewind
  • Street Fighter
  • Drive slow, homie
« Reply #158 on: Fri, 04 April 2014, 17:06:33 »
Will do!
I'll most likely take apart the keyboard tomorrow. I'm just scared of breaking the tabs on the front of the case :( Any tips to prevent this from happening? :D
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #159 on: Fri, 04 April 2014, 17:09:09 »
credit card. I use some old plastic gift cards. They are perfect to open keyboards :) (but I never opened an HHKB)
Offline Smasher816
  • HHKB Master
« Reply #160 on: Fri, 04 April 2014, 17:13:39 »
The HHKB is easy to open. Just unscrew the 3 (obviously placed) screws at the back. Then it simply separates. In order to access the switch internals you will have to unscrew some more stuff to get behind board.
Just be aware that the controller has a ribbon cable that will need to be disconnected.
Offline Rewind
  • Street Fighter
  • Drive slow, homie
« Reply #161 on: Fri, 04 April 2014, 17:18:58 »
Alright cheers guys!
Will post results tomorrow :)
Offline Glissant
« Reply #162 on: Fri, 04 April 2014, 17:28:30 »
To add to what Smasher816 said; if you're worried about the clips just remember to separate the two parts by opening the case like a book. Don't try to pull it apart.
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #163 on: Fri, 04 April 2014, 17:44:58 »
Yeah, exactly. I was really worried about it breaking the first time I opened it, but it just opened right up like a book and there was never any chance of the tabs breaking. I don't know what people have been doing that's been breaking tabs :eek:
Offline Glissant
« Reply #164 on: Fri, 04 April 2014, 21:12:16 »
riotonthebay, stuff can happen I guess :) . Some people might just be opening it like a book, but using force or something *shrug*.
I sanded one white slider, and installed the violet one too for testing purposes. Seems to be working well enough for being 3D printed :) .
59933-0
Be careful when switching caps everyone. I tried a SP doubleshot and pulled it off like I always do:
59973-1
« Last Edit: Fri, 04 April 2014, 22:08:13 by Glissant »
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #165 on: Sat, 05 April 2014, 02:10:05 »
is that the lowest quality material that broke the stem?
does anyone took the medium quality material?
Offline Glissant
« Reply #166 on: Sat, 05 April 2014, 07:42:12 »
Yes, Matt3o. That was the White Detail one. The strong & flexible seems fine and hasn't broken in my little stress test (pulled and replaced the cap ten times).
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #167 on: Sat, 05 April 2014, 08:07:45 »
thanks. I guess I should remove the low quality material, or maybe you could lube the stem.
Offline Rewind
  • Street Fighter
  • Drive slow, homie
« Reply #168 on: Sat, 05 April 2014, 08:32:49 »
Alright, time for some fun!
First off, some side by side pics:
Opening the case without breaking the tabs really was as easy as opening a book. Thanks for the tips!
Removing screws of the PCB was also easy. I chose to keep the controller connected. The only annoying one was the screw below the controller connector cables.
Popping out the slider was a bit tricky at first. I thought I was supposed to pressure on the top of the slider. After a while I figured out just to press down on the bottom of the slider and it literally popped out and flew 2 meters away :D
Result:
Now I'm waiting for my MX VERY VERY skyblue keythulu! :)
Thanks again for the design Matt3o! I'm really impressed. The key press is not as smooth as the original slider at the moment so I will choose to not do my whole keyboard. However, it is great to show off novelties imo  :thumb:
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #169 on: Sat, 05 April 2014, 08:51:33 »
thanks for the report.
what do you mean that is not as smooth as the original? Have you tried to sand the side of the feet a little?
Offline Rewind
  • Street Fighter
  • Drive slow, homie
« Reply #170 on: Sat, 05 April 2014, 09:31:22 »
Yeah I did sand the sides of the feet so it would go in properly, but for some reason the keypress feels a bit less tactile and a bit more mushy. Now that I think of it, maybe I didn't line up the dome correctly during assembly?
I'll probably hack it open soon again as I ordered some more sliders ^^
Offline Rewind
  • Street Fighter
  • Drive slow, homie
« Reply #171 on: Sat, 05 April 2014, 12:38:27 »
Right, so I took it apart again as I was too curious.
It turned out that indeed the dome was not lined up correctly with the key. It must have slipped during assembly. I applied a minuscule amount of weak glue with a q-tip to the dome and now it is in place perfectly.
Now I'm even more excited about this slider haha :D
EDIT: Ordered some more :)
« Last Edit: Sat, 05 April 2014, 12:45:42 by Rewind »
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #172 on: Sat, 05 April 2014, 12:45:34 »
great to hear! :)
I think the correct technique is to simply put the domes inside the housings and then cover with the PCB
Offline avtar
« Reply #173 on: Sat, 05 April 2014, 13:15:27 »
n00b question.. which keycap sets are you using that match the HHKB profile for its Fn and arrow keys? Or I guess all the keys.
Offline Rewind
  • Street Fighter
  • Drive slow, homie
« Reply #174 on: Sat, 05 April 2014, 14:01:48 »
The reddit key above is a cherry profile R4. It is a tiny bit lower than the rest, but you can barely notice it. OEM R4 doesn't really work as it is much higher.
Correct me if I'm wrong but I don't think any standard profile keys will look good on the FN spot.
Pictures
« Last Edit: Sat, 05 April 2014, 14:10:38 by Rewind »
Offline SSIPAK
  • ★ Bootlegcaps ★
« Reply #175 on: Sat, 05 April 2014, 19:28:38 »
ooo thanks Matt3o, so excited for this
« Reply #176 on: Sun, 06 April 2014, 02:31:02 »
The only reason I got these, for my v1s. Glissant beat me to it ;) stoked to add my pink and purple mx sliders!
Offline Belfong
« Reply #177 on: Sun, 06 April 2014, 08:01:48 »
I'm a keyboard noob so if there a video on how to take apart the HHKB especially avoiding breaking the front tab and installing the stem? I mean, there's description a few posts up but nothing beats a video.
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #178 on: Sun, 06 April 2014, 08:10:34 »
Pink AND Purple?
Offline Glissant
« Reply #179 on: Sun, 06 April 2014, 09:06:38 »
Can't wait to see your hhkb get some v1 love, dustin! These are indeed exciting times for the master switch type.
Offline Rewind
  • Street Fighter
  • Drive slow, homie
« Reply #180 on: Sun, 06 April 2014, 10:03:20 »
Unfortunately I did not make a video and could also not find one. However, it is much easier than expected. Remove 3 screws on the back and you can open the board like a book. After that, just remove the ~15 screws on the PCB and you can replace the sliders.
Offline RESPRiT
  • HHKB = ❤
« Reply #181 on: Sun, 06 April 2014, 21:12:40 »
It's basically just removing screws. It's really, really easy, the only thing I would add is remember to remove the keycaps ahead of time if you're taking out the sliders, and be careful with the domes on the PCB if you're not confident with putting them back in place if they come off.
« Reply #182 on: Sun, 06 April 2014, 21:20:09 »
Pink AND Purple?
I take it you haven't looked at the shapeway link? They are smoother then the expensive one too.
Offline SSIPAK
  • ★ Bootlegcaps ★
« Reply #183 on: Fri, 11 April 2014, 02:00:44 »
any updates with SP Matt3o?
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #184 on: Fri, 11 April 2014, 02:09:37 »
not yet, I'll try to nag them Monday.
Offline SSIPAK
  • ★ Bootlegcaps ★
« Reply #185 on: Fri, 11 April 2014, 02:25:09 »
Thank you. You are the best :thumb:
PS I really want your granite set for my Topre T_T
Offline SSIPAK
  • ★ Bootlegcaps ★
« Reply #186 on: Mon, 14 April 2014, 17:44:37 »
any good news?  :D
Offline Latin00032
« Reply #187 on: Mon, 14 April 2014, 19:09:47 »
Ok. Newb question.
Will MX compatible caps work with a hhkb with these stems? What I mean is, will the bigger keys (spacebar, shift, enter, etc) line up correctly where the support stems are?
Offline SSIPAK
  • ★ Bootlegcaps ★
« Reply #188 on: Thu, 17 April 2014, 10:24:53 »
No words from SP yet?
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #189 on: Thu, 17 April 2014, 10:32:39 »
Ok. Newb question.
stabilized keys are not yet supported... if that is what you are asking
not yet, but I have a backup solution. stay tuned.
Offline SSIPAK
  • ★ Bootlegcaps ★
« Reply #190 on: Thu, 17 April 2014, 19:10:30 »
Ok. Newb question.
hopefully soon, thanks matt3o!
« Reply #191 on: Fri, 18 April 2014, 00:36:52 »
Stoked for the mx stabs!!
Offline Pacifist
  • on hiatus
« Reply #192 on: Fri, 18 April 2014, 00:40:42 »
see if imsto knows asian people who can do injection molding for u
Offline Rewind
  • Street Fighter
  • Drive slow, homie
« Reply #193 on: Fri, 18 April 2014, 06:01:14 »
So has anyone tried out white strong and flexible?
If these are strong enough, a full hhkb would be about 150 USD. (WORTH)
If nobody knows, mine are coming in before the 22nd and I'll keep you updated! :)
Offline SSIPAK
  • ★ Bootlegcaps ★
« Reply #194 on: Sat, 19 April 2014, 02:05:12 »
I dont think that's worth, If I had that much to spend just for these sliders I would just wait until novatouch and take sliders from that. At least you get anther board out of it. Anyway let us know how that white strong and flxeible is when you get it.
Offline Rewind
  • Street Fighter
  • Drive slow, homie
« Reply #195 on: Tue, 22 April 2014, 21:33:01 »
Right so today I received at least one of each material.
The ultra frosted detail feels by far stronger and more polished than the others. It actually feels like plastic.
The red, purple and pink all feel really brittle and dry. The also have the lined textured as you might expect from a 3D printed design.
The white strong and flexible feels like a mix of the above.
I'll install them soon.
Offline reefchief
« Reply #196 on: Tue, 22 April 2014, 22:14:43 »
Does the ultra frosted look like something that would make a cool clear keycap material? Thanks for experementing for us! I might pick a few up for some keys I never use if they work decently.
QFR TKL Blue / Topre 55g realforce TKL
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #197 on: Wed, 23 April 2014, 01:08:05 »
you might need to lube a little the lower quality stems. thanks for the report and keep us posted
Offline Belfong
« Reply #198 on: Wed, 23 April 2014, 04:25:30 »
Please make a video. I am curious how this is done!
Offline neunelfer
  • HHKB Pro
« Reply #199 on: Thu, 24 April 2014, 12:53:46 »
This is awesome. Could someone post a picture of an MX Clack to compare profiles?
