Author Topic: Electrical Typewriters keys in keyboards? (buckling spring)  (Read 4046 times)
Offline babuinix
« on: Sun, 09 March 2014, 22:40:54 »
Hello just recently got hold of a model M keyboard and was looking for some spare keys to dye.
What would be the keycaps on this thing, anyone would know?
Thx in advance!
i5 3470//GSKILL 8GB RIPJAW X//SEAGATE 1TB//XFX 550W//MSI GTX660 TF OC 2G
Re: Electrical Typewriters keys in keyboards? (buckling spring)
« Reply #1 on: Sun, 09 March 2014, 22:55:46 »
don't you taint that selectric
It's basically a beamspring, but older.
but seriously, don't taint it, it looks so good as it is
Offline babuinix
« Reply #2 on: Sun, 09 March 2014, 23:10:42 »
I dont want nothing with the typewriter, just need keys suplys!!
And those typewritters sell for like 20 bucks...
Offline Parak
« Reply #3 on: Sun, 09 March 2014, 23:24:04 »
It's not a selectric, it's a wheelwriter... quite more common and not quite as iconic. Plus the feel is replicable with any model M, except with a pretty bad layout that is hard to make functional standalone. So yeah, I'd say harvest away for springs, hammer, keys, etc.
Offline berserkfan
« Reply #4 on: Sun, 09 March 2014, 23:50:12 »
Check to make sure it isn't a beam spring. These things are worth more.
Offline babuinix
« Reply #5 on: Mon, 10 March 2014, 05:37:06 »
Is there any place with info on typewritter keycaps and their compability with buclking spring model M´s?
What would be the best direction to hunt some old keycaps to use on model m?
Offline babuinix
« Reply #6 on: Mon, 10 March 2014, 08:48:18 »
Someone selling this for 10 bucks, should i go for it for they keycaps or its a waste?
Offline Parak
« Reply #7 on: Mon, 10 March 2014, 12:37:50 »
At the very least you can scavenge their internal keyboard assembly (same construction as an M), and then decide what to do with it later. It's often cost prohibitive to repair these entirely, though if they are in a fully working condition, which is unlikely for $10, it's usually worth more to some people, maybe around $100.
Offline ideus
  • Björkö.
« Reply #8 on: Mon, 10 March 2014, 13:30:47 »
It is interesting the typewirters may be value some for someone. The OP is asking about the compatibility of their caps with a BS board. So I suggest someone with information on that to contribute to the thread. However, the OP does not seem to be interested in get into reselling the antique typewriters.
Offline hoggy
  • * Ergonomics Moderator
« Reply #9 on: Mon, 10 March 2014, 13:33:55 »
I've harvested caps from a 6747 (couldn't take the whole unit).  They work fine on a Model M.
Offline babuinix
« Reply #10 on: Mon, 10 March 2014, 15:21:39 »
THIS
Exactly!! Ill scavenge for cheap ibm typewritters and remove their keys to gather materials for my future dyeing experiences!!
Much Obliged
Hope this one is compatible also!! want that power on Keycap and the blank ones!!
« Last Edit: Mon, 10 March 2014, 17:23:51 by babuinix »
Offline Parak
« Reply #11 on: Mon, 10 March 2014, 20:49:36 »
Note my first post in the thread. Perhaps I should have been more explicit about it... but harvesting perfectly functional machines and rendering them useless is not something typically do, so hence my other post as advice and nothing more.
Oh, and that optima is most definitely not compatible. No idea which switch it uses though, but since it's german I suspect some type of cherry or perhaps marquardt.
« Last Edit: Mon, 10 March 2014, 20:51:20 by Parak »
Offline babuinix
« Reply #12 on: Mon, 10 March 2014, 21:34:38 »
Yeap guess ill stick with IBM ones!
Offline ideus
  • Björkö.
« Reply #13 on: Mon, 10 March 2014, 21:35:06 »
I undertood the intention of your post. I was just suggesting to keep the comments focused on what the OP was asking, advice on what key caps he can harvest for his keyboard. Of course he may not be aware of the value of the type writer.
Offline FoxWolf1
  • 154
« Reply #14 on: Tue, 11 March 2014, 13:42:05 »
Hmm.
So, in theory, could IBM typewriters of the right kind be modded for aesthetics with Unicomp keycaps?
Offline ideus
  • Björkö.
« Reply #15 on: Tue, 11 March 2014, 17:41:34 »
Hmm.
Modding a typewriter? Is someone actually using a typewriter these days?
Offline babuinix
« Reply #16 on: Tue, 11 March 2014, 17:44:56 »
Hmm.
I think he means electric ones, tought about that myself...
« Last Edit: Wed, 12 March 2014, 06:11:57 by babuinix »
Offline berserkfan
« Reply #17 on: Wed, 12 March 2014, 02:56:39 »
Actually, I think 99% of the ghers will be happy to take a perfectly functioning Razer, say that the Razer is going to die in a few weeks anyway, and take it apart for the switches rendering them useless.  :p
