Author Topic: Things you discover when you clean under your keycaps  (Read 2363 times)
Offline paicrai
  • mindblank
« on: Thu, 20 February 2014, 12:27:44 »
THE FEMINIST ILLUMINATI
Re: Things you discover when you clean under your keycaps
« Reply #1 on: Thu, 20 February 2014, 12:30:01 »
I bought a MY-7000 for the keycaps. When I pulled the caps underneath was hardened icing, bits of hard candy, and dust. Apparently the previous owner had a sweet tooth.
  • Live long and prosper
« Reply #2 on: Thu, 20 February 2014, 12:33:13 »
Typically when I clean out an old, dirty keyboard, I find things like bits of decomposing food, lots of lint/hair/dust, and one or more rusty paperclips.
I also discover many switches hiding under my keys. Sometimes they are blue, other times they're brown or black, and SOMETIMES there's just a big ol' spring there.  Not quite sure what their function is, but I'll get back to you when I find out more about it... #sarcasm
tp thread is tp thread
Offline paicrai
  • mindblank
« Reply #3 on: Thu, 20 February 2014, 12:34:56 »
I remember when I used the family PC when I didn't have my own, which included keyboards that weren't mine, I did not give a ****. There'd mostly be a bunch of dried yoghurt, milk and noodle-water, salt and crumbs. And that changed when Vun bought me my first keyboard. That **** remained PRISTINE.
« Reply #4 on: Thu, 20 February 2014, 12:47:34 »
Didn't someone recently get a cherry board that was used at a hair salon?
Offline paicrai
  • mindblank
« Reply #5 on: Thu, 20 February 2014, 12:57:46 »
Probably looked like my board before I cleaned it...
HAIR and DUST STUFF
Offline HPE1000
  • Keycap Paparazzo
« Reply #6 on: Thu, 20 February 2014, 13:05:56 »
My kishsaver had a spiders nest under/inside a shift key(spiders all gone luckily).
Offline Techno Trousers
  • ʘ_ಠ
« Reply #7 on: Thu, 20 February 2014, 13:14:40 »
I bought a Dell AT101W from a cat owner. Didn't know the seller owned a cat until I started pulling caps. YIKES!
Online Findecanor
« Reply #8 on: Thu, 20 February 2014, 13:46:35 »
I have a few keyboards that were recovered from garbage dumps. A few of them have had quite a bit of soil in them, while others have been pristine. Never paid more than a Euro (equivalent) for any.
Offline Pacifist
  • on hiatus
« Reply #9 on: Thu, 20 February 2014, 13:50:32 »
My M-122 was disguisting
When it came out, it smelled like ****. Caps were greasy af.
I took of the case and was greeted by dust and a dead bug under the winkeyless part. Panicked and took a vacuum to it.
I tried to vacuum up the hair and dust but it didn't work :'(
Ended up hand cleaning the whole thing with wet tissues. Each tissue was good for one pass then it was all gunked up.
I hate used boards, especially those used for 20+ years :'(
Offline paicrai
  • mindblank
« Reply #10 on: Thu, 20 February 2014, 13:54:19 »
That is some scary stuff.
« Reply #11 on: Thu, 20 February 2014, 15:20:52 »
Did you at least wear gloves?
Offline Pacifist
  • on hiatus
« Reply #12 on: Thu, 20 February 2014, 15:21:22 »
Nope ;D
But I was really careful in making sure nothing dirty touched my fingers
« Reply #13 on: Thu, 20 February 2014, 15:22:08 »
Nope ;D
Offline berserkfan
« Reply #14 on: Sat, 22 February 2014, 09:39:57 »
Fohat should have lots of stories. I'm just waiting for him to show up and talk about finding dead baby rats in his Model F or something.
