Author Topic: Left Control Key Questions on Realforce 87U (55g)  (Read 6354 times)
Offline Shyfe
« on: Tue, 18 February 2014, 21:03:20 »
I just pulled off the left control key on my keyboard and noticed there was a layer of white grease around the plunger's ring. Is this normal and what is it for?
Also, after doing this, I noticed the left control key is pretty wobbly compared to the rest of the keys. Is this normal as well?
Thanks.
HHKB (55g) | IBM SSK | Realforce 87U (55g) | Unicomp EnduraPro | KBT Oni
Re: Left Control Key Questions on Realforce 87U (55g)
« Reply #1 on: Tue, 18 February 2014, 21:04:56 »
Left control uses a lubed slider, and there's another reason too, but I forget.
It should also be purple.
Offline Shyfe
« Reply #2 on: Tue, 18 February 2014, 21:18:11 »
what should be purple? the grease or the slider? the slider is black and the lube is white.
Offline ComradeSniper
  • HHKB Pro
« Reply #3 on: Tue, 18 February 2014, 21:21:36 »
I noticed this as well and thought that the wobble was a manufacturing defect, but since I have my left control set to caps lock it rarely gets used so I didn't mind it much. Maybe it's a normal thing? What's the reason for the wobble?
Offline eth0s
  • Peace & Love
« Reply #4 on: Tue, 18 February 2014, 21:25:57 »
The purple sliders are the silent versions.  He should have the plain black ones.  Also the grease was added by Brian @ EK, AFAIK.  It's there for some beneficial reason, but like TacStach, I can't remember either, lol.  But it's definitely a good thing.  Grease is better than no grease.  Why are you taking the keycaps off anyway?  Put those caps back on, and get back to work, or gaming or watching Laura Branigan on Youtube:
Offline Shyfe
« Reply #5 on: Tue, 18 February 2014, 21:30:51 »
I was just curious what the LED setup looked like. Haha.
Offline Polymer
« Reply #6 on: Tue, 18 February 2014, 21:35:56 »
The switches w/ the LED have some funny mod on the bottom (I guess to fit the LED).  It is what makes the switch not as stable (it wobbles).  There are some pictures out there that show the plunger..it is a modified one....
« Reply #7 on: Tue, 18 February 2014, 21:38:40 »
It's weird because that is the only key that has anything lube/grease on it.
Offline eth0s
  • Peace & Love
« Reply #8 on: Tue, 18 February 2014, 21:49:32 »
Yeah, it is weird.  but I guess EK Brian just likes to lube the Ctrl's.  I think there was some complaint about that key squeaking or something.  I dunno.  Well, tbh, idc.  Both my RF's from EK Brian came with lubed L Ctrl's.  I just didn't make a big deal about it.
@OP, you were just looking for the LED?  lol.  There is not one there.  That's the goofiest part of the L Ctrl.  It has that window, but not an LED.  But it gets lubed.  So many mysteries in this universe, I have so many questions for G*d when I die.
  • HHKB Pro
« Reply #9 on: Tue, 18 February 2014, 21:51:08 »
Huh? Left control has an LED...
Offline eth0s
  • Peace & Love
« Reply #10 on: Tue, 18 February 2014, 21:54:38 »
It does?  Not on either of mine.  I have the 87UW all-45g, and the 87UB silent variable.  Neither has an LED in that L. Ctrl.  F*CK BURGERS!!! IF EK BRIAN RIPPED ME OFF, I'LL ** EDIT - I'll be disappointed in my fellow man.
« Last Edit: Tue, 18 February 2014, 21:56:24 by eth0s »
  • HHKB Pro
« Reply #11 on: Tue, 18 February 2014, 22:00:29 »
Lazy potato pic incoming
Maybe it's just the 55g version?
Offline Shyfe
« Reply #12 on: Tue, 18 February 2014, 22:03:17 »
It does. Just go on the back and flip the first DIP switch on, unplug/replug keyboard. The LED only works when it's serving as caps lock.
Offline tbc
« Reply #13 on: Wed, 19 February 2014, 01:32:34 »
that left ctrl is really annoying to look at.  it's clearly not as perfectly oriented as the rest of the keys.  feels fine though, so i'm cool with it.
Offline spiceBar
    • ChessTiger.com
« Reply #14 on: Wed, 19 February 2014, 07:39:12 »
Actually that's the switch housing that is different. It has to accommodate for the LED. When I modded my Realforces I couldn't simply put a landing pad around the plunger because of this difference. The landing pad would end up jammed in the housing when the key went back in the "top" position. I had to cut 2 small pieces in a landing pad and glue them to the switch housing.
So this Ctrl key is definitely different and it definitely feels different. It's normal. There is nothing to fix. There is nothing wrong with the OP's keyboard.
« Reply #15 on: Wed, 19 February 2014, 08:31:35 »
I've learned from this thread that RFs are strange
who needs and LED on LCTRL?
« Reply #16 on: Wed, 19 February 2014, 08:33:45 »
It's there for when you swap it to be caps lock.
« Reply #17 on: Wed, 19 February 2014, 08:37:11 »
pff
I have it mapped to shift
but that makes sense
Offline spiceBar
    • ChessTiger.com
« Reply #18 on: Wed, 19 February 2014, 13:26:04 »
pff
Shift???
