Author Topic: [IC] - Firefly/Serenity fans...(Final Mock-ups + Revised Spacebars)  (Read 36758 times)
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
Re: [IC] - Firefly/Serenity fans...(Revised with Mock-ups)
« Reply #100 on: Sat, 03 May 2014, 02:54:38 »
DSA PBT spacebars are indeed available.
Offline vierax
« Reply #101 on: Sat, 03 May 2014, 03:02:42 »
Thank you Matt, I'm not (so much) crazy  ;D
edit : Well, I'm still a bit since I thought it was a DSA set  :-[
« Last Edit: Sat, 03 May 2014, 03:05:53 by vierax »
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« Reply #102 on: Mon, 05 May 2014, 17:07:21 »
Help!? SP says I need to limit the phrases on the Spacebars to 2 inches or less... :-[
Give me some ideas on what to change them to, please...
 :-X
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Offline thezooman123
  • Dongs
« Reply #103 on: Tue, 06 May 2014, 00:34:38 »
Interested as ****, those mockups look great
Free clickclacks plz
Offline 00zeRO
« Reply #104 on: Tue, 06 May 2014, 07:17:21 »
 :-X
got it...
'keep flying'
-and-
'to the black'
those should be 2 inches or less...(grumble, grumble)
Offline 00zeRO
Re: [IC] - Firefly/Serenity fans...(Final Mock-ups + Revised Spacebars)
« Reply #105 on: Thu, 08 May 2014, 20:37:01 »
In case anyone is wondering, I am about ready to kick this thing off. I have made the final revision to the mock-ups at the beginning of this thread, and I am looking to start the Group Buy very soon...
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #106 on: Thu, 08 May 2014, 20:46:04 »
I've been selling all my novelty key caps, but these sets are too hard to resist!
Nice work 00zeRO!
Offline 00zeRO
« Reply #107 on: Thu, 08 May 2014, 20:49:56 »
Nice work 00zeRO!
I wish I had this kind of response to the Matrix 'caps...I want to post that group buy, but I fear it will flop...not that many Matrix fans out there...
Offline Pacifist
  • on hiatus
« Reply #108 on: Thu, 08 May 2014, 20:53:53 »
Have you looked at SP's doubleshot PBT before? It has quite some bleed on it
Offline 00zeRO
« Reply #109 on: Thu, 08 May 2014, 21:05:18 »
I think I have a doubleshot ABS Creeper Keycap from Originative, and I think SP made it...no bleeding on that one. I didn't know that SP did PBT Doubleshots, but even if they did I am not interested. I am learning that in order to have better detail, Dye Subs are the way to go.
Are you saying that the Dye-Subs bleed? They sent me samples, I received them today, and the Dye-Subs look very clear and not fuzzy or 'bloody' so I think they will be great for this set.
« Last Edit: Fri, 09 May 2014, 07:26:32 by 00zeRO »
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #110 on: Fri, 09 May 2014, 16:54:01 »
I don't know why I haven't thought about it before. Got to run a Matrix GB. ASAP!
Offline 00zeRO
« Reply #111 on: Fri, 09 May 2014, 17:09:25 »
Did you see the keycaps I designed in the IC? Check them. I know that I will need to modify them a bit to make them Double-Shots but it doesn't look like there is much interest so far...
Offline 00zeRO
