Author Topic: Does anyone know if the pcb on the Keycool 84 White has holes for LEDs?  (Read 5125 times)
Offline victor.m
Hey guys! Been a long time lurker but this is my first time posting!
Anyhow, I currently own a Keycool 84, and love it! It's the black LED backlit version, and I seriously enjoy everything about it. Just working on some custom keycaps.
I was wondering if anyone has the white version of the Keycool 84, with the PBT keycaps, and do you know if the PCB is the same as the fully backlit one? I figure it might be, since it would be easier to just produce one PCB, and the white one has some LEDs on certain keys. If anyone has one and could look to see if the PCB has the holes/headers for LEDs on every key, that would be awesome!
Offline Pacifist
  • on hiatus
Re: Does anyone know if the pcb on the Keycool 84 White has holes for LEDs?
« Reply #1 on: Sun, 30 March 2014, 11:44:35 »
NOPE :'(
« Reply #2 on: Sun, 30 March 2014, 12:29:55 »
Mine seems to have extra holes, not sure what for.
Offline berserkfan
« Reply #3 on: Sun, 30 March 2014, 14:16:53 »
you really have been dissembling lots of keyboards, SpamRay. Am surprised your wallet isn't hurting yet!
« Reply #4 on: Sun, 30 March 2014, 14:20:00 »
The worst part of this one is I messed up the stickers looking for screws which are not there.
Offline victor.m
« Reply #5 on: Sun, 30 March 2014, 15:48:43 »
Thanks a ton guys! Looks like it has some holes, but not the dedicated holes for the LEDs to be wired into the board. A true shame, a backlit white version would be awesome!
« Reply #6 on: Sun, 30 March 2014, 16:05:47 »
Spamray's has LED holes. though you will have to also solder in resistors. You can tell from his picture that the LED holes are wired up (the ones on the poker 1 by comparison are not wired)
They usually cover the plastic drop location with a large sticker, you will get better at finding it.
« Reply #7 on: Sun, 30 March 2014, 21:39:55 »
I mean my keycool84 has no screws at all....so I messed the stickers up for nothing! :D
Offline RESPRiT
  • HHKB = ❤
« Reply #8 on: Sun, 30 March 2014, 21:47:28 »
Those tamper stickers are premium grade stuff Spam, you're really missing out without them :P
Offline Pacifist
  • on hiatus
« Reply #9 on: Sun, 30 March 2014, 22:03:15 »
Its not a tamper sticker
its the birth certificate
Offline Pacifist
  • on hiatus
« Reply #10 on: Sun, 30 March 2014, 22:04:36 »
Could those be diodes? My KC84 didn't have LED holes
edit: my pcb was way different
http://geekhack.org/index.php?topic=47118.msg1170290#msg1170290
« Last Edit: Sun, 30 March 2014, 22:06:45 by Pacifist »
Offline victor.m
« Reply #11 on: Mon, 31 March 2014, 02:33:39 »
Hmmm..so it's still up in the air, then? Some PCBs might have holes, while others may not? I might just pull the trigger on a white one and find out. Worst case scenario, I have an extra sweet white PBT keyboard.
« Reply #12 on: Mon, 31 March 2014, 06:39:35 »
59240-0
59242-1
A couple more PCB shots.  8)
Offline Pacifist
  • on hiatus
« Reply #13 on: Sat, 12 April 2014, 01:08:09 »
Update:
Opened up my new KC84, same as before. No holes for LEDs
With the old version (Green box) and the new version (brown box) both PCBs are the same.
Also, don't know why, but my PCBs seem a lighter shade of red than spamray's
nother thing to note, my switches are soldered the right way, while spamray's pcb is designed to have the switches upsidedown (a trend that a lot of led boards are doing)
But it looks like spamray's pcb will allow LEDs no problem. Just need to SMD solder resistors (pads are already there)
ANOTHER thing: my keycool logo is made in traces while spamray's is silkscreened
« Last Edit: Sat, 12 April 2014, 01:10:29 by Pacifist »
« Reply #14 on: Sat, 12 April 2014, 07:48:17 »
Update:
is yours dated? model number on PCB? mine came from banggood  :-X
Offline YuukiHaruto
« Reply #15 on: Sat, 12 April 2014, 13:12:29 »
Update:
I'm pretty sure it doesn't matter where it came from since banggood is a dropshipper anyway  :D
Offline Pacifist
  • on hiatus
« Reply #16 on: Sat, 12 April 2014, 13:17:54 »
both banggood
6-15-13 is the date
Offline Pacifist
  • on hiatus
« Reply #17 on: Sat, 12 April 2014, 13:22:12 »
So I guess this is how it went:
kc is chinese company, so they want to cut costs (best example is my current board passed QC but the ' key has a cold joint or something....
spamrays is made in 2012. They designed 1 pcb for both the LED and non LED versions
in 2013 they made mine. Revised PCB, different one for led and non led
also for the silksceen/traced keycool name and date, the middle line is almost the same except mine says vo1 while spams is vo2....
« Last Edit: Sat, 12 April 2014, 13:24:01 by Pacifist »
