Author Topic: Just received my first Topre keyboard: a Type Heaven. My ongoing analysis...  (Read 19994 times)
Offline mougrim
Then there are always O-rings.
Which don't dampen the click sound. The click sound is quite high-pitched and more prominent than the bottoming out sound, if somebody gets annoyed by the sound of a keyboard with MX Blues it probably isn't because the person is bottoming out.
Yeah, you're right. As klick sound emitted by internal structure of switch...
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Offline ynrozturk
I had a pretty similar experience to OP, but I used a HHKB for about 3 weeks before I finally said no, this isn't for me. And those 3 weeks were pretty boring, typing wise. When I went back to my buckling springs, blues and browns, I was having fun again.
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
To each's own, loving my Toper Realforce 87U TKL and typing feel. After owning other boards it's the only one I've stuck with.
Offline adhoc
Well at least you gave it a good try. You can't evaluate a board after a few key presses. Then again, if one loves clicky switches, such as blues and buckling springs, Topre will probably not be his cup of tea.
Offline paco
OP here.
First, I would just like to clarify something.
I think some of you took my initial post too seriously. I wasn't bashing on anyone in particular (but all of you. jk.)
That being said, I think I should emphasize on the fact that my goal was to warn people wishing to buy a Topre based keyboard that it might not be what they are expecting.
A recurrent comment was that because I didn't like MX Reds so much, I should have known better than to buy a Topre keyboard.
TweakTown.com has a review of the Type Heaven where it is mentioned "After much use, I found the Topre to be much like a brown switch in feel and noise...". I read multiple reviews here of the keyboard but most importantly I read a plethora of positive comments about Topre switches.
I read more than once comments like: "when you press on a key, you can feel a pop and then the collapse of the dome to a mushy bottom".
That is nothing like MX Reds. The only thing I could relate Topre to MX Reds (from the read descriptions) is the resistivity of the switches.
What I am trying to say is that I read enough about Topre to lead me to believe I was missing out on the best switch there is. The switch exhibited tactility, smoothness, finess. I wanted it.
I brought the keyboard at work Thursday and Friday. I wanted to expose myself fully to the keyboard. I can thus ellaborate a little more:
Regarding the build quality of the keyboard:
The keyboard is really well built.
  • Yes, if you purposely tap bellow the right side of the space bar, you will hear rattling. I don't care about that.
  • I noticed that if I pressed on the right section of the ENTER key, that it would make a different sound than if I pressed anywhere else on that key. It bothers me, but just a bit.
  • The lack of rubber pads under the keyboard is the most glaring issue. On a normal surface, the keyboard moves easily. Luckily at work, I have a surface with two pads of rubber on which the keyboard sits. It doesn't move then.
  • Finally, I was surprised by the small size of the Win-keys. They chose to make the Ctrl and Alt keys bigger. At first I didn't like it and thought I would have a hard time finding the key (which I use quite often), but it wasn't a problem.
Regarding the feel of the keyboard:
It is slowly growing on me. I am starting to appreciate how the keys feel.
  • I still feel the keys are rather stiff. Typing on my MX Red based Poker II is extremelly different. The Reds are MUCH less resistive than the 45g Type Heaven. This translates in me typing more slowly and taking the time to bottom out. Maybe with more practice this will change.
  • Tactility: My definition of tactility with regards to keyboard switches is a physical feedback from the switch telling you it is being depressed. On any cheap membrane keyboard, you need to apply sufficient force on a key for it to move at all and then instantly collapse. You could argue that the act of collapse is feedback in itself. This is not what I am talking about when I mention tactility. The best parallel I could draw would be the difference between MX Red and MX Brown. To me, MX Red has zero tactility whereas MX Brown has tactility (not at lot, but it has some). I used Matias ALPS and it had tactility. It was similar to Topre in the sense that all the resistance was at the top of the depression, but you still felt a bump at the top telling you "you are activating this switch sir!".
    By that definition, 45g Topre as implemented on the Type Heaven is NOT tactile. There is no bump. There is no pop. All there is is a resistance like on any cheap membrane keyboard until the dome starts to give and collapse.
    That being said, it IS smooth. It IS comfortable.
    Actually, this is what happens to me when I slowing press on a key: there is resistance until collapse starts. It is not a brutal collapse where I bottom out instantly. It is easy to control the rest of the travel (again, when concentrating on one key). Bottoming is a journey through which you can feel a very pleasent smoothness of key through the stem. Rebound is light. There is a 'texture' to the movement of the key. It is completely linear like Red/Blacks are linear, but you feel something smooth in that movement. I believe this is what people refer to when they say it is 'buttery'.
    But, again... there is absolutely zero bump or pop at the actuation point or anywhere during the operation of the key. Maybe on 55g. Maybe on Leopold. But on the Type Heaven, there is none. Nada. Nobody could argue that. That would be like saying milk is green.
  • I find the sound to be a little too 'clackety' for my taste, but I will live through this ordeal.
  • Also, I felt the keys were somewhat... 'loose'. Maybe not Matias loose, but... loose nevertheless. And that is not a bad thing. It gave the keyboard a 'vintage' feel to it which I like.
td;lr
My goal is to warn people wishing to buy Topre based keyboards that they are buying a keyboard is zero tactility. It will be a high quality board. It will be a board with smooth switches. It will be a comfortable board. But that will be it.
The Type Heaven is slowly growing on me. Initial disappointment is letting place to some kind of pleasanteness in getting to know the keyboard.
Offline Polymer
I think the best thing is to describe it rather than claim it has no tactility..which is wrong.
The collapse of the dome is indeed tactile...maybe not by your definition but your definition is wrong. The collapse of the dome is a change in feel which by definition is tactile.   You can certainly say you dislike that type of tactile feedback or that you like to have something more than a dome collapsing..
What surprises me is that some people are surprised by things like the tactility.    If you read through the Topre threads, one very consistent thing is described, that Topre has a rubber dome.  The main feel you get from a Topre is that there is a dome that collapses...The difference between a Topre and a regular rubber dome is the stability, the smoothness and the solidness...But the main mechanism for how Topre behaves is a rubber dome and it feels like that.  You can feel it collapse...If you don't think rubber domes are tactile then you won't feel like Topres are tactile because they behave exactly the same way.  How this is a surprise to anyone that actually read a thread or two on it, I'm not really sure...
I'm glad you're at least using your keyboard and giving it time..
Offline epzy
  • HHKB Fiend
  • ded
"The keyboard is really well built."
"Yes, if you purposely tap bellow the right side of the space bar, you will hear rattling. I don't care about that."
"I noticed that if I pressed on the right section of the ENTER key, that it would make a different sound than if I pressed anywhere else on that key. It bothers me, but just a bit"
Lol. So contradicting... that's not exactly what I would call a 'well built' keyboard. :/
Offline dante
30g is linear, 45g is not.
You are right - it is not as well built as its big brothers however that's ok with me because the typing experience is great.
For example: Many consider the IBM M2 to be inferior to other buckling springs due to the way it's constructed.  On the other hand due to the lower profile and the fact that it doesn't have a metal plate it is much more satisfying and comfortable to type on than the others for me personally.  For me IBM M2 > SSK/All other M bolt modded or not.
Some of us, a keyboard doesn't need to weigh 5 lbs and be built to withstand being driven over by a vehicle to be a fun comfortable experience.
Offline paco
By your definition (a change of feel), this means a 30g Topre is as tactile as a 55g Topre. This is consistent with  this thread I guess.
But, just google: "topre pop". To me a 'pop' is _not_ a rubber dome that collapse boringly. A pop is synonymous with 'bump'.
So, I take it is correct to say Topres are tactile in the sense there is a difference in feel once the switch is actuated, but there is no bump.
Things are not absolutes in life. You can have a Filco Majestouch 2 that you will say is well built but has crappy ABS caps and pings. They still are top notch keyboards.
My Poker II exhibits all kinds of different sounds when I press, for example, on the backspace key. I still think the build quality is excellent.
There is no contradiction. The Type Heaven is a heavy, well built keyboard. It has flaws, but I would still consider it to be very well built.
BTW, I didn't answer your first message. The Type Heaven where I live is usually 200$. I got it for 150$ + Free shipping. A Filco Majestouch 2 is about that price + shipping. I consider this to be expensive for a keyboard, hence the reason I had said it had cost me an arm and a leg.
Offline epzy
  • HHKB Fiend
  • ded
Yeah... no. Nothing wrong with ABS keycaps as long as they are of high quality. Stock keycaps are usually not high quality, but it shouldn't reflect on the _build_ quality. You can change keycaps easily. The Type Heaven reaks of low quality. Filco cases are way more solid than that. None of my 2 Filco pings btw, and if they did, it wouldn't matter as I don't consider it a defect or low quality. Some of my other keyboards pinged for a while, not any longer - not sure how or why... placing a anti slip rubber mat beneath the keyboards that pinged helped as well.
Offline paco
lol.
this is ludicrous.
I don't know if you are just trolling or being obnoxious. Either way, I am done with you.
Offline epzy
  • HHKB Fiend
  • ded
lol.
this is ludicrous.
Great reply!
Not sure why you're trying to argue it's well built. https://www.youtube.com/watch?feature=player_embedded&v=8adZh1sNzqI - You said you have this as well, so it's obviously not well built.
Also, the lack of rubber pads under the keyboard also qualifies as 'not well built'.
« Last Edit: Sat, 22 March 2014, 08:02:07 by epzy »
Offline tinlong117
lol.
this is ludicrous.
Then I bet you have never tried a proper realforce.
Offline Polymer
"As Tactile" is not the same as just being tactile right?  Not sure if you've actually tried 30g Tope but IMO they feel very linear because I don't feel a change there at all (it doesn't feel like there is any collapse at all even when I look for it carefully)....but you're not claiming that for 45g (some 55g users think 45g feels linear).  You're claiming you feel the collapse (tactile) but you don't consider that to be tactile.
45g Topre is not as Tactile as 55g Topre but they're both Tactile.
They're tactile..but not in the way you like them to be..which is fair enough...Plenty of people want something else...
Offline paco
lol.
this is ludicrous.
By that logic, a Realforce owner would be shot down by a KMAC owner saying "You think your Realfoce is well built? I bet you have never tried a KMAC!".
We could draw an analogy in the car industry or with pretty much everything else.
Relative != Absolute
I have had a Deck 82, a Max Blackbird, a Matias Mini Quiet Pro, a Poker II, a QFR, a QFS and so many cheap keyboards, I stopped counting a long time ago.
The Type Heaven is heavy. The Type Heaven is solid. The Type Heaven is tight. The Type Heaven is well built.
You don't agree? To me, that is just being pedantic.
Offline paco
My only experience with Topre is with my 45g Type Heaven.
I can understand what you mean with the 30g being linear. I have MX Red and I can relate to the feeling you are describing.
Though, I have a hard time understanding what would be different between the 45g tactility and the 55g tactility if we agree the tactility of a Topre is, at most, the change of feeling the keys have once you have conquered the force required for the dome to collapse.
My understanding is, the 55g would require more force to collapse and that's it.
Please, enlighten me if I fail to understand the subtility of the 45g vs the 55g switches.
Thanks.
Offline epzy
  • HHKB Fiend
  • ded
lol.
this is ludicrous.
Yes, because comparing customs to stock keyboards is sane... Most people would argue metal cases being superior to plastic cases, simply because of the material.
The Realforce housing is way more solid than the Type Heaven. The Type Heaven has a lack of basic features like the anti slip rubber pads and that case defect is just not acceptable. Compare the Topre Type heaven to other Topre's and it doesn't look like it's well built in comparison.
Offline Polymer
Thanks.
The collapse on the 55g will feel bigger because it takes more force to push them down...To me I think the actual difference in tactility between 45g and 55g is not that much (but there) but other people will feel it is a lot...Fans of 55g Topre will feel like it makes a big difference and feel the keys are snappier..  They are snappier for sure but to me they're slightly heavier than what I want..but for you, 55g might be a better option.
Offline QuadGMoto
I haven't had a chance to touch any of those boards for myself, but considering that TypeHeaven is sold as the lower end of the Topre line, I would expect the build quality to be inferior to those boards, as you said.
It's all about your point of reference—what you are comparing it to. If you're comparing it to a piece of garbage $19.95 rubber dome, then the TypeHeaven's build quality should be very solid.
paco is comparing the TypeHeaven to different keyboards than you are. It's that simple. Is it not as solid as the boards you're comparing it to? I assume the answer is yes. Is it solid in comparison to the boards he's comparing it to? Again, I assume the answer is yes. There is no contradiction there. Arguing over something you both apparently agree on is just arguing for argument's sake. So please chill.
Offline dante
The one bad thing about 55g is you can't find them in a fullsize layout.  I remember reading 55g being created specifically because Korean banks asked for it - so it's odd to only see it in a tenkeyless.
Offline epzy
  • HHKB Fiend
  • ded
The fact of the matter is: He says it's well built, when it has obvious build quality flaws. It's a $150-200 keyboard, you compare it to the keyboards in that respected price range, not to a $400 KMAC or a $10 membrane keyboard.
Offline paco
Thanks.
I can't really represent to myself what "snappier" would translate to. I stopped using my Deck 82 become it had MX Blacks which I thought were too resistive for me to type on for long periods.
I feel buying a 55g is more risky. Both the HHKB and the Leopold are 45g. The 55g seems to be very unique.
I read somewhere the ESC key of variable weight Realforce was 55g. I guess the ESC key of a Type Heaven is 45g, right?
I wanted you to tell me the 55g had the 'pop' feel in them. ;-)
Bizarre indeed. The 104UG "High-Pro" seems to be made for the financial sector (if I read EK's description well), so I would assumed the weight to have been 55g if the requirement was coming from the financial sector.
Offline Hordak
This thread seems like a good place to ask if it is true that 55g Topre feels similar to the old IBM Thinkpad keyboards from a view years ago (before the Lenovo takeover)?
Offline Hordak
I don't own one, but the Realforce doesn't seems to be as well built either.
Offline Polymer
That's because most people don't realize how the case is built..it is made (for whatever reason) so you can take it off which also means it can slide a bit.
This ends up making it possible to twist the case so it doesn't sit evenly on the desk...but all you have to do to fix it is press down on the case on all four corners and maybe twist it the other way slightly...
It doesn't mean it is made poorly...
Offline epzy
  • HHKB Fiend
  • ded
"It's a result of the way the case is designed (screwless)
Because the whole thing just clips together, there is some play between the top and bottom half of the case. I doubt Topre skimped here just because they were going to save money on screws, given that they use about 300 screws to hold the PCB and mounting plate together. Some of their OEM boards have screws in them anyway."
It just moves a few mm or so.
Offline Hordak
Even if it's no big deal, for 250$, I would none the less expect it to be designed flawlessly.
Another point about the realforce to be aware of - if you're considering it OP - is that the keys are slightly larger than normal on this board. Again, some may like that, some won't.
Offline tinlong117
lol.
this is ludicrous.
Firstly, it's not a kmac, it's a lz-s. Second, I don't own this anymore and I didn't feel it's better than my €10 G80-3000. Third, weight doesn't mean the board is well built. I also have uncountable cheap keyboards such as deck legend, ducky 9008, some random cherries. However, ducky is the heaviest amoung those, does that make the board well built? No, I don't think so. My less than 1kg 3000 is better than that. Also, according to your logic, hhkb isn't well built then.
Offline paco
The Deck Legend is one of your cheap keyboards? Either you made a typing mistake or, you too, are trolling!
You know I didn't say weight == quality. You are isolating one of the variables I enumerated that I consider important to a good quality keyboard. I don't know what you are trying to do, but it sure isn't very productive.
You want to look l33t by bashing the Type Heaven? Go ahead.
Offline epzy
  • HHKB Fiend
  • ded
If he's comparing it to a LZ-S it's cheap. And what's cheap for him, might not be for you. He's definitely not trolling you. No matter what you say, it's still not well built compared to other Topre's.
"You want to look l33t by bashing the Type Heaven? Go ahead." - Dumbest **** I've read so far. Pointing out obvious flaws when you say it's 'well built' isn't necessarily bashing, more like giving reasons as to why I don't think it's a solid keyboard.
Offline tinlong117
Yet you're the real troll here.
Offline daerid
    • Rossipedia
People taking too much personally in here. It's GeekHack peeps, we all love keyboards, and we all have different opinions, mmk?
LOVE
Offline tbc
topre keycap reality distortion field working again.
it is COMPLETELY fair to judge the stock keycaps on a topre board because a replacement set costs from $80 to $110(although with keysets no longer being sold, the cost is actually closer to $200 for a whole realforce keyboard).  whereas it costs only 59 for a pbt doubleshot mx set or less for a lower quality set.
Offline epzy
  • HHKB Fiend
  • ded
Talking about MX keycaps, not Topre.
Offline tbc
apologies.
my actual point in general still stands though.
Offline epzy
  • HHKB Fiend
  • ded
Well the stock ABS Filco keycaps are better than many other stock ABS keycaps.
https://dl.dropboxusercontent.com/u/106134265/20140322_110556.mp4
Offline daerid
    • Rossipedia
Are RealForce caps bigger? I can't tell... they look the same size to me (my RF is sitting right next to one of my Dox's that has OEM DCS caps).
Offline daerid
    • Rossipedia
Every RealForce I've owned has done that. It's how the case is designed. That doesn't automatically mean it's not "well built".
Offline epzy
  • HHKB Fiend
  • ded
They look the same size to me as well... but I haven't taken proper measurements. :P
Offline Hordak
Wow, thanks for the vid, that looks really bad; although the board itself looks like a stealth bomber :cool:
Offline epzy
  • HHKB Fiend
  • ded
I wonder how much it actually moves, I'd guess 0.1 - 0.2 mm or something silly. Can barely feel it move at all, doesn't hurt the experience or anything though. Plus you need to take your whole hand and force it to move. :p It's just how the case is designed; if you don't accept it, don't buy it - simple, but if that's a reason to not get one... then I don't even know.
Offline Hordak
Yeah, I may have been WRONG about this one. I re-checked the video where I got this from, and it seems that it is in fact the HHKB that has the wider keys and NOT the Realforce. Sorry about that.
Offline Hordak
Oh, I was tempted, but it's just too expensive for me w/o being able test it pre-purchase, especially when calculating in shipping & tax to europe and also because it seems even a greater hassle to get extra keycaps. Gonna wait for the novatouch release.
I don't understand... If OP liked greens but greens were too loud for his gf, why not try MX blues? Quieter, not so stiff version of greens. Or vice versa.
I don't think Blues are that much quieter that it would matter.
o-rings make blues more loud... this was measured elsewhere on the webs. QUOTE WAY BACK
Offline Candyflip
That explains it, I always thought I was delusional thinking that o-rings can make blues louder...
Offline Polymer
Not sure how that would even be possible..but from personal experience and from videos as well..that statement doesn't seem to be true...
The o-rings wouldn't make the click any louder..and it makes less noise when you bottom..
Offline Hyde
  • White Tofu Extraordinaire
It's an illusion, because without o-ring the bottom out sound masked the click sound.  And with o-ring it muffles the bottom out sound, so in contrast the click sound just sound extra loud.
But yes in terms of physics it's impossible to get louder with o-ring.  :P
Offline zig_ziglar
It depends on numerous factors as to whether or not it is an illusion. This might help.help: http://www.sengpielaudio.com/calculator-spl.htm
Depends on what material the O-ring is made from :p
