Author Topic: Keyboard with red switches and minimal actuation & travel distance?  (Read 1537 times)
Offline dmbr
I'm looking for a keyboard for gaming that has red switches and minimal actuation and travel distance. What option is best in these two particular regards?
« Last Edit: Fri, 21 February 2014, 07:14:20 by dmbr »
Offline Oobly
Re: Keyboard with red switches and minimal actuation & travel distance?
« Reply #1 on: Fri, 21 February 2014, 07:38:48 »
Actuation and travel distance are a characteristic of the switch, so they'll all be the same.
You can reduce them yourself by modding the switches, though.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #2 on: Fri, 21 February 2014, 07:50:45 »
Buy any MX red keyboard you please and get the thickest o-rings you can find along with it.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Offline ideus
  • Björkö.
« Reply #4 on: Fri, 21 February 2014, 08:53:23 »
Go for the orings/dampeners that best suit you. The caps shape may add to the feeling of shortness, but not the actual geometry though. DSA and cherry can "reduce" the travel distance of the overall assembly.
Offline aref
« Reply #5 on: Fri, 21 February 2014, 11:12:57 »
I tried some black o-rings on an MX Red KB I had and the o-rings made a considerable reduction in key travel.
I picked up a pace of 125 o-rings from Amazon for $8.25: http://www.amazon.com/gp/product/B0051XWXCE/ref=oh_details_o07_s00_i00?ie=UTF8&psc=1
