Author Topic: USB vs Ps2 Keyboards  (Read 62871 times)
Offline ricercar
  • mostly abides
« Reply #50 on: Wed, 02 December 2009, 00:13:09 »
PS/2 fits in a crayon sharpener. Try that with USB!
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #51 on: Wed, 02 December 2009, 03:44:25 »
To be honest I have not used my serial and parallel ports in ages, but they do tend to be very handy for special applications, like reviving semi-dead harddrives that have hung up due to a firmware bug, or controlling some ICs with an I2S interface (it takes a "real" parallel port for the latter though, a USB adapter won't cut it - by contrast, there are a few USB RS-232 adapters suitable for low-level stuff around).
Incidentally, even my trusty P2B-D (10 year old technology) has USB legacy support and I can use a USB keyboard for the BIOS setup just fine. Gotta try on the truly historic GA-686KDX.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #52 on: Wed, 02 December 2009, 19:03:20 »
Quote from: ripster;137921
Even my oldest computer (Asus A8N SLI Deluxe) allows me to access everything through USB at bootup.  In fact it's useful because I use a DiNovo Mini Bluetooth to access the media computer in a wiring closet downstairs from the TV room.  Try doing that with PS/2!
Your oldest computer is not old. Even my NEWEST machine doesn't do that!
Offline HaaTa
  • Master Kiibohd Hunter
  • Kiibohds!
    • http://kiibohd.com
« Reply #53 on: Wed, 02 December 2009, 19:56:02 »
Well, I bought a Gigabyte EP35 (DS3P I think) a while a back, it actually has headers on the motherboard for serial and parallel ports. Mind you its more than a year old now.
Kiibohd
ALWAYS looking for cool and interesting switches
I take requests for making keyboard converters (i.e. *old keyboard* to USB).
Offline Rajagra
« Reply #54 on: Wed, 02 December 2009, 21:05:00 »
Really? Can you hit print screen from inside the BIOS to get a screendump like you can with parallel printers?
Offline ricercar
  • mostly abides
« Reply #55 on: Thu, 03 December 2009, 00:15:03 »
My Commodore SX64 has no USB, no PS/2, but it does have mechanical key switches.
Offline keyb_gr
  • Cherrified user
« Reply #56 on: Thu, 03 December 2009, 03:04:40 »
Quote from: Rajagra;138225
That most probably not. I think the HID protocol was the only one deliberately kept simple so that key codes could be extracted just by looking at the packets.
Offline grantb3
« Reply #57 on: Thu, 03 December 2009, 10:25:16 »
Quote from: Hak Foo;137914
With USB, you get no "press F12 for boot menu" time.
I do.
Offline nowsharing
  • Swoop
« Reply #58 on: Wed, 31 March 2010, 16:47:48 »
Are there power usage benefits to using an active usb converter? I read this at clickykeyboards.com:
Quote:
Online reports indicate that vintage IBM ps/2 keyboards pull up to 100x more current compared to modern keyboards (112 mA vs 1.2 mA). see reference: (http://www.geocities.com/jszybowski/keyboard/index.htm). One way to resolve this problem to add resistors to change the voltage, or an easier non-destructive fix is to use an active ps/2 to USB plug-in converter with built-in electronics.
This sounds like it might add a longer life to older Ms?
Sorry to dig up this old thread. My blue cube came in today and it reminded me of a question I asked in this thread: Does converting to USB make our old Ms draw less current, perhaps extending the life of the onboard electronics?
Offline Rajagra
« Reply #59 on: Wed, 31 March 2010, 16:56:12 »
Quote from: ripster;168456
Now the M2 - those have like a 50% failure rate.
Sounds right. 50% of the 2 electrolytic capacitors in mine had failed, making it unusable. :rofl:
Fine since the repair though.:thumb:
Offline keyb_gr
  • Cherrified user
« Reply #60 on: Wed, 31 March 2010, 17:54:59 »
Quote from: nowsharing;168453
Of course not. That text you quoted wasn't worded overly well. It's not like the adapter would magically decrease the power consumption, but rather the higher current available with USB power compared to problematic PS/2 ports makes things more likely to work. It should be a +5V supply in either case.
Offline ch_123
« Reply #61 on: Wed, 31 March 2010, 18:07:32 »
The keyboard is going to consume as much power as it needs regardless. The issue here is that there are some motherboards whose PS/2 ports are inferior to the likes of the Blue Cube or the Belkin, so they actually are more reliable when used with the latter.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #62 on: Wed, 31 March 2010, 19:21:56 »
Since current was brought up, I should mention this (I will edit this post very soon after making it, because I need to get to one of the links in my sig to find what I'm looking for)
Edit: had to go through 14 pages to find it, but I found it.
http://geekhack.org/showpost.php?p=123069&postcount=186
1986 terminal keyboard was identified as using nearly 200mA of juice. I thought I had included a test with a normal Model M at the same time; apparently not. Presumably the controller PCBs don't differ too much though.
« Last Edit: Wed, 31 March 2010, 19:31:03 by kishy »
kishy.ca
Offline Manyak
« Reply #63 on: Thu, 01 April 2010, 01:13:34 »
Quote from: ch_123;168483
It's not the adapter that allows more power, it's the USB ports of the PC you're connecting it to.
Currently Owned:
Filco FKBN104MC/EB - Model M 1390131 \'86 - Model M 1391401 NIB - Unicomp Endurapro NIB - iRocks KR-6230 - Compaq MX-11800 - Cherry G80-8113HRBUS-2 - Cherry ML-4100 - Cherry MY-8000-something - Dell AT101W (Black) - ABS M1 - Siig Minitouch - Chicony KB-5181 w/ SMK Montereys - Chicony KB-5181 w/ SMK Montereys NIB - Cherry G80-3494LYCUS-2 - Deck Legend
Offline Nonmouse
« Reply #64 on: Thu, 01 April 2010, 01:18:57 »
Quote from: ripster;138230
What's a parallel port???  :biggrin1:
You can't be serial....
Offline Nonmouse
« Reply #65 on: Thu, 01 April 2010, 01:31:42 »
Quote from: ripster;168566
Yes I am.  USB is infinitely more powerful than PS/2.
Try boiling water with a PS/2 port.
I think I DIN hear you correctly....
Offline ch_123
« Reply #66 on: Thu, 01 April 2010, 03:28:59 »
Quote from: Manyak;168560
Never said otherwise. In theory, PS/2 offers more power, but in reality, a lot of motherboards skimp on it.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #67 on: Thu, 01 April 2010, 05:29:45 »
Quote from: ch_123;168574
Sorry but what's the theory behind that? Spec called for a max of 200 or 250 mA, I can't recall which.
USB spec requires a minimum supply to keep a device drawing up to 500mA happy at all times.
kishy.ca
