Author Topic: Plastic keyboard covers.  (Read 27712 times)
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Plastic keyboard covers.
« Reply #50 on: Sun, 28 May 2017, 13:42:55 »
What is happening right now? Is it happening? This thread needs more cardboard and less silicone. C'mon
Offline leech
  • …always on the lookout for higher quality…
« Reply #51 on: Sun, 29 October 2017, 07:22:29 »
That is 49.4cm x 21.5cm x 6.6cm. Not an annoyingly big cover but definitely not to be called compact either
Turns out that the cover sits perfectly on top of my new IBM Model M (49.0cm x 21.0cm x 4.5cm), basically covering the entire top face —including the top face edges— of the keeb and protecting it against dust and light:
The matching dimensions are absolute coincidence. Perfect width, left side:
Same perfect width on the right side, of course. Funny how in the pic the cover looks like having a prismatic geometry:
Perfect length, too. Really, what a coincidence. Also, as you can tell, in the afternoon sun rays would hit the board:
My copy is a most recent manufactured blue label unit 6127, made 1999 in the UK by IBM UK (not Lexmark UK or Lexmark USA), and it does not suffer from the warped upper case half problem which resulted in a visible black gap on Rhinofeed's expensively refurbished unit and on Modern Classic's 2017 unit:
As we could see, the cover does not cover the four side faces of the keeb but leaves them still exposed to sun light, dust and splashes of milk from muesli. Oh well. A hard plastic cover covering the entire keeb by sitting on the desktop would be humongous for the IBM Model M and probably fill the entire desk space, no thanks anyway!
If anyone's wondering, my unit has a German ISO layout and its space bar does not produce any rattling sound during typing (e.g. during type-racing or normal typing), not even the faintest:
While taking the above photos of my new (and first Model M ever!) keeb, i noticed select spots which were slightly dirty. So now i am off to cleaning the spots with ethanol and vinegar-based cleaner. Last night i ordered a 5.5mm nut driver from Aliexpress for 1.44US$ and i will be posting more about my unit in some other thread.
I believe i got a very lucky deal on this unit…  :-*
Offline leech
« Reply #52 on: Thu, 07 March 2019, 06:15:30 »
Status update:
I have replaced all my previous keyboard covers with THE SORA COVER (thanks for checking my review :thumb:).
Offline Aelon
« Reply #53 on: Thu, 07 March 2019, 09:13:16 »
Just wanted to mention that Razer Huntsman and Razer Hunstman Elite keyboards also come with their own clear plastic keyboard covers. And I think it would fit many other brands of keyboards with similar shape and size. Another nice accessory to play with for keyboard enthusiasts...
Reminds me the 80's and 90's where mainly IBM computers with Model M keyboards in the offices had these kinds of covers in order to protect them and to prevent dust buildup. Besides they look neat and tidy. They were either hard clear plastic covers or soft plastic "sheet" type covers...
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #54 on: Thu, 07 March 2019, 09:57:27 »
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline ideus
  • Björkö.
« Reply #55 on: Thu, 07 March 2019, 10:31:04 »
I really prefer the see the board naked. Ocasionally mop the dust off and that's it. There is not really a need for a cover, unless you are paranoic about some dirt over your keyboard. If you live in a high humidity place you'd better do not do it, it may be a perfect vapor chamber for the board.
Offline zslane
« Reply #56 on: Thu, 07 March 2019, 12:24:57 »
That Orange acrylic case look sweet. Sadly, they don't seem to make a full-size version.  :(
