Author Topic: Backlighting  (Read 3344 times)
Offline CX23882
Backlighting
« on: Sat, 14 March 2009, 16:21:12 »
I'm not usually one to buy into keyboard backlighting but I can see the times when backlit keys can be quite useful even if you're a touch-typer.
The thing that concerns me (other than the fact that most backlit keyboards except the Déck(*) are rubber dome) is the way in which the keys are manufactured.  I know that in cars, the buttons are often clear plastic and then have black "paint".  I had an Audi on which one of the electric window switches wore clear over time.
Do backlit keyboards use a similar method?  I can't imagine light-pipes being feasible due to the shape and fine-ness of the shape, which I suppose leaves either clear plastic with black paint, or that with some kind of clear overlay to protect the paint.
* what is the accent for on the é in Déck?
Offline tamasrepus
    • http://blog.samat.org/
Backlighting
« Reply #1 on: Sat, 14 March 2009, 18:03:54 »
AFAIK the Logitech Illuminated keyboard has "laser-etched" writing on the keys, it's not paint.
The keyboard also uses scissor switches, though not classical mechanical switches, feel a lot better to type on than rubber membrane boards.
Noppoo Choc Mini w/ Cherry MX Brown
Happy Hacking Keyboard Professional 2, Black w/labels
Topre Realforce 87U, 55g
ABS M1
Happy Hacking Keyboard Lite 2
Logitech diNovo Edge
Sun Type 6 USB
Offline cchan
Backlighting
« Reply #2 on: Sat, 14 March 2009, 19:56:39 »
Quote from: CX23882;24479
F!ck knows. And I would imagine that at least some backlit keyboards have double-molded keycaps with one black and one clear layer.
HP Envy17: Core i7-2760QM, 8GB DDR3, 128GB Crucial m4 + 750GB Hitachi, Windows 7 Home Premium x64, Cherry ML4100, Logitech M500, HP zr22w
IBM Thinkpad X60: Core Duo T2400, 2GB DDR2, 128GB Samsung 830, Xubuntu 12.04 x86, Cherry ML4100, Logitech M205, HP zr22w
Raspberry Pi Model B: BCM2835, 0.25GB DDR2, 8GB Samsung SD card, Raspbian Wheezy, human interaction devices as above
Offline itlnstln
Backlighting
« Reply #3 on: Sun, 15 March 2009, 08:27:13 »
It looks pretty pointless to me.  It's a one syllable word; the accent falls on the e by default.
Offline D-EJ915
Backlighting
« Reply #4 on: Sun, 15 March 2009, 20:14:00 »
it's there to make it look fancy
Offline Xuan
Backlighting
« Reply #5 on: Sat, 21 March 2009, 15:17:15 »
9. Key Caps: Characters can't chip off the key caps or wear down to oblivion. Period. Deck™ uses a sublimated negative printing process which drives the ink into the plastic keycaps at 525°f. This means permanent printing from the inside out, not on.
http://www.deckkeyboards.com/techspecs.php
Offline lam47
Backlighting
« Reply #6 on: Sat, 21 March 2009, 16:49:03 »
Why only blacks in the deck? Would they not sell more if they offered the whole cherry range?
Keyboards. Happy Hacking pro 2 x2. One white one black. IBM model M US layout. SGI silicone Graphics with rubber dampened ALPS. IBM model F. ALPS apple board, I forget what it is. And some more I forget what I have.
Typewriters. Olivetti Valentine. Imperial Good Companion Model T. Olympia SM3
Offline eugenius
Backlighting
« Reply #7 on: Sun, 22 March 2009, 09:32:04 »
they don't care and are generally useless :)
I asked them a while ago if they can sell me a mini keyboard with browns and black matte case not that fugly clear case theu have ...  no response.
Cherry ErgoPlus MX5000 + MX5700 / IBM Model M
