Author Topic: Help troubleshooting malfunctioning Northgate Omnikey  (Read 1422 times)
Offline intelli78
« on: Sat, 29 March 2014, 08:03:29 »
I have a Northgate Omnikey like this (http://media.engadget.com/img/product/11/8i4/northgate-computers-omnikey-102-hsv.jpg).
It is functional except for the following keys, which do not work:
F3, F9, Tab, q, w, e, r, u, o, a,s, d, j, k, l, semicolon, x, c, m, Lalt, space, left arrow, down arrow, right arrow.
Some info:
- I have cleaned all of the switches recently; none seem damaged or worn out.
- If I disassemble a working switch and press the leaf against the contact with a screwdriver or Qtip, the key registers. For dead keys, this is NOT the case, so I do not think the problem is in the switch internals. Thinking it's the PCB or a chip, but I'm really not sure.
-  The keyboard was working in the past, but got exposed to some gnarly Arizona heat; this could maybe have something to do with it. I don't know.
- The dead keys seem to be in clusters for the most part. Coincidence? you tell me.
Anyone more knowledgeable about electronics able to speculate on what's happening with this board?  :( I can do basic multimeter / soldering work but I don't have the knowledge to figure this out myself.
« Last Edit: Sat, 29 March 2014, 08:05:30 by intelli78 »
Offline jabar
Re: Help troubleshooting malfunctioning Northgate Omnikey
« Reply #1 on: Sat, 29 March 2014, 08:46:23 »
Well have you tested connections with the multi?
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline intelli78
« Reply #2 on: Thu, 03 April 2014, 03:18:09 »
I performed the most basic level of troubleshooting -- testing continuity of the switches -- and found that all of these had simply gone bad. I opened a few and there was corrosion in the ALPS "gold sandwich." So, the problem was less serious than I had suspected. I have a blue ALPS donor board on the way and will solder in some replacements.
