Author Topic: How much does it cost for a custom pcb?  (Read 2541 times)
Offline clickclack123
« on: Wed, 26 February 2014, 21:24:56 »
Just thought that before I go through the process of learning how to design a pcb in KiCad, I'd ask here:
I'm just looking for a ballpark figure for how much it would be to get a TKL/compact sized pcb made, either single or double sided??
I haven't been able to find a price from anywhere yet as I don't have the design finished (or even started!) to send off for a quote.
If it's too much, I will just direct-wire my design for now as I'll probably want a plate later anyway.
Also, where would people recommend I get it made? Cheap is good, I'm not in too much of a hurry, pretty used to waiting for 3 weeks for stuff from China.
Offline OldDataHands
Re: How much does it cost for a custom pcb?
« Reply #1 on: Wed, 26 February 2014, 21:33:35 »
OSHPark
pcbwing
seeedstudio
(many others too, I'm sure)
You might budget $5 per square inch from OSHPark as a good ballpark for a one-off.
« Reply #2 on: Wed, 26 February 2014, 22:04:10 »
Thanks, I just found the DIY Resources Thread which has a fair bit of info.
Just emailed sitopway (recommended in the DIY thread) and tingriver on ebay to ask them for prices as well.
