Author Topic: Sharpkeys simple remap  (Read 3010 times)
Offline zippox
« on: Thu, 20 March 2014, 08:34:48 »
I would like to remap the Pause key on my QFR to be a Return or Enter. I must be missing something obvious because I open the application make my two selections, press write to registry, restart, and the pause key doesn't press enter. Ideas?
Offline hoggy
  • * Moderator
Re: Sharpkeys simple remap
« Reply #1 on: Thu, 20 March 2014, 12:35:14 »
From memory, the pause key is rather strange, I think it doesn't raise one or more of the usual events, try remapping another key to enter and see if that works for you.
Offline zippox
« Reply #2 on: Thu, 20 March 2014, 13:07:37 »
The pause key is to me the most useless key and close to my mouse which made it a good candidate as an Enter-key replacement. I'll try your suggestion and see if it is just a Pause key problem. Any other software I can try to remap the key?
« Reply #3 on: Thu, 20 March 2014, 13:08:49 »
I know a lot of users have used AutoHotKey to remap their keys. You could try that.
Offline zippox
« Reply #4 on: Thu, 20 March 2014, 13:13:54 »
I created a script with:
Pause::Enter
Works great! Thanks for the suggestion.
