Author Topic: What Pointing Device Are You Using Now?  (Read 334549 times)
Offline davkol
  •  Post Editing Timeout
Re: What Pointing Device Are You Using Now?
« Reply #50 on: Fri, 28 March 2014, 05:19:28 »
potato
what are the things on the right (blue) and the left? a notepad and a volume-controller?
ontopic: currently using a G400. i also own a zowie FK. both mice are among the best for fps games (which i play frequently) :j
Apple trackpad and Griffin Powermate, the only thing missing there is a Apple Aluminium keybohd
Offline oscillik
    • music podcasts
« Reply #51 on: Fri, 28 March 2014, 05:27:12 »
ThinkPad TrackPoint right now.
when back home, Zowie FK 2014
Keymacs A620N-Rev.A with Alps SKCM Salmon switches
Offline vun
  • Just one more thing
« Reply #52 on: Fri, 28 March 2014, 06:59:03 »
Using a Xornet atm, been playing D3 lately so I figured I'd switch to a mouse that's cheap to replace if I end up clicking it to death.
Offline Doyniish
  • Good you
    • Power Hour Playlists
« Reply #53 on: Sat, 29 March 2014, 12:56:23 »
@Bucake: Yep this is correct. Griffin Powermate is a controller and can be programmed for almost any application to do things. I use it for Final Cut Pro and as a volume control.
As for the Apple Keyboard remark, i'm not sure what you mean by this. If it was supposed to be a chirp it really was pretty pathetic.
Offline eddie
« Reply #54 on: Sat, 29 March 2014, 15:58:26 »
zowie ec2 evo. I only wish it could go to a lower dpi
Offline daerid
    • Rossipedia
« Reply #55 on: Tue, 01 April 2014, 01:25:54 »
Lower than 450?
Offline vun
« Reply #56 on: Tue, 01 April 2014, 04:10:25 »
Currently using my DA2013 because I picked up a Manticor on sale(boy was that a good deal) and wanted to see how the DA2013 looked on it. Real smooth combo.
Offline Zombly
  • Zombie Enthusiast
« Reply #57 on: Tue, 01 April 2014, 10:04:21 »
I use a Razer mamba, got it for $30 clearance needed a wireless mouse at time, can also wire it, honestly better than expected.
In the process of my custom Zombie board
[WTB MX Zombro's]
Offline PolaBurrr
« Reply #58 on: Tue, 01 April 2014, 10:34:04 »
Rotating between xai, kana v2, and ec1 evo
« Reply #59 on: Tue, 01 April 2014, 10:42:04 »
CM Storm Spawn at work and a Kensington Slimblade at home. I think I'm starting to really like trackballs.
Offline PolaBurrr
« Reply #60 on: Tue, 01 April 2014, 12:18:49 »
One benefit I see with trackballs is that it resists your urge to play games when you should be doing work  :p
Offline davkol
« Reply #61 on: Sun, 13 April 2014, 18:49:53 »
MS Basic Mouse Optical O_o
...but it was only for Cookie Clicker. Now I'm giving Logitech G400 another chance. Or just suffer with a trackpoint.
Offline davkol
« Reply #62 on: Mon, 28 April 2014, 12:40:33 »
Kensington SlimBlade Trackball and Roccat Lua @ SteelSeries 4HD. I'm pleasantly surprised that solid mousepads have allowed me to drop cpi to ~1k.
« Reply #63 on: Mon, 28 April 2014, 12:58:41 »
CoolerMaster Spawn at work and an Anker Vertical Mouse at home.
Offline mrklaw
« Reply #64 on: Mon, 28 April 2014, 13:02:10 »
At work I have a "Logitech cordless laser mouse" that I bought from a surplus store like geeks.com. It doesn't have any markings on it that shows the model or anything besides "Logitech" and "Performance Laser 848nm".
I've got a LTrac on the way from Massdrop to replace it.
Ducky Zero with DSA Dolch and SA Vim key
Offline CeeSA
« Reply #65 on: Fri, 16 May 2014, 06:34:33 »
At work I use a trackpoint only. It is build in, in my right side of my Tipro board.
64901-0
Offline munch
« Reply #66 on: Sun, 25 May 2014, 05:30:46 »
I use a Logitech G100s atm, but having a hard time with the slippery sides when it's a bit hot.
is there any product especially made to help with this? like grip tape that isn't too thick or whatever?
any ideas?
thanks!
Offline vun
« Reply #67 on: Sun, 25 May 2014, 05:36:20 »
any ideas?
thanks!
I know Artisan makes grip tape, not sure about thickness, but their pads get a lot of praise so I'd assume the tape is at least decent.
You can also buy pre-cut pads of grip tape, can't remember the manufacturer of those, but there's a good chance any site that sells mouse feet will also sell something like that.
Offline kakakowie
  • Make Love not War
« Reply #68 on: Sun, 25 May 2014, 08:23:19 »
I really need a trackball with more buttons though. As far as I know theres the slimblade but the buttons are way too big.
Offline davkol
« Reply #69 on: Sun, 25 May 2014, 09:18:52 »
They're best pressed near the outer edge in the middle, it's not an issue at all. Only the switches could be better.
Offline Freebird
    • SSRCG
« Reply #70 on: Sun, 25 May 2014, 10:02:39 »
Razer Naga 2012
I thought I was silly buying a mouse with 12 side buttons, but I actually use them for a lot of stuff.
« Reply #71 on: Thu, 05 June 2014, 12:54:02 »
ROCCAT Kone Pure Color, Orange. This thing fits amazing in my palm and is perfect. I love it!  :cool: 10/10 Best mouse Ive ever used and also held (fitment wise).
« Last Edit: Thu, 05 June 2014, 20:04:32 by dustinhxc »
Offline UnlikeAny
« Reply #72 on: Thu, 05 June 2014, 13:08:46 »
Best of the best: Logitech G400
Offline Pacifist
  • on hiatus
« Reply #73 on: Thu, 05 June 2014, 13:28:30 »
elaborate on that board :eek:
Offline Mr. D
« Reply #74 on: Thu, 05 June 2014, 19:41:10 »
Just picked up a Logitech Marble Mouse recently to see if it would help with some wrist pain and I really like it so far.  Currently switching between it and a Zowie EC2.
QFR | Model M | AT101W
Offline Pacifist
  • on hiatus
« Reply #75 on: Thu, 05 June 2014, 19:47:26 »
getting a Logitech Trackman Wheel on saturday
Offline kakakowie
  • Make Love not War
« Reply #76 on: Thu, 05 June 2014, 21:07:59 »
Love the colour on that!
Offline davkol
« Reply #77 on: Tue, 10 June 2014, 11:30:43 »
Zowie FK... but I don't like it. The buttons, including the wheel, have too short travel. Otherwise, it's a good mouse and the shape is quite well thought out... I just don't see any reason to pick it over a modern roccat. Perhaps if I wanted to switch to palm grip, or if the side buttons were usable on both sides at the same time...
Offline epzy
  • HHKB Fiend
  • ded
« Reply #78 on: Thu, 12 June 2014, 22:38:25 »
Zowie EC2 eVo. I think it's a great mouse, only possible cons in my opinion are the scroll wheel is a tad bit heavy and the glossy finish might not be for everyone.
Offline Deviruki
  • Devil's Advocate
« Reply #79 on: Sun, 15 June 2014, 14:27:42 »
Razer Deathadder 3.5g, Crossfire Red version. Pretty much just to match my board.
| Ducky Shine 3 MX Reds |
Offline sacratoy
    • Twitch
« Reply #80 on: Sun, 15 June 2014, 14:46:32 »
I'm using a Logitech G502 at the moment. Need to move up since my G9x was looking a little worse for wear after 4 years of heavy use.
Glad I moved up to the G502, very similar shape.
Poker II
Offline wetto
  • Brazil's Keyboard Enthusiasts Representative
    • Portuguese Mechanical Keyboard Guide
« Reply #81 on: Mon, 16 June 2014, 23:35:56 »
I'm using the CM Storm Devastator and I'll make a review of it soon...
Sensor: Pixart PAN3309DH
Calling it "bad" is underrating it. It goes far beyond that... It's the worst gaming mouse I've ever seen, it makes any Philips Twin Eye mouse (even the CM Storm Sentinel) look good next to it  :-X
« Last Edit: Mon, 16 June 2014, 23:40:16 by wetto »
My collection:
Mice: Logitech G602, CM Storm Recon, CM Storm Spawn, Razer Naga, Ozone Radon Opto, Corsair M60, Tesoro Gandiva, CM Storm Alcor, Mionix Naos 8200.
Keyboards: Matias Secure Pro, Matias Mini Quiet Pro, custom modded Metadot Das Keyboard Model S Professional Silent (MX Brown, Costar), CM Storm Trigger (MX Brown), Noppoo Choc Mini (MX Red), Tesoro Lobera G5NFL Supreme, CM Storm Devastator.
Soon: CM Storm Quick Fire TK (MX Brown), CM Storm Trigger Z.
Boards I don't own anymore: CM Storm Quick Fire Rapid (MX Black), Logitech K800 (Membrane), Logitech G710+ (MX Brown), Thermaltake Meka G-Unit (MX Black), Corsair K70 (MX Red).
Mice I don't own anymore: Logitech G9x MW3, Corsair M65, Logitech G700, Roccat Kone Pure.
Offline xxghostxx
« Reply #82 on: Sat, 28 June 2014, 12:24:17 »
steel series diablo 3 mouse
LOVE THIS THING!!!! :p
Ducky shine 2(9008)-orange back lit ,MX Cherry brown
Offline bursar
« Reply #83 on: Sat, 28 June 2014, 15:53:52 »
Roccat Kone XTD here.
I had the Kone for 4 years before deciding to upgrade to the XTD. I love the variable lighting - was awesome when I changed from the red LEDs on the Sidewinder X6 keyboard to the blue LEDs on the Blackbird. A couple of mouse clicks, and presto, all the colours match again :)
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #84 on: Mon, 30 June 2014, 08:51:48 »
I AM CURRENTLY USING A HEWLETT-PACKARD MOUSE AS A POINTING DEVICE.
Offline wetto
« Reply #85 on: Mon, 30 June 2014, 19:19:22 »
No love for the original Microsoft Intellimouse?
It's one of the first mouse ever to use a rubberized scroll wheel and the one of the first "Palm" grip mice.
My collection:
Offline ShawnMeg
« Reply #86 on: Tue, 01 July 2014, 10:08:07 »
Logitech M705.  Had an MX600 (which I prefer over the M705).  I also have a  M570 trackball still in its package.  This is for my main setup at home.
At work, just use a ****ty Dell mouse.  I have a Magic Trackpad that I use with an old MacBook Pro, but I'm not too fond of it.
I also use an old PS/2 Dell optical mouse with a 10 yr old laptop that I'm running Linux.
IBM Model F122 X 2 internal Soarer's || IBM Model M122 internal Soarer's || AEK II SKCM Salmon ALPS external adb_usb converter ||  AEK M0115 SKCM Orange ALPS click mod external adb_usb converter || AEK M0115 SKCM Salmon ALPS external adb_usb converter ||
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #87 on: Wed, 02 July 2014, 00:45:38 »
Yeah just as I thought mw has always been unfaithful to the original Microsoft Mouse brand, as now confirmed by him  8) .
I now have the original InteliEye Sensor LED mouse "Made in Mexico" model, LOVE it to DEATH :thumb: .
Offline twiddle
    • Portfolio
« Reply #88 on: Wed, 02 July 2014, 03:15:57 »
The one I prefer to use the most is the Steelseries Sensei (not the RAW edition, the original). It lets me have pretty insane sensitivity (about 11k CPI), with an option to have hardware in the mouse reduce that sensitivity when I am making very slow movements. Lets me fly around my dual screen setup without having to worry about precision when trying to only move in small increments.
Offline wetto
« Reply #89 on: Wed, 02 July 2014, 04:08:24 »
Do you know that that CPI/DPI is achieved through positive interpolation, which is just about the same concept as upscaling pictures/videos, which means, it's not really as accurate as a native CPI/DPI would be. Kinda like doing this:
http://img530.imageshack.us/img530/9219/mw2cb.jpg
PS: But the main difference between CPI (DPI)/Picture or Video Resolution is that higher CPI/DPI doesn't means better, so don't misunderstand the example!
When you try to force a sensor to achieve a higher CPI/DPI, you get a lot more noise, jitter and a much less precise tracking, so, using 11k CPI/DPI is just really (pardon me for the word, but it's necessary) stupid. Here's an example of a 2000 CPI/DPI (AVAGO 3050) sensor working up to 3200 CPI/DPI through interpolation:
You get lots of jitter and anything above 1600 CPI/DPI has a fair amount of mouse prediction to makes things worse.
The max CPI/DPI of the older version of the AVAGO 9500, which is Steelseries Sensei's sensor, is 5700 CPIs/DPIs. Anything above that will contain higher amounts of jitter, smoothing and maybe even input lag and is just not recommendable.
« Last Edit: Wed, 02 July 2014, 04:19:48 by wetto »
My collection:
Offline twiddle
    • Portfolio
« Reply #90 on: Wed, 02 July 2014, 04:16:46 »
Do you know that that CPI is achieved through positive interpolation, which is just about the same concept as upscaling pictures/videos, which means, it's not really as accurate as a native DPI would be.
<snip>
The max DPI of the older version of the AVAGO 9500, which is Steelseries Sensei's sensor, is 5700 DPIs. Anything above that will contain higher amounts of jitter, smoothing and maybe even input lag and is just not recommendable.
Fair call, this makes sense if it is achieving it through interpolation like you say. Perhaps the Sensei is using some of that fancy gimmicky onboard processor to compensate? I've got other mice that run at around that 5500-6500 DPI range (a Saitek and a Razer) and don't notice any jitter, or lag, whatsoever with the Sensei by comparison.
Thanks for the info though, I didn't really think to investigate the difference between CPI and DPI.
Offline JackMills
« Reply #91 on: Wed, 02 July 2014, 04:59:53 »
I am currently using a Microsoft Wireless Mobile Mouse 3500, the name is longer than the mouse itself. It is our company standard mouse for the laptop users. Although it has decent accuracy and works on lots of surfaces, it is too small. I loved the logitech mouse that came with their Wave keyboard, but I lost the receiver and they don't keep it in their spare parts anymore, so that's a loss.
Now, I was looking for a new mouse and was thinking about the Logitech Performance MX, due to it's programmable buttons and that it works good on different surfaces, but then I saw this thread. A lot mention that they are using a trackball, and now I am intrigued. I like that a trackball stays in place on the desk, it seems to be ergonomical, but how different is the experience?
How is the experience in CAD software (PTC-software mainly)?
Edit: A last question, how good is the logitech M570 for mobile use?
« Last Edit: Wed, 02 July 2014, 05:06:05 by JackMills »
Offline wetto
« Reply #92 on: Wed, 02 July 2014, 13:00:34 »
<snip>
Basically, the dictionary meaning of each one, which doesn't makes any sense at first is:
CPI = Counts per Inch
DPI = Dots per Inch (dots as in the number of pixels on your screen!)
Your mouse sensor always works with Counts Per Inch, but those get translated later into Dots per Inch so that your computer may understand them and move the cursor accordingly.
So, in a 800 CPI mouse, if you move your mouse left for a single Inch the sensor will make 800 Counts, then those will be sent to your computer which will move the cursor 800 Dots (or Pixels if you prefer) towards left on the screen.
In the end, as many say, it's almost the same thing because they both have the same value and one always gets converted into the other, but Counts are related to the sensor, while Dots are related to the screen.
Also, it has no relationship whatsoever with accuracy. A good video that explains some of this, and even more, is this one, from a Logitech's Senior Engineer:
« Last Edit: Wed, 02 July 2014, 13:19:39 by wetto »
My collection:
Offline Frenir
  • HHKB Viking
« Reply #93 on: Wed, 02 July 2014, 13:03:03 »
Right now I'm using my p.o.s Razer Naga Epic, because I'm at a LAN-party of a sort.
It's amazing how much of an improvement the 2014 version is.
I just wish I could find another MMO-gaming mouse that I like, Razer is a continues disappointment in my case.
Offline deltuhhh
« Reply #94 on: Wed, 02 July 2014, 14:16:09 »
i'm currently using the Steelseries Rival. love the thing.
Offline Protato_Tubby
  • people enthusiast
« Reply #95 on: Thu, 03 July 2014, 10:14:22 »
Welcome to GeekHack! :D
DELL AT102W Black Alps | IBM Model M 122 | Matias Tactile Pro 4
Offline paicrai
  • mindblank
« Reply #96 on: Sun, 13 July 2014, 16:51:51 »
thumb!!!
THE FEMINIST ILLUMINATI
Offline Glissant
« Reply #97 on: Sun, 13 July 2014, 18:51:35 »
I bought the G502 because I wanted a new mouse. It's a nice mouse, and it accommodates my claw grip style handling very well. I am tempted to say I finally found the mouse that can replace the G9(x) for me.
Offline BetaZerker
« Reply #98 on: Tue, 15 July 2014, 03:01:39 »
A £10 logitech laser mouse whilst I wait for my g400s to arrive.
Offline Coff_man
  • hi.
« Reply #99 on: Tue, 15 July 2014, 09:38:14 »
 Right now I am using both a Logitech g400s (for teh fps) and a Razer naga 2014 (4 de mmos).
 Also a cheap wireless mouse for when I am in the bed. O.o
-QFR w/ mx Blues
-Ducky 9008 G2 w/ mx Red (dyesub ptb/thin?)
-Choc mini w/ mx Black
