Author Topic: Name for Blues with Clear Spring  (Read 9731 times)
Offline ideus
  • Björkö.
Re: Name for Blues with Clear Spring
« Reply #50 on: Wed, 05 March 2014, 08:39:49 »
How about we come up with a standard naming scheme and post it in the wiki?
Example:
Ghost [nickname for Clear Springs] Blacks
So in this case the first part of the naming scheme will refer to the nickname for the spring being used and second word will always refer to the stem color.
More examples:
Ghost [Clear springs] Blues, Smurf [Blue Springs] Blacks, Lava [Red Springs] Blacks....you get the point.
Than all we will need to do is decide what to nickname the springs.
Aw, a codification system. I like it.
Offline daerid
    • Rossipedia
« Reply #51 on: Wed, 05 March 2014, 11:13:02 »
+1
Although, Smurf and Lava (and whatever Browns are) might be confusing, since they all use the same spring.
Offline do_Og@n
« Reply #52 on: Wed, 05 March 2014, 11:17:08 »
+1
We could call it the Harlot spring?
Offline QuadGMoto
« Reply #53 on: Wed, 05 March 2014, 11:28:35 »
We already have Ergo Clears, which are a clear using the spring from blues/browns/reds. So why not use that for other switches that receive that spring?
« Reply #54 on: Wed, 05 March 2014, 11:54:55 »
Well, it wouldn't really be making anything Ergo outside of a White or tactile Grey since it would just be making a linear or clicky switch  that already exists.
Offline daerid
    • Rossipedia
« Reply #55 on: Fri, 14 March 2014, 11:53:21 »
Sorry to necro bump this, but I just swapped out the blue springs for clears on one hand of my new ErgoDox, and I gotta say:
Hmmmm
Nowhere near as good as I thought it was going to be. I think the stem mechanism of the blue switch doesn't really work out well with the clear spring. It feels like it requires much more force to actuate than a stock clear.
I think I'm going to stick with the stock blues on this one.
Offline Grendel
« Reply #56 on: Fri, 14 March 2014, 12:11:59 »
Heh. Personally I like "Sky Blues", lighter than greens but some bite. For giggles, try a blue switch w/ a grey tactile spring. I call them "Rainy Day" ;)
- I'm game !
Offline QuadGMoto
« Reply #57 on: Fri, 14 March 2014, 12:16:42 »
I've been doing the somewhat crude nickel test on various MXs. Since I've been experimenting with putting blue springs in clears, I happened to have some disassembled blues and clear springs lying around. So I threw one together and tested it.
For reference, here is what I had previously found:
11 nickels - stock blue
12 nickels - ergo clear
14 nickels - stock clear
Given that, I expected the clear blue to be somewhere in the range of 13 to 15. (Greens are 15). The actual result is: 17! That's higher than the white at 16.
Your fingers seem to be telling the truth. That's the highest activation force I've seen yet.  :eek:
Offline daerid
    • Rossipedia
« Reply #58 on: Fri, 14 March 2014, 19:45:09 »
Whew! Glad to know that I wasn't trippin (and nice to see some good old fashioned keyboard science up in here). And yeah, 17 is nuts. Assuming 1 nickel = 5g, that's an extra 15g of actuation force over a stock clear, and 30g over a stock blue.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #59 on: Fri, 14 March 2014, 20:14:35 »
Ghost is cool. I like that.
Offline Lastpilot
  • Power stance
« Reply #60 on: Fri, 14 March 2014, 20:24:12 »
Bears. Clues.
Aqua blues? [since aqua -> water -> clear]
« Reply #61 on: Fri, 14 March 2014, 21:56:31 »
hard on blues
Offline tbc
« Reply #62 on: Sun, 16 March 2014, 04:53:24 »
someone have a technical explanation of how this is possible?  something is getting jammed?
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #63 on: Sun, 16 March 2014, 06:53:52 »
Aquamarine?
A Ghost From The Past
Offline daerid
    • Rossipedia
« Reply #64 on: Sun, 16 March 2014, 11:25:27 »
Doubtful. While I didn't measure mine, I definitely felt that the Blues with Clear springs were stiffer than practically any Cherry MX switch I'd tried. Probably has something to do with the force curve of the clear spring at the actuation point combined with the shape of the blue stem (i.e: the "sharpness" of the tactile point on blues).
Offline tbc
« Reply #65 on: Mon, 17 March 2014, 03:06:31 »
^that's kinda disappointing to hear :(
because the clear spring seems to make the blue switch even louder, which is what I want. :/
