Author Topic: [GB] 16ga metal ergodox cases -- Shipping R2 recommencing  (Read 128261 times)
Re: [GB] 16ga metal ergodox cases -- Shipping R2 recommencing
« Reply #400 on: Wed, 06 August 2014, 21:21:00 »
Yea the only thing I'm wondering is whether or not my TRRS cable will fit without any acrylic plates. I get the impression there might not be enough clearance for the end of the cable.
One would think that replacing the cable with a lower profile one would be the solution
these two look lower-profile than the stock one.
Offline GSimon
« Reply #401 on: Wed, 06 August 2014, 21:25:00 »
It's an option, however I'd much rather use this:
Offline Loligagger
« Reply #402 on: Wed, 13 August 2014, 11:21:09 »
Got my plates in yesterday, thanks AKmalamute.
74359-074361-1
Offline witbliz
« Reply #403 on: Fri, 05 September 2014, 11:57:49 »
Hey guys , i just got my plate as well and i was wondering which screws and spacers did all of you use. I know i read them somewhere but i cant find the post and link to purchase the screws :( can abybody help me out ?
Offline Shiftshape
« Reply #404 on: Mon, 15 September 2014, 04:15:27 »
Is it worth getting my hopes up for a potential round 3?  ;)
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #405 on: Mon, 15 September 2014, 05:16:50 »
So it's to late to get in on this ah... :))
Offline AKmalamute
  • HHKB Scrub
« Reply #406 on: Mon, 15 September 2014, 16:10:50 »
You two should check the interest-check subforum. ;)
It's looking like it'll happen; probably soon, too.
HHKB-lite2, Dvorak user
  • Kitteh Overlord
  • Say WHAAT...
« Reply #407 on: Mon, 15 September 2014, 19:40:25 »
Thanks AK! I'm all over it!  :thumb:
Offline Shiftshape
« Reply #408 on: Tue, 16 September 2014, 02:47:22 »
Awesome, cheers!  ;)
Offline limitz
  • "the old gods stir and will not let me sleep..."
« Reply #409 on: Thu, 25 September 2014, 12:08:24 »
In light of the R3 of the metal ergodox case buy commencing, I was wondering if anybody has experience combining this plate, and Czarek's case.
I already have bought Czarek's PVC case w/ aluminum plate, but I want a more sturdy plate vs the flimy aluminum currently used in his designs.
I'd like to buy the kit, and utilize the SS plate in Czarek's case. Which option should I buy? Classic, Minimalist, or Extended minimalist?
Mmm... machined aluminum
Offline Data
« Reply #410 on: Thu, 25 September 2014, 12:41:58 »
All 3 configurations include a plate, so you would probably want to buy the cheapest (minimalist) if that's the only piece you're using.
I have no idea if the plate will work with czarek's case.
Offline witbliz
« Reply #411 on: Fri, 15 May 2015, 23:39:46 »
I would like to share pics of this wonderful case :)
I have not completed it yet but I'm almost there on my right side
« Last Edit: Sat, 16 May 2015, 02:03:04 by witbliz »
Offline braidn
« Reply #412 on: Tue, 19 May 2015, 08:29:23 »
These cases are amazing. I currently have an acrylic plate/Massdrop ergoDox and was wondering if these would work with that and if there were any still sitting around from the Group Buy/someone bought an extra that they are looking to offload?
Offline Data
« Reply #413 on: Tue, 19 May 2015, 13:01:39 »
Very nice.  Can you tell us a little bit about what you've done there?  Is that a powder coat or some kind of anodizing?  It almost looks "stonewashed" in your photos.
Offline samsonite727
« Reply #414 on: Tue, 19 May 2015, 15:13:38 »
Hey guys,
those that have bought the case does it scratch easily? I am really looking forward in buying it.
Offline Data
« Reply #415 on: Tue, 19 May 2015, 19:38:44 »
Hey guys,
I have the stainless.  It doesn't scratch that easily, but I also don't move my keyboard like, at all.  Depends on how you use it too.  If you just assemble the case as it came from the laser cutter then you're probably not going to notice a scratch.  If you polish it a little like I did it might show scratches more.
Also, this GB has been over and done for many months.  Orders are not open and I haven't seen much of AK lately.  Classifieds are probably your only chance to get one of these cases.
Offline witbliz
« Reply #416 on: Sun, 31 May 2015, 02:45:49 »
Yup its powder coated :) and I've just finishing soldering it and here is the pic with granite keycaps
I can't get it working tho :( must be something I did wrong on the software.
