Author Topic: Realforce issue  (Read 4401 times)
Offline tribade
Realforce issue
« on: Sun, 09 March 2014, 14:39:27 »
Hi all,
I got a realforce 87uw 55g board, and a digil0g aluminum case to put it in.  Everything was smooth sailing until i tried to get the ground off of the metal pcb.  Does anyone know whether Realforce puts locktight on the ground screw or something because I have had no luck whatsoever in getting it to budge, and I've been trying for a while now.  Has anyone else had this problem?
Here's an image I stole from ripster of the area: .  It's a phillips head screw that connects a ground to the PCB from the usb cable.
KMAC mini w/ blacks | Realforce 87uw 55g w/ Digil0g case | KMAC w/ blacks | Duck Viper w/ clears
"Te occidere possunt sed te edere non possunt nefas est."
Offline khaangaaroo
Re: Realforce issue
« Reply #1 on: Sun, 09 March 2014, 15:24:31 »
There's no locktight glue, but there might be a lock washer keeping it on there tighter than normal. Just get a good grip on a screwdriver that fits into the screw head well, and turn hard.
Offline exitfire401
  • The Force is Re/\l
Re: Realforce issue
« Reply #2 on: Sun, 09 March 2014, 15:26:58 »
Weird, mine came off with no issues. I remember it took some good force to get it off, but it still came right off.
Offline AKIMbO
  • HHKBro
Re: Realforce issue
« Reply #3 on: Sun, 09 March 2014, 15:27:24 »
I had trouble removing mine too.  I ended up using a very sharp micro-screw driver (flat head) to remove the screw.  It took quite a bit of downward pressure on the screw with the screwdriver, but it worked.
| KBD75 (box reds)
Offline aref
Re: Realforce issue
« Reply #4 on: Sun, 09 March 2014, 15:59:11 »
I had to use a micro tool set with an oversize handle to generate sufficient torque and, as AKIMbO said, downward pressure.
Offline tribade
Re: Realforce issue
« Reply #5 on: Sun, 09 March 2014, 18:21:45 »
Thanks for all the replies guys. I'll give it another shot when I get home from work later tonight. I think it must be a lock washer or something similar.
Re: Realforce issue
« Reply #6 on: Sun, 09 March 2014, 18:57:59 »
Downward pressure is key to prevent cam out of the Phillips bit. I recommend replacing it with hex or torx.
Offline Wildcard
  • When caffeine isn't enough
Re: Realforce issue
« Reply #7 on: Sun, 09 March 2014, 19:03:04 »
Use the force
Offline khaangaaroo
Re: Realforce issue
« Reply #8 on: Sun, 09 March 2014, 19:12:15 »
I second what AKIMbO said about using a flat head driver. I remember having an easier time getting it off with a flat head than a philips. Not as much downward force required to prevent it from popping out.
Offline AKIMbO
  • HHKBro
Re: Realforce issue
« Reply #9 on: Sun, 09 March 2014, 19:24:57 »
Use the torx
FTFY
| KBD75 (box reds)
Offline tribade
Re: Realforce issue
« Reply #10 on: Wed, 12 March 2014, 15:11:41 »
Use the torx
FTFY
Got it to work, thanks guys!  Turns out I really did just need more force.  I'm used to fixing fencing equipment with jewelers screwdrivers so I thought that I could get enough torque on it with those, but I needed that fullsize handle.  Fortunately we had a phillips head screwdriver that fit perfectly.  After a battle that took days, I had it out and put into its new case in seconds.
Thanks again for your help!
Re: Realforce issue
« Reply #11 on: Wed, 12 March 2014, 15:13:09 »
I've opened my silent model and my all 55g up multiple times and that screw came right out. Glad you got it!
Offline BucklingSpring
Re: Realforce issue
« Reply #12 on: Wed, 12 March 2014, 18:43:51 »
Sh0w us s0me digil0g pr0n 0nce d0ne!
Boards I own, click ->
