Author Topic: What kind of Wrist Rest is the best?  (Read 3858 times)
Offline Pacifist
  • on hiatus
« on: Sun, 02 March 2014, 19:35:26 »
What kind of rest is the best? Hard, soft, or inbetween? And for each kind, what brand do you prefer?
For soft, is grifiti good? http://www.amazon.com/Grifiti-Standard-Keyboards-Mechanical-Materials/dp/B004D8PYE2/
For in between, is the ducky one at massdrop good?
For hard, is wood the only choice or are there others?
« Last Edit: Sun, 02 March 2014, 20:15:39 by Pacifist »
Offline SonOfSonOfSpock
Re: What kind of Wrist Rest is the best?
« Reply #1 on: Mon, 03 March 2014, 00:40:42 »
If it's too soft your hands just sink. The Grifiti is firm, but still has a little cushion. I find the depth of the Grifiti a little too deep. With the Grifiti you can cut it pretty easily and not have a problem if you end up in the same boat as me.
I wouldn't want a solid piece of wood/plastic, but I'd prefer that over something on the opposite end of the spectrum.
Offline Pacifist
  • on hiatus
« Reply #2 on: Mon, 03 March 2014, 00:47:43 »
Good to know. Grifiti is pretty much dirt cheap at $14 shipped while ducky is $33 shipped, and it seems like the grifiti is good enough quality to suit my needs
Offline Pacifist
  • on hiatus
« Reply #3 on: Mon, 03 March 2014, 18:15:26 »
I'm going to buy the grifiti today and see how it is when it arrives
« Reply #4 on: Mon, 03 March 2014, 20:07:38 »
Hope you like it!
Offline Pacifist
  • on hiatus
« Reply #5 on: Wed, 05 March 2014, 17:27:42 »
Got it today
it's too tall, going to have to cut it down later
also its bent a little on the inside so theres a "bubble" but just like my mousepads they should be gone after a bit
« Reply #6 on: Wed, 05 March 2014, 21:16:52 »
Mine was bent too. It was a general flex upwards so that only the edges touched the table when I wasn't resting my hands on it. I thought it was a good height, just too deep. Do you use a normal height keyboard or is it a shorty?
Offline Dyslexic
  • All we love we leave behind
« Reply #7 on: Fri, 07 March 2014, 10:52:44 »
I can honestly tell you to skip the Ducky if you're going to try something else -- the bottom has absolutely no ability to prevent the rest from sliding around.
| HHKB Type-S | FC660C Silenced | ReΛlforce 23UB
Offline Latin00032
« Reply #8 on: Fri, 07 March 2014, 14:01:11 »
Best wrist rest. Best wrist rest. Best wrist rest. Best wrist rest. Best wrist rest.
Offline histevenhere
  • Student
« Reply #9 on: Thu, 13 March 2014, 18:41:17 »
Oh darnit, I just got the ducky one from massdrop :(.
HHKB PRO 2, DAS ULTIMATE, SIIG MINITOUCH, KBT PURE, IBM MODEL M, MICROSOFT COMFORT CURVE 2000, CHERRY G84-4100, TG3-TP, QUICKFIRE RAPID, REALFORCE 87u
