Author Topic: Raccoon Cables Type USB Connectors?  (Read 2254 times)
Offline Angelwork
    • Angelwork Tech
« on: Thu, 20 February 2014, 23:47:32 »
I was wondering if anyone knew where to get the connector tips for USB Type A and USB Mini Type B that Raccoon Cables uses for his cables?  I'm talking about the kind that come split and can be folded over on each other so as to achieve the "sleeving under the connector" look.  I've sleeved my PSU and have a heat gun, soldering gun, MDPC sleeving, etc.  I just haven't the slightest idea where to get these connectors.
Razer BlackWidow Ultimate | HHKB Pro 2
Offline tjcaustin
  • King Klaxon
    • Buy stuff
Re: Raccoon Cables Type USB Connectors?
« Reply #1 on: Thu, 20 February 2014, 23:55:02 »
If you're looking for low bulk, IE - 1 to 5, mouser/digikey can get you set up.
Offline PointyFox
« Reply #2 on: Thu, 20 February 2014, 23:56:28 »
They have tons of them on eBay for like $2 for 10 sets.
Type "Set Male USB Mini-B Type Connector Mount Socket" into search and you'll find a ton of them.
« Last Edit: Thu, 20 February 2014, 23:59:34 by PointyFox »
Offline Angelwork
    • Angelwork Tech
