Author Topic: Possible good source of Alps caps/switches  (Read 2558 times)
Offline Techno Trousers
  • ʘ_ಠ
« on: Wed, 19 February 2014, 12:37:18 »
I just saw these pop up on eBay. Hard to tell from the potato pics, but the caps look Dolch-like, and I'm assuming the switches are Alps. I ordered one, so I'll report back when I receive it.
http://www.ebay.com/itm/310877742396
Re: Possible good source of Alps caps/switches
« Reply #1 on: Wed, 19 February 2014, 12:39:01 »
Love those colors!
  • Rich Homie Huang.
« Reply #2 on: Wed, 19 February 2014, 12:39:05 »
I have very similar caps. The caps I have are Alps, and yes they look like Dolch. It looks like they're the same though since the function and top rows are the same weird size.
« Last Edit: Wed, 19 February 2014, 12:41:05 by CPTBadAss »
Please check out TactileZine.com!
« Reply #3 on: Wed, 19 February 2014, 12:40:18 »
I have these caps. They are Alps, and yes they look like Dolch.
Do you know if the board is useful for anything? Or just harvesting caps?
  • Rich Homie Huang.
« Reply #4 on: Wed, 19 February 2014, 12:43:08 »
I bought just the keycaps. I don't really know anything about the actual keyboard. I'm sure one could get it working but I'm not even sure if the keyboard actually has Alps switches. I shouldve said previously they're Alps mount. I've edited my post accordingly.
« Reply #5 on: Wed, 19 February 2014, 12:56:31 »
If nothing else the alphas would be hot with black everything else (either on a matias board or from whenever he releases caps), assuming the profiles were close.
Offline riotonthebay
  • Cherry Peasant
  • Cherry Pheasant
« Reply #6 on: Wed, 19 February 2014, 12:59:27 »
Just bought these. Going to have to figure out the bottom row... Needs another 1x and a reasonably sized spacebar, but that's a problem for another day :D
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #7 on: Wed, 19 February 2014, 13:00:13 »
Looks like it's also some lapy keyboard, so likely there is not a controller... but get a handle on matrix tracing and hook up a teensy and you can probably make it work as is. Almost tempted to get one myself... axe the top 2 rows, make a case and you have a nearly perfect Alps 60%. Seeing a small vintage Alps without some ****tarded enter key is rare indeed.
« Last Edit: Wed, 19 February 2014, 13:02:53 by IvanIvanovich »
Offline Pacifist
  • on hiatus
« Reply #8 on: Wed, 19 February 2014, 13:02:34 »
Are they double shot?
  • Cherry Peasant
  • Cherry Pheasant
« Reply #9 on: Wed, 19 February 2014, 13:04:49 »
That's exactly what I'm thinking. I saw those ANSI mods and knew I needed it.
« Reply #10 on: Wed, 19 February 2014, 13:07:54 »
Just noticed in the details the sellers says
I do have more of these
  • ʘ_ಠ
« Reply #11 on: Wed, 19 February 2014, 15:52:20 »
He originally posted a sale for a single one with that message, then took that down and posted the four. I don't know if he has more than this set of four though. I hope there are enough for everyone that wants one here.
« Reply #12 on: Wed, 19 February 2014, 15:54:09 »
Also for anyone wanting these I would make an offer and see how low he will go.
Offline jacobolus
« Reply #13 on: Wed, 19 February 2014, 16:55:24 »
I tried making an offer a week ago and he wouldn’t go lower then.
I got a Mitsubishi MP286L laptop that has this same keyboard. The keyboard uses those PCB-mounted Alps switches with the oval sliders http://deskthority.net/wiki/Alps_low-profile_oval_slider, plus some skinnier ones of the same general type (which I don’t think are on the Deskthority wiki) for the F keys &c.
The keycaps are doubleshot, of the standard Alps-produced type, except for the skinny top keys, which are printed. These are the same type of keycap that were also used on Toshiba laptops of that era. For an example of someone putting them to better use, see https://geekhack.org/index.php?topic=54857.0 (though Paranoid’s Toshiba laptop had full-size F keys and a numpad as well).
As mentioned above, there’s no controller, but for anyone who likes this type of switch, there is a diode with each switch, so if you add a Teensy and a case, it should be NKRO. Personally I’m not a huge fan of the switches. They’re linear, but not as nice as the plate-mounted green/yellow Alps switches.
« Last Edit: Wed, 19 February 2014, 17:06:26 by jacobolus »
Offline nuclearsandwich
« Reply #14 on: Wed, 19 February 2014, 21:50:32 »
Turned down my offer for $13 and now they're all gone. ;_;
« Reply #15 on: Thu, 20 February 2014, 06:41:40 »
After he turned down a $16 offer from me, I just bought one.
That "offer" thing is hard to guess at. Sometimes sellers will take 50% and sometimes turn down 90%.
Ebay loves confusion and I want transparency.
“Wise statesmen as they were, they knew the tendency of prosperity to breed tyrants, and so they established these great self-evident truths, that when in the distant future some man, some faction, some interest, should set up the doctrine that none but rich men, or none but white men, were entitled to life, liberty and pursuit of happiness, their posterity might look up again to the Declaration of Independence and take courage to renew the battle which their fathers began — so that truth, and justice, and mercy, and all the humane and Christian virtues might not be extinguished from the land; so that no man would hereafter dare to limit and circumscribe the great principles on which the temple of liberty was being built.”
- Abraham Lincoln, July 4, 1858
Offline 127001
« Reply #16 on: Thu, 20 February 2014, 10:25:51 »
I usually offer 30% and base my next offer on their counter offer. If it's auto rejected I walk away.
« Reply #17 on: Thu, 20 February 2014, 10:29:01 »
I offered $12 he countered with $14 but I decided I didn't really need it :D
« Reply #18 on: Thu, 20 February 2014, 11:15:47 »
That's just unfair. You must be cooler than me.
« Reply #19 on: Thu, 20 February 2014, 11:18:33 »
Or perhaps he got lots of interest and realized he had a desirable item :D
« Reply #20 on: Thu, 20 February 2014, 16:19:36 »
Off subject but not off topic:
I just posted a Genovation numpad with 18 nice Alps-compatible caps in white on dark gray.
https://geekhack.org/index.php?topic=55033.0
« Last Edit: Thu, 20 February 2014, 16:21:44 by fohat.digs »
  • ʘ_ಠ
« Reply #21 on: Thu, 20 February 2014, 18:36:11 »
Looks nice, fohat. Are those full size or low profile caps? I have an Alps numpad with white on black caps.
« Reply #22 on: Thu, 20 February 2014, 18:46:47 »
Full size. And they are clearly gray not black, which is a plus if you are looking to dress up but not pimp.
I bought the numpad for the caps, but I need some cash and these are selling on ebay in the high-$20 range.
« Reply #23 on: Thu, 20 February 2014, 21:49:56 »
Further discussion of fohat.digs' tenkey for sale should be made in his classified advertisement.
« Reply #24 on: Fri, 21 February 2014, 07:06:38 »
These are really nice doubleshot keys!
The stabilizer wires are thick, but there are long "U" clips on the undersides of the long keys so I am going to see if they can be made to work with thin standard wires.
I have never had these old Alps switches with metal tops. They feel nice but I simply don't like linear switches. If they are pin-compatible with conventional Alps, I may put some in an experimental Alps-hybrid board I may make someday, with different switches in different areas. These might be good for WASD or arrows.
« Last Edit: Sat, 22 February 2014, 09:26:24 by fohat.digs »
« Reply #25 on: Sat, 22 February 2014, 14:12:03 »
I dont think so: they require 4 pcb holes per switch, though with some modding it could work.
Offline jacobolus
« Reply #26 on: Sat, 22 February 2014, 15:17:31 »
They’re not as tall as standard Alps switches, they’re PCB mounted, and they are definitely not pin compatible. If you want to use them along with other Alps switches in the same keyboard, you’re going to need to do some customizing work.
The caps should work with standard Alps stabilizers (you might have to swap out the little clips on the bottom, but I don’t think so).
« Reply #27 on: Sat, 22 February 2014, 16:49:34 »
That would be just peachy. I have spares of those clips. I keep little jars of clips and stabilizers, but they are all orphans and so different!
  • Cherry Peasant
  • Cherry Pheasant
« Reply #28 on: Sun, 23 February 2014, 09:57:37 »
I needed another one of these because I needed extras of certain keys, so I asked the seller if he had more. He said that there were 3 unlisted, and I bought 1, so there are 2 left. I offered and he accepted $15 plus shipping. ($24 CONUS via USPS priority.)
  • ʘ_ಠ
« Reply #29 on: Sun, 23 February 2014, 22:17:02 »
I just ordered a second as well.
  • ʘ_ಠ
« Reply #30 on: Wed, 26 February 2014, 22:23:04 »
The last of this cache is up on eBay now.
http://pages.ebay.com/link/?nav=item.view&id=201043707837
Offline Pacifist
  • on hiatus
« Reply #31 on: Wed, 26 February 2014, 22:24:40 »
Agh should I?
Are they DS?
  • ʘ_ಠ
« Reply #32 on: Wed, 26 February 2014, 22:27:40 »
Yes, double shots. See jacobolus' post earlier in the thread for more info.
Offline False_Dmitry_II
« Reply #33 on: Sun, 02 March 2014, 03:46:13 »
What the heck, right after I saw that you said you got one after the auction was over I sent him a message asking if he still had one and he never answered. So I figured it had been gone already.
  • ʘ_ಠ
« Reply #34 on: Sun, 02 March 2014, 14:40:30 »
D'oh!
« Reply #35 on: Sun, 02 March 2014, 14:48:42 »
Well, if you're willing to pay a little more, there's still this auction that finishes in a couple of hours.
Offline jacobolus
« Reply #36 on: Sun, 02 March 2014, 17:16:59 »
Note, that's a completely different set though.
There’s also http://www.ebay.com/itm/Toshiba-T5200/141203228889 for anyone looking for a numpad as well, but note that neither of the Toshiba sets has standard ANSI-width modifiers.
  • Cherry Peasant
  • Cherry Pheasant
« Reply #37 on: Sun, 02 March 2014, 17:20:11 »
Shoot, I was hoping no one would notice this :). Anyways, I've been eyeing this for the numpad and spacebar. If anyone wins it and doesn't need a 7x spacebar, I'd love to buy it ;).
« Reply #38 on: Sun, 02 March 2014, 18:04:10 »
Haha, sorry man.  I've had it on my wishlist for ages.  I was going to bid on it, but then found my other set for cheaper.
