Author Topic: [SOLVED]Need help resolving BSOD.  (Read 12065 times)
Offline smknjoe
Re: Need help resolving BSOD.
« Reply #50 on: Fri, 21 February 2014, 08:49:25 »
Just make sure all of your BIOS settings are set to factory default before you continue testing.
SSKs for everyone!
Offline epzy
  • HHKB Fiend
  • ded
« Reply #51 on: Fri, 21 February 2014, 09:59:11 »
Okay.  :thumb:
Offline epzy
  • HHKB Fiend
  • ded
« Reply #52 on: Fri, 21 February 2014, 13:00:29 »
https://onedrive.live.com/#cid=DAF523E66417CC7B&id=DAF523E66417CC7B%21105
Here's my dump files if anyone wanna take a look.
Offline smknjoe
« Reply #53 on: Fri, 21 February 2014, 13:15:29 »
DUDE...what happens with Memtest?
SSKs for everyone!
Offline epzy
  • HHKB Fiend
  • ded
« Reply #54 on: Fri, 21 February 2014, 13:17:00 »
Can't do it before my friend brings a burn CD etc. ;p He's been busy @ work.
« Last Edit: Fri, 21 February 2014, 13:18:31 by epzy »
Offline smknjoe
« Reply #55 on: Fri, 21 February 2014, 13:19:26 »
You don't have a USB flash drive?
You can't run hardware diagnostics through Windows or any OS reliably. Especially, when we are talking about RAM, CPU, or MOBO.
SSKs for everyone!
Offline epzy
  • HHKB Fiend
  • ded
« Reply #56 on: Fri, 21 February 2014, 13:24:39 »
Nope, I don't. The dump files, do they tell you anything?
Offline epzy
  • HHKB Fiend
  • ded
« Reply #57 on: Sun, 23 February 2014, 18:23:23 »
Swapped RAM sticks, everything works fine now. Ran memtest86, but I think I ****ed it up big time. The test took 6 hours and did a total of 10x4 tests. >.> Anyhow, it's all good now. Thanks for all your input. Locking thread. :)
