Author Topic: Controller recommendations needed  (Read 2864 times)
Offline GiraffePencils
« on: Tue, 25 February 2014, 17:27:18 »
Hi all,
I'm looking to back a keyboard with a built in touch screen in place of the number pad, much like the 'Razer Deathstalker'.
I have cherry blues reclaimed from an old keyboard and I have some touchscreens that came with single board PCs.
I would like a controller to handle the keys and the screen and touch functionality and hopefully make media controller/macros to be used through the touchscreen.
I was looking at the teensy/getting an ARM Cortex evaluation board? but was hoping someone with more experience could help before I start down the wrong route.
For information the touchscreen uses an LVDS connector for the screen and a USB header for touch feedback.
Thanks
Offline Oobly
Re: Controller recommendations needed
« Reply #1 on: Wed, 26 February 2014, 01:42:44 »
You have 2 options. The simple one and the complicated one.
Simple option: Buy an LVDS controller board (you can get them for DVI, VGA and HDMI) and a Teensy. Use the Teensy for the keyboard only. Run the LVDS board from whichever type of video port you have chosen. Use the USB header from the touchscreen to a USB port on your PC. Write software on your PC to do all the touchscreen stuff.
Complicated (and expensive) option: Buy a Devkit8000 or similar board with LVDS out. Do a lot of hard work figuring out how to connect everything and writing the software for it.
The Teensy is a much simpler controller than an ARM dev board. Most of the ARM solutions are essentially small PC's in their own right. Most also require a converter to be able to output to LVDS anyway, such as the Raspberry Pi (which I can recommend for almost any project), just like a normal PC. One possible advantage of going the complicated route is you can run Android or Ubuntu on your keyboard and play games on it without even being connected to a PC ;)
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #2 on: Wed, 26 February 2014, 04:21:52 »
Thanks for the reply,
I considered the option of passing through the screen and controlling everything through PC, but I hoped to create a more elegant solution.
I looked at the raspberry Pi or an Arduino, but they seemed bloated with features I didn't want.
Your suggestion of 'Devkit8000' looks promising, software is no issue for me, any excuse of a new project  :p
It would be fun to have the keyboard run like a mini PC, that might be worth the effort itself hehehe.
I might just take the plunge on something.... I've helped a few friends with PI projects so could be a good route.
So the Teensy is only good as far as Keyboard (and LEDS?) would it be best to keep that a separate part?
Offline jacobolus
« Reply #3 on: Wed, 26 February 2014, 23:24:07 »
What about just passing everything through some kind of super cheap Chinese Android phone?
If you buy one as a separate component, what kind of touchscreens are cheaply/easily available nowadays?
« Last Edit: Wed, 26 February 2014, 23:25:45 by jacobolus »
« Reply #4 on: Thu, 27 February 2014, 03:49:14 »
I have the touchscreen already, I have a stack of 15-20 of them.
Edit: That being said, I could use a phone, I have a couple of old one's lying around
« Last Edit: Thu, 27 February 2014, 08:48:31 by GiraffePencils »
