Author Topic: Another SSK  (Read 8712 times)
Offline Pacifist
  • on hiatus
Another SSK
« on: Sun, 16 March 2014, 22:51:15 »
http://www.ebay.com/itm/261425764066
This time seller refurbed
Offline ideus
  • Björkö.
Re: Another SSK
« Reply #1 on: Sun, 16 March 2014, 23:01:58 »
According with your experience, how high its price is going to be at the end of the auction?
Offline Pacifist
  • on hiatus
Re: Another SSK
« Reply #2 on: Sun, 16 March 2014, 23:04:13 »
Now that its on great finds and its seller refurbed, $300ish. Recently there's been an influx of $200ish SSKs here on GH so the prices are going down a bit
Offline ideus
  • Björkö.
Re: Another SSK
« Reply #3 on: Sun, 16 March 2014, 23:08:32 »
That is why I have never ever thought in getting one, just out of my league.  :p
Offline Pacifist
  • on hiatus
Re: Another SSK
« Reply #4 on: Sun, 16 March 2014, 23:10:19 »
Yea I don't really dig SSKs
Its small and portable but
1. You won't be taking it everywhere as its pretty heavy, bulky, and lould
2. Its not very good for gaming as its 2kro
Re: Another SSK
« Reply #5 on: Sun, 16 March 2014, 23:17:12 »
Well whoever put the first bid put more than $50 (which was my max).
Offline Pacifist
  • on hiatus
Re: Another SSK
« Reply #6 on: Sun, 16 March 2014, 23:17:48 »
I put down $50 to get the ball rolling
Offline ideus
  • Björkö.
Re: Another SSK
« Reply #7 on: Sun, 16 March 2014, 23:18:47 »
LOL! well you were outbid, and you do not have more to be concerned about now, so get a drink and relax.
Offline The_Beast
  • I like wood ಠ_๏
Re: Another SSK
« Reply #8 on: Mon, 17 March 2014, 00:04:26 »
Damn son, exactly 2 months older than me.....
Offline Belfong
Re: Another SSK
« Reply #9 on: Mon, 17 March 2014, 00:24:00 »
What is bolt modded?
Offline Pacifist
  • on hiatus
Re: Another SSK
« Reply #10 on: Mon, 17 March 2014, 00:28:05 »
Plastic rivets are replaced by metal bolts
Re: Another SSK
« Reply #11 on: Mon, 17 March 2014, 00:52:03 »
The original IBM keyboards were built like tanks, except for plastic rivets holding the metal plate on inside.
Over time those rivets would fall off one by one until the keyboard turns mushy.
A common upgrade is to slice off the heads of any remaining rivets, drill the holes out, and put small bolts through to keep the plate and other bits firmly held together for another 30 years.
Offline berserkfan
Re: Another SSK
« Reply #12 on: Mon, 17 March 2014, 02:23:14 »
nowhere in the ad does it say it's bolt modded. don't be misled, guys!
Offline ed_avis
Re: Another SSK
« Reply #13 on: Mon, 17 March 2014, 02:35:35 »
Why do you say the SSK is 2KRO?  Is that something peculiar to SSKs or is it true of Model Ms in general?  I always thought the PS/2 connector was superior to USB in that it allows more rollover combinations - but does the Model M not take advantage of that?
Offline Belfong
Re: Another SSK
« Reply #14 on: Mon, 17 March 2014, 02:40:04 »
The bolt modded is the one sold by Bro Caps, not the ebay one - I asked because Bro Caps post mentioned it.
Re: Another SSK
« Reply #15 on: Mon, 17 March 2014, 02:45:54 »
That is my bad, I had to shuffle some posts around.
The SSK has a membrane as the actual keyborad matrix and is 2KRO like almost all membrane keyboards.
I recommend reading this page about kb matrix circuits
http://www.dribin.org/dave/keyboard/one_html/
Basically, there's only continuity (or lack thereof) between the nodes, and no place for diodes (or something exotic, like the microsoft sidewinder kb uses)
PS/2 has the bandwidth to support NKRO for keyboards, whereas "full speed" USB 1.1 only supports 6 key and a few modifers. USB 2.0 supports enough for NKRO, but isn't common in keyboards.
so for a KB to have NKRO, it has to have an NKRO compatible circuit, an NKRO compatible controller, and use an NKRO compatible protocol. The SSK only has the latter. Many USB keyboards have the first two. My current keyboard (IBM F 122 with soarer's converter) has all three.
hope this helps.
Offline mougrim
Re: Another SSK
« Reply #16 on: Mon, 17 March 2014, 04:55:59 »
And how about XT keyboard?
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Offline E TwentyNine
    • Some of My Keyboards
Re: Another SSK
« Reply #17 on: Mon, 17 March 2014, 07:39:50 »
Saying 2kro makes an M a poor keyboard for gaming is simply wrong.  It has zero impact the vast majority of the time.
For those who don't know, 2kro is the *minimum* keys you'll get correctly pressed, not including modifiers.  You'll usually get more.  I've gotten 16 at once through a native ps/2 port and should be able to get 22 keys pressed and registered correctly if the controller can handle it.
Through most USB converters today that drops to 6, which is more than enough.
The XT is NKRO but you'd need a converter like a soarer to use it with a modern computer.
Offline ZeDestructor
Re: Another SSK
« Reply #18 on: Mon, 17 March 2014, 09:12:17 »
At which point you might as well for an AT or F122 for the nicer layouts.
Offline mougrim
Re: Another SSK
« Reply #19 on: Mon, 17 March 2014, 11:16:38 »
Yep, but there scarce any AT to be found.
Offline berserkfan
Re: Another SSK
« Reply #20 on: Mon, 17 March 2014, 11:38:27 »
Just not at a price you want to pay ^-^
BTW AT is VERY HEAVY. I suggest you buy and cart around two CoolerMaster Quickfire TKs. Cheaper, and lighter, and you can have two switch types to swap from versus just one F AT.  :))
Offline mougrim
Re: Another SSK
« Reply #21 on: Mon, 17 March 2014, 11:42:25 »
Price ain't so bad... it's the shipping that the real killer. So my only chances are to find one in Europe.
Cooler Master TK's not so bad, really :)
Re: Another SSK
« Reply #22 on: Tue, 18 March 2014, 05:58:09 »
Literally nothing is like a true BS though....
Offline mougrim
Re: Another SSK
« Reply #23 on: Tue, 18 March 2014, 06:01:18 »
True story, bro :) I like my Unicomp enough, but real IBM ones from AT epoch... dat another matter :)
Offline Grr8
  • Quack!
Re: Another SSK
« Reply #24 on: Tue, 18 March 2014, 11:53:14 »
Another SSK?
Is that a challenge?
Busy cleaning 3 of the ones I already have :)
57829-0
Daily Driver: Poker II Backlit (Ducky Mini-fied) + Amazon o-rings. Future daily driver IBM AT Model F (restoring now). For fun: IBM SSK 1397681 (NIB), IBM SSK 1391472, IBM Industrial 101 Square label 1388032, IBM Industrial 101 Black label 1394946, IBM 1391401 (bolt-modding now), IBM 1370477, IBM 42H1292 (USA), IBM 52G9700 IBM, and more....
Ducky Shine w/Blues + WASD o-rings, Ducky Shine 3 TKL w/Browns + ebay o-rings, Rosewill RK-9100 w/Blues, Apple Wireless (slim), Apple Wireless White A1016, Apple Extended II ADB. Next? HHKB2Pro?
Offline n0rvig
Re: Another SSK
« Reply #25 on: Tue, 18 March 2014, 11:56:47 »
They go for a lot less when they aren't noticed here. I saw one go for $91 last week.
Offline Shyfe
Re: Another SSK
« Reply #26 on: Wed, 19 March 2014, 02:07:29 »
Can you link to this? I have looked through eBay history and have not seen any go for less than $250.
HHKB (55g) | IBM SSK | Realforce 87U (55g) | Unicomp EnduraPro | KBT Oni
Re: Another SSK
« Reply #27 on: Wed, 19 March 2014, 04:36:07 »
There's a couple on eBay now (at least last time I looked) for $200.
Offline mougrim
Re: Another SSK
« Reply #28 on: Wed, 19 March 2014, 04:43:13 »
I doubt many cool boards aren't noticed here. Seriously. But... all happens :)
Re: Another SSK
« Reply #29 on: Wed, 19 March 2014, 08:23:09 »
Lots of cool boards don't get posted here. Where do you think HaaTa and I get all our neat KB stuff?
Re: Another SSK
« Reply #30 on: Wed, 19 March 2014, 14:12:03 »
I need to get out more - $91 for SSK is more like my kind of price :p
Offline HAL9000
Re: Another SSK
« Reply #31 on: Wed, 19 March 2014, 14:37:21 »
True! I just bought an 1386303 with "buy now" before anyone noticed
Code: [Select]
/*pz*/char p[]=" ELPRTWZ";unsigned z[]={553179788,1641},
_=14;main(){while(_--)putchar(p[z[_/012]>>3*(_%10)&7]);}
Re: Another SSK
« Reply #32 on: Wed, 19 March 2014, 16:43:17 »
I hope it wasn't this one.  http://www.ebay.com/itm/111299617857  $400+
Re: Another SSK
« Reply #33 on: Wed, 19 March 2014, 16:59:58 »
I have an F-122 from that same date! Is this one a terminal variant of the 1390120?
- D Trump 2026-10-24
Re: Another SSK
« Reply #34 on: Wed, 19 March 2014, 17:42:20 »
Considering the date and lack of LED's I'd have to say yes.
It's a Display Station 3161 keyboard.
Re: Another SSK
« Reply #35 on: Wed, 19 March 2014, 22:11:18 »
The 1386303 is the very first model M (along with the 1386304), even before the first industrials. Killerbee on GH had the oldest known M at one time (june 10 1985!). This KB in the OP is a rather late sample for a 1386303, just to give an idea as to it's age. I believe they may have been discontinued by the end of 1985.
By the way, I could be totally wrong about the production, as that one seller had those NIB (?) 1386304's from 1991.
« Last Edit: Wed, 19 March 2014, 22:14:43 by dorkvader »
Offline Pacifist
  • on hiatus
Re: Another SSK
« Reply #36 on: Wed, 19 March 2014, 22:11:55 »
Oh dam thats sweet
Offline Belfong
Another SSK
« Reply #37 on: Wed, 19 March 2014, 23:56:35 »
How come no one is buying Bro Caps' super nice SSK? Am I the only one noticing it?
Re: Another SSK
« Reply #38 on: Thu, 20 March 2014, 00:06:56 »
Too expensive for me (even excluding shipping) :(
Offline Belfong
Re: Another SSK
« Reply #39 on: Thu, 20 March 2014, 00:22:29 »
Yeah, I'm just so afraid of the shipping cost because it's so heavy!
Offline mougrim
Re: Another SSK
« Reply #40 on: Thu, 20 March 2014, 02:58:48 »
Even if you choice USPS, it still 60 bucks.
Offline Belfong
Re: Another SSK
« Reply #41 on: Thu, 20 March 2014, 03:35:27 »
When I bought Code keyboard, shipping was already $50! I think SSK is more than that.
Re: Another SSK
« Reply #42 on: Thu, 20 March 2014, 08:00:46 »
I'm going to have to beg to differ on that point.
Offline Grr8
  • Quack!
Re: Another SSK
« Reply #43 on: Thu, 20 March 2014, 08:33:38 »
One went today for $152, not "restored" with no cord:
http://www.ebay.com/itm/271424173742
Re: Another SSK
« Reply #44 on: Thu, 20 March 2014, 14:11:20 »
That is US$, converts to about AU$168.69, and then add some silly postage amount, usually around $80 on top of that :(
Re: Another SSK
« Reply #45 on: Thu, 20 March 2014, 19:35:38 »
If you noticed my modifier has been carefully places (instead of misplaces) so you can take my statement to mean that at one time (not necessarily now) he had the oldest M on GH (which was certainly true). Now it's possibly not the oldest and he no longer has it, so my statement stands as written.
I just know someone would show up with their pedantry.
To be honest, I'm not sure why people in the market for a ssk don't just "watch" hyderconsulting's store.
