Author Topic: Why is there a lack of 75% boards?  (Read 10344 times)
Offline Fragil1ty
  • Abre los ojos.
« on: Fri, 07 March 2014, 07:27:07 »
I know this topic has probably been discussed to death, but heh, let's go over it again anyway.
I'm a massive lover of the 75% board hence my almost 2 year long use of the Noppoo choc mini, but why is there a complete lack of choices? I've either got the Noppoo choc mini to go with or the Keycool 84 and that's about it.
I don't like to use 60% boards because I need to have the F1 keys accessible (directly and not through some form of a variant, e.g. fn + 1) and I need to have my arrow keys directly accessible also.
Do people not care for the 75% boards etc? as there seems to be like I said, a complete lack of them out there.
你搞砸了
Offline longweight
  • philanthropist
Re: Why is there a lack of 75% boards?
« Reply #1 on: Fri, 07 March 2014, 07:30:10 »
For me it isn't an aesthetic form factor and boards like the HHKB have such a good Fn layer so I don't need top layer access to F etc.
Also getting caps is a nightmare!
Offline dante
« Reply #2 on: Fri, 07 March 2014, 07:40:41 »
Vortex Race 2 is coming...
« Reply #3 on: Fri, 07 March 2014, 08:54:49 »
I don't know, but I'll just leave these here:
The Epsilon Keyboard
Offline epzy
  • HHKB Fiend
  • ded
« Reply #4 on: Fri, 07 March 2014, 09:01:36 »
I should get one of those and call it "epzylon" hmm...
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #5 on: Fri, 07 March 2014, 11:37:35 »
The KC is fantastic. And isn't the Race 75% as well?
Offline Shayde
« Reply #6 on: Fri, 07 March 2014, 11:54:21 »
There's also the Matias Mini Quiet Pro.
Collector-of-switches.  Cherry: red, brown, blue, black, grey (linear), green.  Alps: simp./comp. white, comp. blue, Matias.  NMB: white, black.  Futaba: Cherry stem.  Omron: yellow.  Topre: 45g  Various: Apple II+, TRS80 Model 1, C64, Acorn Electron, ZX81 (lol!).
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #7 on: Fri, 07 March 2014, 11:59:46 »
A while back I was really looking forward to seeing samwisekoi's gh75 take off:
http://geekhack.org/index.php?topic=43450.0
I believe GON also makes a MX-Mini (75):
http://www.gonskeyboardworks.com/custom-kbds-w-assembly/24-gon-ns-mx-mini-w-tuningassembly.html
« Last Edit: Fri, 07 March 2014, 12:07:48 by digi »
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #8 on: Fri, 07 March 2014, 12:10:25 »
Pretty much this.
Personally I do actually like the uniform "slab o' keys" look, but 60% boards do look cooler and are just as functional.
Offline digi
  • elite af tbh
« Reply #9 on: Fri, 07 March 2014, 12:12:01 »
Pretty much this.
hmm, thats debateable, Function row without using a modifier key?
Offline hashbaz
  • Grand Ancient One
« Reply #10 on: Fri, 07 March 2014, 12:14:59 »
What do you use the function row for?
Offline digi
  • elite af tbh
« Reply #11 on: Fri, 07 March 2014, 12:17:33 »
macros, game keybindings, find, spell checker, help, web browser full screen etc. I just like having the single keypress opposed to using a modifier. It's preference, we still friends?  :)) :)
Offline davkol
  •  Post Editing Timeout
« Reply #12 on: Fri, 07 March 2014, 12:50:26 »
There's the TECK, but I won't ever get that one, because of the Truly Ergonomic part.
IMHO this form factor is perfect for gaming, portable and easy to learn to use.
For now, I'm stuck with Noppoo Choc Mini (sucky availability and I don't really trust the PCB either) and TypeMatrix 2030 (essentially 75% layout; too bad it has only ABS keycaps and proprietary firmware). I didn't like the Race or the 82key TG3/Deck keyboard, because of their layouts... and the rest have either weird switches, or rubber domes. I've never found KC84 more appealing than choc mini.
GH75 is dead, Epsilon has never really been meant to be an option... maybe I'll make something on my own one day.
Offline Pacifist
  • on hiatus
« Reply #13 on: Fri, 07 March 2014, 13:24:58 »
What i liked about the kc84 was it has pretty much every key on a tkl but its smaller and more compact.
but i guess some companies don't like to make 1,75 shifts
« Reply #14 on: Fri, 07 March 2014, 13:38:03 »
That's why metalliqaz made the Epsilon to fit the keycaps from an MY7000 board. :)
He probably needs to make another run of those one day...
Offline Pacifist
  • on hiatus
« Reply #15 on: Fri, 07 March 2014, 13:39:59 »
I've moved onto 60% for the next compact board. 75% is perfect if you can't remap keys. But with a programable 60%, you can get all the keys you need to use easily, 1 colum 1 row shorter
Offline remdell
« Reply #16 on: Fri, 07 March 2014, 15:07:27 »
I'm with you on this.  Simple remapping via dip switch or AutoHotKey helped me compact necessary keys into a small 60% board.  I initially avoided 60%'s for their lack of arrow keys, but because I rarely use right alt, ctrl, windows, and shift, remapping those four keys into an arrow cluster solved my 60% problem.
Rukia PC | RF87U Digilog | Norbaforce MKII Palm Desert | Zenith ZKB-2R | Datadesk MAC-101
Offline Skull_Angel
« Reply #17 on: Fri, 07 March 2014, 19:30:14 »
I could see myself using a 60% board for work, but I like having that damned F-row for gaming (mmo) keybinds.
Offline Lengradde
« Reply #18 on: Fri, 07 March 2014, 21:46:31 »
I'm in the same boat, disappointed with the lack of 75% keyboard options.  I too need the F row and arrows directly accessible due to MMO games and key binds.
The mention of 60% boards doesn't even belong in this thread.  All I want is a 75% board with no plate and no LEDs, yet there's literally nothing on the market and nothing coming down the pipe.  Sucks...
« Last Edit: Fri, 07 March 2014, 21:50:37 by Lengradde »
Offline Pacifist
  • on hiatus
« Reply #19 on: Fri, 07 March 2014, 22:07:05 »
Really the only pcb mounted commercial board is either poker x or cherry boards
The only way to get 75% pcb mounted is custom. metalliqaz has a custom 75% but I don't think he has more parts.
Offline dante
« Reply #20 on: Fri, 07 March 2014, 22:22:51 »
The first gen KBT Race was also PCB.
« Last Edit: Fri, 07 March 2014, 22:26:53 by dante »
Offline Pacifist
  • on hiatus
« Reply #21 on: Fri, 07 March 2014, 22:35:16 »
Ah yes, the race. A great keyboard but not common because they produced so few :confused:
Offline Fragil1ty
  • Abre los ojos.
« Reply #22 on: Sun, 09 March 2014, 07:09:06 »
I've looked at all the possibilities in terms of 75% boards and the kc/noppoo are the only ones that appeal to me, I don't really want to shy away from these type of boards.
Last week I gave away a Filco TKL to a friend of mine, it was brand new, gave it away because I just didn't like it, too big for me :(
你搞砸了
Offline katushkin
  • Just the guy
« Reply #23 on: Sun, 09 March 2014, 08:42:46 »
If you don't get a KC and join the club (therearedozensofus.gif) I will be very sad.
It seems like a lot of people reccomend/get reccommended keycools, but I see so few of them here and on /r/mechanicalkeyboards :(
Offline charlaph
« Reply #24 on: Sun, 09 March 2014, 09:09:07 »
I imagine the lack of choice is because it's such a niche product. If you need F keys or arrows/insert cluster then TKL is the default way to go. If you want something smaller than TKL then most people will jump directly to a 60%, it's only those people who need both a smaller form factor AND the arrows/insert that will ever buy a 75% and I don't imagine there's all that many of them (well, there are on keyboard forums, but y'know, I mean in the wider populace)
Just to add my personal input on this. I was leaning towards a KC84 as my first mechanical, but went for a TKL instead as I use the arrows and insert cluster quite a lot and am familiar with the layout - it's also not that much larger than the KC84. My reasoning for not getting the 75% was that if I was going to go to the effort and take the time to learn a non-standard layout, then I'd prefer to just get a 60% and enjoy the smaller form and greater choice of keys. I might still end up getting a KC84 as I like the look of them and they're a bargain, but I doubt it'll ever become my main board.
Offline davkol
« Reply #25 on: Sun, 09 March 2014, 09:20:59 »
Niche product? I doubt that. Most compact keyboards, especially in the laptop market, have some variation of a ~75% layout... and scissor switches at best.
Offline simon_C
« Reply #26 on: Sun, 09 March 2014, 16:58:34 »
I personally love the 75% layout if it is done properly. Love the size and layout of my noppoo.
Offline SonOfSonOfSpock
« Reply #27 on: Mon, 10 March 2014, 00:55:42 »
I just got a Matias mini quiet pro. I like how compact it is compared to a full board. I see the form factor as a good compromise between having function keys, arrow keys, and a compact width.
Offline blighty
« Reply #28 on: Tue, 11 March 2014, 02:57:44 »
Keysets for 75% are a bit of a pain to get, but worth it
57106-0
I'm sure people have seen these R4 Sph.
Cherry caps work just as well, if not better, due to their low profile:
57118-1
It took keysets from both an mx8000 and an mx/my1800 to get almost full DS coverage (the win keys and fn caps are pad printed)
« Last Edit: Tue, 11 March 2014, 11:40:23 by blighty »
LZ ergo (MX silent red) | JER - A06 (MX silent black-red springs) | Duck Lightsaver V2 (MX red) | Duck Octagon V2 (gateron clear) (lifted pads) | Duck Orion V2 (gateron red) | TKC 1800 (gateron silent reds) | Mistel MD770 (MX red with GMK silencing clips) | Realforce R2TSLA-US4-IV | Realforce R2TLSA-US4-BK | TX 75 (gateron clear) | KBDFANS 75 ("vintage" MX blues) | Kinesis Freestyle Pro (MX red) | MS Surface Ergonomic | MS Natural Ergonomic Keyboard 4000 | Filco Majestouch 2 TKL (MX black) | Phantom (Filco case) ("vintage" MX blacks | Spr1t 75% PCB x 2 (MX black and gateron clear) | Cherry G80-1865 (MX browns with black springs)
Offline tbc
« Reply #29 on: Tue, 11 March 2014, 03:04:26 »
^ DSA blanks is truly the way to go.  although I'm perfectly fine swapping a 1.25x mod for the 2x right shift.
Offline scottjad
« Reply #30 on: Tue, 11 March 2014, 22:23:42 »
I know they're not cherry/topre switches, but I just wanted to note that this keyboard on my Thinkpad X220 is IMO more similar to the 75% keyboards than anything else, in part because of the arrow key placement and its width. Also, the Apple Wireless Keyboard is essentially a 75% keyboard, though I know it lacks a few keys. In fact, the keyboards on all mac laptops are essentially 75%.
So while 75% may be niche in cherry/topre keyboards, which are themselves quite niche, it is actually well represented in laptop keyboards.
I slightly prefer my Keycool 84 over my Noppoo Choc Mini.
I suck at Starcraft 2 and use F2 to select all my army. On a HHKB, that would require two hands with the Fn placement. Perhaps someone will say I should be using control groups for my army on 1 and 2. But then again if I were good I would want to use F3-F6 to move the camera to my bases, so the problem still stands.
Of course I use F keys for a ton of other things too, like driving a debugger and switching virtual desktops and moving windows to different virtual desktops and midnight commander and tons of things in Emacs and Excel and it's just nice not having to use an extra modifier key.
One nice thing about using a 75% keyboard is that when you inevitably have to use a laptop keyboard, it's not as much of an adjustment.
Current: RF 87U 45g, Keycool 84 White w/ Browns, Noppoo Choc Mini Black w/ Browns, Thinkpad X220
Sold: RF 87U Ergo, TEX Beetle w/ Blues, Noppoo Choc Mini Black w/ Reds, Truly Ergonomic w/ Browns, Kinesis Advantage, Kinesis Freestyle, TypeMatrix, Das Keyboard w/ Blues
Offline ideus
  • Björkö.
« Reply #31 on: Tue, 11 March 2014, 23:02:22 »
My thinkpad has an oustanding keyboard for a laptop, but I'd use my mech keyboard any time. Functions keys? mm, what do you need them for, that requiere them to have dedicated keys?
Offline StylinGreymon
  • Keyboard Hipstar
« Reply #32 on: Tue, 11 March 2014, 23:07:24 »
Too cluttered looking, for me.
If today had been a hippo, then you'd really have to worry about tomorrow.
Offline scottjad
« Reply #33 on: Tue, 11 March 2014, 23:32:28 »
I pointed out that Starcraft 2 uses F1 for idle worker, F2 for all army, F3-F? for centering the camera on your bases. Taking your right hand off your mouse to press the Fn key is not acceptable for a RTS game. Now, you can say you should come up with different keybindings for these things, or that you should hook up a different keyboard everytime you want to play, but this is one good example where having dedicated F keys is very important.
Offline jacobolus
« Reply #34 on: Wed, 12 March 2014, 00:00:19 »
All sorts of existing applications take advantage of the keys that happen to be already present on the keyboard. That doesn’t mean that the number of keys or their layout is a good one, though.
It is much easier, whether for playing starcraft or for invoking actions in Photoshop or closing applications in MS Windows or whatever else, to have at least 3-4 thumb keys as modifiers and assign one of them + the home row to be F1, F2, F3, F4, instead of needing to reach up for the F keys on a “traditional” keyboard layout.
Offline scottjad
« Reply #35 on: Wed, 12 March 2014, 00:09:10 »
I'm all for having more modifiers on the thumbs and for experimenting with different layouts. I'm a huge fan of SpaceFn and similar ideas. My response was more geared toward why one might want a 75% vs the same thing w/o a F row, e.g. a 60% with a Fn key on the right hand side.
Offline RESPRiT
  • HHKB = ❤
« Reply #36 on: Wed, 12 March 2014, 03:10:16 »
I think is actually a big reason for the turn off. There's just too much going on, the aesthetic isn't quite there.
Offline tbc
« Reply #37 on: Wed, 12 March 2014, 04:09:38 »
filco minila.  master race layout - dungbeetle keycaps
Offline RESPRiT
  • HHKB = ❤
« Reply #38 on: Wed, 12 March 2014, 04:13:58 »
SP DSA base + mods and I think 2(?) extra keys should cover that issue, though.
Offline tbc
« Reply #39 on: Wed, 12 March 2014, 04:16:00 »
^ no convex 3x spacebar.  only 3x concave key (think slightly larger right shift).  also the stock fn keys are convex 1.25x. you need 2x for the left shift (i use the numpad 2x 0 key).
4 keys that won't be covered by a TKL set.
i'm talking about a blank set btw, if you want correct legends, you're in deep doo doo.
and some people are really picky against DSA.  I would argue DSA isn't that bad when you're using it on a 60% board.
« Last Edit: Wed, 12 March 2014, 04:20:26 by tbc »
Offline RESPRiT
  • HHKB = ❤
« Reply #40 on: Wed, 12 March 2014, 04:26:13 »
I remember trying to work it out a bit ago, and I'm pretty sure you get a 2x that would normally be for a backspace that you can use for the lshift. Also a TKL set should have enough 1.25x keys for the win/ctrl/alt/fn on the bottom row for a Minila, right? I think the only extras you actually need are the 3x spacebar and 1.75x lctrl. Correct me if I'm wrong on that though.
Offline tbc
« Reply #41 on: Wed, 12 March 2014, 04:31:48 »
sorry, my bad.
I'm tired and didn't notice you're talking about just DSA (i was talking about no profile in particular)
you're right about the keys though
no convex keys REALLY screws up your feeling.  there's no reason that you wouldn't be able to adapt; it'll just be really weird because you'll solely be relying on the position of your fingers rather than on the feel of the key (you'll KNOW you're above space, but the feeling will make it seem like you're above ALT)
« Last Edit: Wed, 12 March 2014, 04:34:01 by tbc »
