Author Topic: Where to buy Filco Majestouch 2  (Read 5271 times)
Offline motoyuki
« on: Tue, 01 April 2014, 11:57:11 »
Hi GH,
I'm thinking about purchasing a Filco Majestouch 2 TKL with mx blue, but I'm not sure where the best place to buy it would be. Do you guys have any recommendations? the cheapest I can find is amazon, but it will cost $170. Thanks in advance.
Offline isaske
  • Stop whining!
Re: Where to buy Filco Majestouch 2
« Reply #1 on: Tue, 01 April 2014, 12:03:42 »
HOW DO I COMPUTER?
Offline lightsout714
« Reply #2 on: Tue, 01 April 2014, 12:06:17 »
Hi GH,
What country are you in.
Offline PolaBurrr
« Reply #3 on: Tue, 01 April 2014, 12:14:37 »
wait a bit for amazon. They usually get stock in from keyboardco that qualifies for amazon prime and price around 140. That is your best bet if you are in the states. Otherwise, you will have to import from Japan or order from UK, which will cost a lot more than it should.
Offline motoyuki
« Reply #4 on: Tue, 01 April 2014, 12:44:46 »
I'm in the US. Thanks for the link and tips guys. I'll definitely wait on amazon to get a stock in. I'm in no hurry =)
Offline PolaBurrr
« Reply #5 on: Tue, 01 April 2014, 17:50:24 »
yeah, do that. Buying overseas would be more expensive than it needs to be.
Offline intelli78
« Reply #6 on: Tue, 01 April 2014, 17:59:50 »
Check NCIX.ca
Offline TBone
« Reply #7 on: Tue, 01 April 2014, 23:42:00 »
I hope I don't miss it when they drop down in price, someone should post on here when there is a good price  ;)
Offline boradori007
  • I'm trippin bear balls.
« Reply #8 on: Wed, 02 April 2014, 00:04:54 »
try amazon
Offline Mooby
  • Funployee
« Reply #9 on: Wed, 02 April 2014, 09:42:03 »
Keyboardco on Amazon.com has really good prices.
If you'd buy the same Keyboard in Europe directly from their Onlinestore you'd pay around 50$ more than from Amazon.com. And this doesn't even include shipping. I mean I got used to the fact that everything is more expensive here, but this is kind of stupid.
Offline IPT
  • Formerly projectD
« Reply #10 on: Wed, 02 April 2014, 14:53:50 »
does their direct price include VAT in the pricing?
No VAT in the USA.
Offline Mooby
  • Funployee
« Reply #11 on: Wed, 02 April 2014, 15:28:48 »
No VAT in the USA.
You're right I didn't consider that.
They have an option to show the VAT. If you take the prices without VAT and add the shipping costs it still quite a difference compared to amazon. Not to forget amazon's selling fee.
