Author Topic: [WTB] Case for A.87 PS2AVR  (Read 1909 times)
Offline GeorgeK
  • Trade Count: (0)
« on: Sat, 08 March 2014, 04:12:12 »
Morning all - I have an A.87 PCB coming my way but I have nothing to put it in!  As such I'm in need of (in order of preference)
The bottom half of a Filco / QFR TKL keyboard case (I have a couple of case tops courtesy of mkawa but no spare bottom halves)
or alternatively
An entire TKL keyboard case for an A.87 PS2AVR, preferably in orange, white or at a push black.
Does anyone have anything going spare?
Cheers
GK
« Last Edit: Sat, 08 March 2014, 04:32:44 by GeorgeK »
  • Trade Count: (1)
Re: [WTB] QFR Case Bottom or TKL Case
« Reply #1 on: Sat, 08 March 2014, 04:18:34 »
I don't think the A87 will fit in a Filco/QFR case, as it doesn't have holes for the plate standoffs. These usually go through the PCB and touch the plate. The plate then screws onto them.
You'd need a custom case designed for the A87, like the ones GON sells.
Offline GeorgeK
  • Trade Count: (0)
« Reply #2 on: Sat, 08 March 2014, 04:21:30 »
Hmmm - hadn't thought about that...  Might well be that I need a proper case for it then...  I didn't but the QFR tops for that reason at least (I bought them for my Filcos)
In that case does anyone have a case they want to sell that does fit the A.87?
Cheers bud
Offline GeorgeK
  • Trade Count: (0)
Re: [WTB] Case for A.87 PS2AVR
« Reply #3 on: Sat, 08 March 2014, 04:28:04 »
OP & title updated :)
Offline meiosis
  • Trade Count: (3)
  • Time
« Reply #4 on: Sat, 08 March 2014, 05:58:55 »
You can maybe ask around on the Korean forums if anyone has the files for the acrylic cases and have someone cut you something, for the most part a case will be quite hard to find. I know the LZ series all fit them, but they don't fit in standard cases as the F-row is slightly further distance then filco/qfr cases. There are some really nice acrylic pieces out there, maybe if you ask GON if he can help source one.
Keyboards:
Aripeko TKL
Offline GeorgeK
  • Trade Count: (0)
« Reply #5 on: Sat, 08 March 2014, 07:51:30 »
I am beginning to think that may be the case (pun not intended) - I imagine that all suitable cases probably already have boards in them :)
Offline Dreamre
  • Trade Count: (0)
    • kbdlife
« Reply #6 on: Sat, 08 March 2014, 09:36:22 »
Does the PCB fit in a KMAC (sorry for the rando question)?
Offline GeorgeK
  • Trade Count: (0)
« Reply #7 on: Sat, 08 March 2014, 11:56:52 »
Not sure tbh - I'd need to look into that more...
