Author Topic: Tai Hao Doubleshots + QFR Stock Grey Case  (Read 2717 times)
Offline morpheus
« on: Fri, 14 March 2014, 11:34:14 »
Hi guys,
I was wondering which color would go well with a QFR stock grey case.
If you own these keycaps and are using them, could you post some pics here?
thanks.
« Last Edit: Fri, 14 March 2014, 11:36:25 by morpheus »
Offline gigibecali
Re: Tai Hao Doubleshots + QFR Stock Grey Case
« Reply #1 on: Fri, 14 March 2014, 17:05:25 »
definitely reds.
IBM M - UK  |  QFR reds  |  QFR blacks  |  HPE 87 browns  |  HPE 87 blues
« Reply #2 on: Fri, 14 March 2014, 23:45:44 »
Hi guys,
thanks.
Mostly Tai Hao:
57492-0
Offline morpheus
« Reply #3 on: Thu, 20 March 2014, 12:49:21 »
definitely reds.
Hi guys,
thanks.
Mostly Tai Hao:
Red and Green look the best IMO. Thanks for the help!
Offline Lu_e
« Reply #4 on: Thu, 20 March 2014, 14:06:26 »
Hi guys,
thanks.
Mostly Tai Hao:
Profile mistmatch... OCD level rising
Just say NO to ABS keycaps
« Reply #5 on: Thu, 20 March 2014, 14:14:03 »
Hi guys,
thanks.
Mostly Tai Hao:
Only a few keys, but you gotta admit, it's a fairly close match :)
Offline gigibecali
« Reply #6 on: Thu, 20 March 2014, 18:26:17 »
I believe the colors are a bit off (calibrated display here).
The red is way more soothing than what the picture shows.
