Author Topic: What's your main computer's screen resolution?  (Read 176711 times)
Offline rired48
« Reply #50 on: Tue, 07 April 2009, 09:26:23 »
1600x1200 on a Dell/Phillips 2001FP 20" with a EVGA nVidia GTX280 video card.
"The truth shall set you free. But, not until it is finished with you."
David Foster Wallace
Asus P5B-D (Bios 1237), E8400 @ 3.6ghz
GSkill 4 gig, EVGA GTX280, D-Link DIR-655,
Lian Li A16, Dell 2001FP 20", DAS III Pro, Win XP
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #51 on: Thu, 09 April 2009, 16:15:54 »
1280x1024 on 19". A yet larger screen is of no use to me, since I can barely see all of this at once anyway and keep losing track of the mouse pointer once in a while as-is. (Team 1ft viewing distance and large fonts.) For work, there currently is a 20" with 1600x1200 and font sizes cranked up.
« Last Edit: Tue, 05 May 2009, 04:35:23 by keyb_gr »
Offline ozar
« Reply #52 on: Thu, 09 April 2009, 16:23:27 »
Quote from: BigWopHH;27444
2560x1600 on Dell 3008 30" LCD.
Wow, that's huge!
Just curious... do you have to keep a large distance between you and the monitor to make it usable?  Also, do you notice any distortion or change in color near the outer edges?
Offline huha
« Reply #53 on: Thu, 09 April 2009, 19:57:26 »
1680x1050 on my Thinkpad Z60m (15.4"), which is quite nice for getting some work done, although the panel itself is exceptionally bad in terms of colour reproduction. Plus, it's quite dim.
3360x1050 via two Dell 2007WFP, driven by the Thinkpad when it's docked. Too bad the dock has just one DVI connector; signal degradation on the monitor connected via the analogue connection is noticeable, but usually not bothersome, although I like to use the digitally connected monitor more.
-huha
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
Offline bigpook
« Reply #54 on: Thu, 09 April 2009, 20:35:49 »
1920 x 1080 on a 24" asus. Not so sure if I like the wide screen though.
Offline SUPER432
« Reply #55 on: Wed, 15 April 2009, 17:17:59 »
Quote from: bigpook;84656
I've got mixed feelings also: great for watching movies, though I'm not sure how I feel about the move to wide screens for everything else.
1600x1200 20" Dell 2007FP
1024x768 on the X60s
Offline rnak92a
« Reply #56 on: Thu, 30 April 2009, 00:55:46 »
1920*1200 on a 22" Lenovo ThinkVision L220x
1440*900 on a 14.1" ThinkPad T400 (Samsung LED)
1280*800 on a 12.1" ThinkPad X200T (Samsung, not Hydis, S-PVA LED Tablet).
Cheers,
~rn
P.S.,
AFLAC! :lol:
My keyboards, numpads, and pointing devices
Quote from: Hak Foo
The label says, "World\'s best... guaranteed."
What would happen if I bought one and sent them a nasty letter that read:
"1391401.  I want my money back."
Offline Manyak
« Reply #57 on: Thu, 30 April 2009, 02:17:04 »
My PC has two 24" screens, and will be getting a third next month, each of which does 2304x1440.
So I guess, 6912x1440? :)
Currently Owned:
Filco FKBN104MC/EB - Model M 1390131 \'86 - Model M 1391401 NIB - Unicomp Endurapro NIB - iRocks KR-6230 - Compaq MX-11800 - Cherry G80-8113HRBUS-2 - Cherry ML-4100 - Cherry MY-8000-something - Dell AT101W (Black) - ABS M1 - Siig Minitouch - Chicony KB-5181 w/ SMK Montereys - Chicony KB-5181 w/ SMK Montereys NIB - Cherry G80-3494LYCUS-2 - Deck Legend
Offline Rajagra
« Reply #58 on: Thu, 30 April 2009, 14:14:38 »
Quote from: ktkr;83654
3840x1200 spanning over 2x 24".
And I'm another with that setup. I only just got around to hooking them up that way after having them on my desk for years. Before, they were on one PC each. Now one PC uses the DVI connections, the other uses the D-SUBs.
Now I'm kicking myself for getting Vista on the new PC, it can't span across the screens for gaming.
Offline FKSSR
« Reply #59 on: Thu, 30 April 2009, 15:18:51 »
I like using dual monitors at work, but they have different things on them.  I can't imagine putting the same screen over them.  Doesn't the break in the middle get annoying?
Add me on Steam | Twitter
Offline Manyak
« Reply #60 on: Thu, 30 April 2009, 15:29:15 »
Quote from: FKSSR;88358
That kind of spanning is only useful over an odd number of monitors useful (like 3 or 5), and only with certain applications. Lots of dialog boxes pop up in the center of the 'desktop', and on two monitors those boxes end up broken in half.
On 2 monitors you'd use the regular multi-desktop approach, where maximizing an application just maximizes it over that monitor, and its dialog boxes appear in the center of only that monitor.
Currently Owned:
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #61 on: Sun, 03 May 2009, 16:42:49 »
1920x1200 (24" Eizo LCD)
1024x768 (Samsung CRT)
1024x768 -> PAL (TV)
A Ghost From The Past
Offline eugenius
« Reply #62 on: Fri, 15 May 2009, 05:01:28 »
I had many S-PVA / S-IPS 23-24" monitors, now I'm on a the backup - Belinea P-MVA 1280x1024 19" monitor, and searching for a 30" H-IPS. :)
Cherry ErgoPlus MX5000 + MX5700 / IBM Model M
Offline bhtooefr
    • bhtooefr.org
« Reply #63 on: Sat, 16 May 2009, 15:58:40 »
Looks like my next machine is going to be 2048x1536 with an IDTech IAQX10N 15" IPS panel.
(ThinkPad T60 or T60p with the EEPROM flashed to contain the correct EDID info. This panel (well, the IAQX10S, which is apparently the same thing, just with an IBM part number) was used in a medical imaging configuration of the R50p, and some Chinese guys figured out how to get the panel working in the R60/T60. Apparently works better in a T60/p than it did in a T41p/2p/3p, even.)
Offline pmyshkin
« Reply #64 on: Sun, 17 May 2009, 09:50:12 »
Quote from: lal;83717
Yeah I know, it's already on my todo list.  Can you recommend one that's configurable by GUI?  I don't have time for studying config file syntax ΰ la fvwm for example...
You can take a look at wmii or xmonad. Even though they don't have gui driven configuration, they both work pretty well out of the box.
And anyway, what do you mean by "don't have time?" If you browse geekhack, you have time to figure out simple config syntax.
Offline IBI
« Reply #65 on: Mon, 18 May 2009, 12:25:34 »
Quote from: Rajagra;88350
How do you use 2x 24" screens? I'm considering adding a second 24" to my PC but I'm not sure I'd actually use it.
Owned: Raptor-Gaming K1 (linear MX)(Broken), IBM Model M UK, Dell AT102W, Left-handed keyboard with Type 1 Simplified Alps.
Offline o2dazone
« Reply #66 on: Mon, 18 May 2009, 13:02:22 »
I know you're asking ktkr and Rajagra but I have a single 24" setup at home, and a dual 24" setup at work. The additional real-estate is great, but I only finding myself utilizing all 48" when doing motion graphics and editing in After Effects and Premiere, otherwise, about 70% of the screen stays blank lol. I guess it all depends on your habits though. I'm also used to a "Primary/Auxiliary" monitor layout, where the main monitor is in front of me, and the auxiliary is to the side. With dual 24s I have to put them evenly in the center (or else I end up finding 50% of the aux monitor is too far away lol)
Offline Manyak
« Reply #67 on: Mon, 18 May 2009, 13:30:15 »
Quote from: IBI;91456
Having a second monitor is worth every penny IMO, and if you're a big multitasker you'll slap yourself upside the head for not getting one earlier. But it doesn't really have to be 24", it's just the fact that you have a second screen to put stuff on the side on that's important. Just to give you ideas of what I do with mine:
- If I need to look up info for a report or programming project, I'll have the internet open on the side one with MS Word / visual studio open on the main one. Much easier than constantly alt-tabbing.
- When surfing the net, the second monitor is used for a media player, displaying my music library, watching a movie, and stuff like that
- When setting up stuff on my server, I just use remote desktop and maximize it on the second screen - without really interrupting what I'm doing on the primary one, and switching back and forth becomes as easy as moving the mouse over.
- You can also play video games on the main screen while vent/teamspeak is open on the second one - to see who's talking.
Like I said, it's really nice to have one. But there's no reason to get a big one, or even a good quality one - just as long as it's there. (unless it becomes beneficial to your work or something)
Currently Owned:
Offline Rajagra
« Reply #68 on: Mon, 18 May 2009, 14:15:48 »
Yes, mainly for multiple apps or ones where you can shift menus etc to the 2nd screen like Photoshop or Gimp.
I wouldn't have bought two 24" screens just to do this. But as I have 2 PCs side by side, and the 2 screens can switch between DVI and VGA, it seemed silly not to take advantage of it.
Can anyone else remember putting Hercules and EGA display cards in one PC to get dual screens?
Offline wheel83
« Reply #69 on: Mon, 18 May 2009, 14:50:19 »
i had 1 24" dell and i felt the real estate was too large.  also it didnt run things like ps3 and dvd movies in the proper ratio.  so instead i got an asus 22".  i think i will get another.  it is a great monitor for the money.
I <3 BS
Offline IBI
« Reply #70 on: Tue, 19 May 2009, 07:23:37 »
Quote from: wheel83;91469
Yeah, unfortunately features that should be standard by now like 1:1 mapping and aspects scaling aren't.
@Ripster: Personally I find my 24" too small, it's a bit cramped for two windows side by side and an extra couple of hundred vertical pixels would be nice (say around 2200x1400). A 30" screen might be too big though, I've never tried one.  It is only an extra 7.5cm in height (3 inches) so you could always stick a strip of cardboard to the back of your 24" to raise it's height (or the bottom, if the stand doesn't go all the way down).
Offline ironcoder
« Reply #71 on: Tue, 19 May 2009, 09:06:56 »
I have two 22 inchers and a 20 incher in use right now but that's on 3 separate boxes. I never get enough screen real estate and I finally decided dual-head is the way to go. I would rather have 2x20 than one 22 on the desk. I don't think there's ever a screen big enough. I usually like to have a manual open in dual page mode and that takes a whole screen. And then I have a piece of code open and a program listing open and that takes another whole screen. If not, then you get sick from switching back and forth and waste a lot of time. I remember in the old days we used to avoid this problem by having a dead tree manual on the desk and then  one screen was enough. Damn those online documentation sets. Now everybody needs at least 2 screens to get anything done.
 If I had two screens side by side (dual head) then I could live with less boxes. Of course I won't live with less boxes, but I will probably get more screens!
« Last Edit: Tue, 19 May 2009, 09:09:01 by ironcoder »
In the office: Filco 87 Cherry Browns x 2 (one with coffee damage, recovered) ● Lexmark IBM Model M 52G9658 1993 & 1996
Offline bhtooefr
    • bhtooefr.org
« Reply #72 on: Fri, 28 August 2009, 10:46:02 »
2880x2400 + 2048x1536. :biggrin1:
2048x1536 on the 15.0" internal LCD, 2880x2400 on the external IBM T221 (22.2", although only 18.4" of the display area is being used.) Unfortunately, I can't run the full design 3840x2400 due to a hard limit of my graphics card. :sad:
« Last Edit: Fri, 28 August 2009, 10:49:18 by bhtooefr »
Offline watduzhkstand4
« Reply #73 on: Fri, 28 August 2009, 10:49:27 »
1920x1200 =[ I want to get a CRT and make it huge =D
KEYBOARDS
Cherry Blue *Filco Tenkeyless w/ blank keys* w/ red ESC key thanks to Megarat
Cherry Red Noppoo Choc Mini
IBM Model M 1391401 12/15/88
Siig Minitouch w/ White Alps
SOLD
HHKB Pro 2 white w/ blank keys red ESC key and blank WASD keys
HHKB L-2
Cherry Brown Compaq mx11800
Dell AT101W
Cherry Red Leopold 104-key Otaku FC500RR/ABN
Offline timw4mail
    • https://timshomepage.net
« Reply #74 on: Fri, 28 August 2009, 11:12:38 »
1680x1050 + 1680x1050
So, that's 3360x1050.
Although, I'd really like to get a decent panel for a vertical display.
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline InSanCen
« Reply #75 on: Fri, 28 August 2009, 16:51:06 »
1440*900
Fujitsu Siemens 19"
I still wish to this day I never sold my pair of 22" Lac'ie Electron Blues... Best monitor's ever, even though they doubled up as a space heaters. Oh, and 4092 x 1536@80 Hz (Across both screens).
Currently Using :- IBM M13 1996, Black :
Currently Own :- 1391406 1989 & 1990 : AT Model F 1985 : Boscom 122 (Black) : G80-3000 : G80-1800 (x2) : Wang 724 : G81-8000LPBGB (Card Reader, MY) : Unitek : AT102W : TVS Gold :
Project's :- 122 key 1389620 Wireless ESP32 :
'Pooter :- Xeon E5-2680v4 : Machinist MR9A : 2x16GB DDR4 : Radeon RX6600 : NVME & Spinning rust :
Offline Mr.6502
« Reply #76 on: Fri, 28 August 2009, 19:47:12 »
1280x1024 (19" Sony LCD) + 1600x1200 (22" IBM CRT)
The LCD has great color and refresh rate, and is portable enough to take to a friends house.
The CRT is very useful for design stuff or to weigh down my car's back end in the winter.
"Engineers are really good at labeling and branding things ...  If we had named Kentucky Fried Chicken, it would have been Hot Dead Birds."
-Vint Cerf
Offline kode
« Reply #77 on: Sat, 29 August 2009, 03:00:23 »
I've got two 1680x1050 screens, so 3360x1050. I sorta want to get another GPU and add a monitor or two more to it. That'd be sweet.
Offline lal
« Reply #78 on: Sat, 29 August 2009, 05:43:44 »
While I have a 24" LCD (1920x1200) I actually think about getting a *smaller* one.  Somehow I feel lost with this huge screen and I can work more concentrated at the tiny 12" in my laptop.  Quality of the 12" sucks though, so I end up with all apps overlapping in one corner of the big screen :)
BS: Customizer, Model Ms; Alps: CSK-2101, FK-2002, AT-101 (SGI & Dell), MCK-860, FKBN87Z/EB; Cherry: Poker X, FKBN87MC/EB, WY60, G80-3000, G84-4100, TDV 5010
Offline keyb_gr
  • Cherrified user
« Reply #79 on: Sat, 29 August 2009, 08:05:11 »
Quote from: lal;112845
Maybe you should just place the 24" further away?
That being said, I don't need anything bigger than a 1280x1024 19" either. Just more area for the mouse pointer to get lost in. OK, I'm a special case.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #80 on: Sat, 29 August 2009, 08:14:39 »
My main computer is running in 800x600 on a 14" DEC monitor from 1993. It's still got knobs for adjusting the settings.
Offline lal
« Reply #81 on: Sat, 29 August 2009, 08:29:04 »
Quote from: keyb_gr;112855
It's already as far away as possible.  More distance would either make text too small to read or give ugly results if everything is set to bigger font sizes.  I prefer the crystal clear display quality as it is and live with that slight uncomfortable feeling at times :)
Offline kode
« Reply #82 on: Sat, 29 August 2009, 16:17:37 »
well, I guess you could use just a bit of the monitor...
But really, personally I feel I have a hard time readjusting to smaller monitors for every time I move up a resolution. I'm now at a point where I can fit two terminals/emacsen side by side with both getting the space I feel they need on both monitors. Next time I go up a resolution I expect to be able to put two browser on the same screens without them interfering with each other. That'll be nice.
Offline erricrice
« Reply #83 on: Sat, 29 August 2009, 22:06:10 »
I have a 22" Acer running at 1680x1050.  I want to get a 30" eventually though, but only once I get a good job so I can afford a $1200 monitor....
I\'m selling all my Shizz! Please buy it!
White ALPS: Northgate Omnikey 101-NCS(Real-Complicated)****Filco Zero FKBN87Z/EB(Fukka Simplifieds)****Siig MiniTouch(XM Simplifieds)
Black ALPS: Black Dell AT-101W(Real-Complicated)****ABS M1(Modded Black ALPS, Linear)
Buckling Spring: Model M 1391401(1988 & 1993)
Cherry Blues: DAS III Pro
Cherry Blacks: Cherry G80-11900
Cherry Browns: 3X Cherry G80-8113LRCUS-2
Cherry MY: G81-7000HPBUS-2****G81-3000LANUS-0****Modded to 20g
Rubber Dome: HHKB Lite 2 (White & Black)
Logitech G5[/FONT]
Erricrice\'s Song of the Day: Gorillaz - El Maρana
Yup, Blatantly stealing this from you Kishy, hope you don\'t mind, it\'s a great idea.
Offline Moparx
« Reply #84 on: Sat, 29 August 2009, 22:12:59 »
I have a 22" Westinghouse LCM-22w3 which runs at 1680x1050.
IBM Model M | IBM Model F
Offline datamonger128
  • Location: Newport News, Virginia (Lee Hall neighborhood)
  • Forever alone.
« Reply #85 on: Sun, 30 August 2009, 00:46:11 »
On my home systems, I utilize a 15.6" 16:9 LCD on both my Mac mini and my HP a6600z.  Both of these computers use 1366x768.  On my HP dv6458se, everything is shown in the native 1280x800.
Coffee is supposed to be bitter.  It symbolizes the bitterness of life.
Offline bhtooefr
    • bhtooefr.org
« Reply #86 on: Sun, 30 August 2009, 16:51:10 »
Quote from: kode;112961
I hate that - I've noticed that it takes a while to readjust to ONLY having one monitor, at 2048x1536, when I undock. :laugh:
Offline JBert
« Reply #87 on: Mon, 31 August 2009, 08:07:37 »
1280x1024 + 1920x1200 here.
Both are the native resolutions of my Samsung LCD screens.
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline xyzzy
« Reply #88 on: Mon, 31 August 2009, 15:00:29 »
1440x900 (15" MB Pro, left side)
1920x1200 (24" Dell 2407WFP, center)
1050x1680 (20" Dell 2007WFP, right side, vertical)
.... and I feel like I'd make a good use of a couple more LCDs. Hey bhtooefr, wanna borrow that T221? :lol:
IBM Model F62 (Ellipse's) • PFU HHKB Pro Type S Hybrid • PFU HHKB Pro • Leopold FC660C • IBM Model M SSK 1391472 • IBM Model M SSK UNI04C6 • IBM Model M 1391405 (x4) • Cherry MX 1800 Compact (blue Cherry) • Cherry MX 11900 Touchboard (brown Cherry) • Dell AT102W (black Alps) • Apple Extended Keyboard II (cream Alps) • Acer 6312-TA (black Acer) • Unikey KWD-601 (white Cherry)
Offline Xuan
« Reply #89 on: Thu, 10 September 2009, 00:33:59 »
Home: 1680x1050 (20")
Work: 2x 1280x1024 (19")
Offline Hofy
  • Voids Warranties
« Reply #90 on: Thu, 10 September 2009, 06:14:24 »
1680 x 1050 on a Dell 20" 2007WFP S-ISP panel
Poker II Cherry MX Blue
Filco TenKeyless Zero Fukka
Cherry ML4100
IBM Model M 1391401 Buckle Spring Luvin
Offline ironcoder
« Reply #91 on: Thu, 10 September 2009, 07:06:19 »
I was surprised that 20 and 22 inch LCDs have the same "native" resolution. On a 20 incher 1680x1050 is pretty nice, but I'd like to go higher (and can't with my o/b graphics) on my 22 inchers.
Offline ironcoder
« Reply #92 on: Thu, 10 September 2009, 07:09:40 »
I like having one emacs on the screen split into 2 verticals because it's a more economical use of the real estate. Have you tried that? What I really like is having the source on the left and a compiled listing on the right. Now that's sweet.
Offline ironcoder
« Reply #93 on: Thu, 10 September 2009, 07:10:51 »
Quote from: erricrice;113026
I think after you get to 20 or 22 inches you're better off getting another monitor than going any larger. I guess it depends on what you use your systems for.
Offline bhtooefr
    • bhtooefr.org
« Reply #94 on: Thu, 10 September 2009, 07:35:36 »
Not all 22" monitors are 1680x1050. ;)
(And I'm not even referring to the occasional 1920x1200 one you find out there. I'm referring to 3840x2400. ;))
Offline kode
« Reply #95 on: Thu, 10 September 2009, 09:00:44 »
Quote from: ironcoder;116542
Yeah, that's what I usually do.
Offline ironcoder
« Reply #96 on: Thu, 10 September 2009, 09:15:27 »
Quote from: bhtooefr;116548
Woot woot woot for you! Is that a CRT or are you running a slew of FXs in GLI?
Offline D-EJ915
« Reply #97 on: Thu, 10 September 2009, 10:13:53 »
IBM T220/221 is the 3840x2400 22.1" lcd
I got a laptop the other day which is 1024x768 and is 6.4" diagonal.  1024²+768²=1280² so 1280 / 6.4 = 200 pixels per inch so it has slightly less density as the IBM one which is insane, stuff is small enough as is on this thing XD I can't really imagine it being any smaller even if just slightly so lol.
http://project777.darktech.org:777/gallery2/v/pcg-u3/IMG_4984.JPG.html
« Last Edit: Thu, 10 September 2009, 10:20:21 by D-EJ915 »
Offline ironcoder
« Reply #98 on: Thu, 10 September 2009, 10:22:32 »
Yeah I guess the two sides are the size of the display and how much you can get on it AND still see what you are looking at.
I don't have any use for tiny tiny characters on small screens but a big screen where I could fit enough stuff on it and still see it all clearly, that would be nice.
Edit: wow, that's a really sweet little machine you got yourself there, hardware king! I notice you wind up with a lot of cool stuff. I loved that other shot of your server rack. I would like to get something like an X300 with enough RAM and an SSD and enough horsepower to do some serious work but they're too damn expensive for it to be worth me importing one now. I don't want anything too small because you can't type well enough on it and I'm too damn old to be able to see tiny characters.
So many toys, so little time.
« Last Edit: Thu, 10 September 2009, 10:26:21 by ironcoder »
Offline bhtooefr
    • bhtooefr.org
« Reply #99 on: Thu, 10 September 2009, 23:04:13 »
Quote from: D-EJ915;116596
And mine's a DG5, the best version. :)
Nice, although the Crusoe must not be fun. I think the modern day equivalent would be the Fujitsu U820, with a 1.6 GHz Atom, and a 1280x800 5.6" display.
