Author Topic: Poker II Questions  (Read 4243 times)
Offline Jalberstone
Poker II Questions
« on: Wed, 02 April 2014, 02:53:10 »
I think I'm going to buy a Poker II with Cherry MX Black switches from qtan for about $106. Is this a good idea? I think I read somewhere that I could get a discount if I message him on GH. Is that true? Also, is there somewhere that I would be able to buy an aluminum case for it? (preferably in grey, but I would like to see other colors too) I will mainly be typing on this keyboard and I am wondering if blacks will be too heavy. I am used to typing on greens and clears which I believe are supposed to be heavier than blacks, so should I be fine typing on blacks? And will all the volume controls and the arrows keys on WASD work on a mac? Thanks!
Offline mougrim
Re: Poker II Questions
« Reply #1 on: Wed, 02 April 2014, 04:23:17 »
I think it will be a good idea to message Qtan on GH.
Also, you can sometimes find metal cases for Poker II in classifieds. Don't know about colours, though.
Oh, and after greens blacks are not heavy at all.
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Offline Razor Lotus
« Reply #2 on: Wed, 02 April 2014, 08:04:25 »
I think blacks will be fine for you.
Not sure if you will get a discount if you message him but if you do.. I'll be sad since i bought off him but didn't get any discount :( But you can try!
Yup, $106 is a reasonable price for a poker 2 keyboard.
If you're looking for an aluminium case, pexon still has some $60 cases left i think. Hurry go send him an Email.
Here's the link: http://geekhack.org/index.php?topic=47776.0
Offline HPE1000
  • Keycap Paparazzo
« Reply #3 on: Wed, 02 April 2014, 08:06:02 »
I think you are thinking of feng as far as messaging to get a discount.
Offline saltdiscus
« Reply #4 on: Wed, 02 April 2014, 09:45:57 »
yeah let us know if u got thr discount.I am also thinking of getting poker 2.
duckyshine3/looking for poker,mx keycaps
Offline ideus
  • Björkö.
« Reply #5 on: Wed, 02 April 2014, 09:49:07 »
QTan also has an aluminun case available at his site. And he will add a couple other designs soon. So maybe you want to wait for the cases to be in stock to buy the item toghether.
Offline Jalberstone
« Reply #6 on: Wed, 02 April 2014, 13:08:09 »
How easy would it be to change the switches out on a Poker II?
Offline ideus
  • Björkö.
« Reply #7 on: Wed, 02 April 2014, 13:10:35 »
They are plate mounted, thus, they are as hard / easy to pull out as any other plate mounted keyboard.
« Reply #8 on: Wed, 02 April 2014, 13:19:11 »
For the stock plate you will have to desolder and resolder to remove/replace switches.
Offline Jalberstone
« Reply #9 on: Wed, 02 April 2014, 13:21:17 »
Does anyone know if the volume/media controls and arrow keys on WASD work on a mac?
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #10 on: Wed, 02 April 2014, 13:21:52 »
They do.
Offline ideus
  • Björkö.
« Reply #11 on: Wed, 02 April 2014, 13:26:28 »
Is there a stock board that has a plate that does not require that?
Offline Jalberstone
« Reply #12 on: Wed, 02 April 2014, 13:28:15 »
Should I maybe try to find a Poker X just for the ability to easily swap out switches? I do not know if I would want to do something like that, but what are the other benefits of a Poker II over a Poker X?
  • Cherry Peasant
  • keycult.com
« Reply #13 on: Wed, 02 April 2014, 13:30:07 »
The primary benefit is that the Poker II has a programmable function layer while the Poker X does not.
Offline ideus
  • Björkö.
« Reply #14 on: Wed, 02 April 2014, 13:31:43 »
The plate itself is an advantage. The slots for leds are also an added bonus in the Poker II.
Offline Jalberstone
« Reply #15 on: Wed, 02 April 2014, 13:57:15 »
What makes the plate an advantage?
Offline ideus
  • Björkö.
« Reply #16 on: Wed, 02 April 2014, 14:00:32 »
Rigidity of the assembly. The Poker X flexes. I have one Poker X and I was in need to add some support under the PCB because it tends to flex and the feeling when typing is awkward. Maybe that is not a concern for you though. Just check GH and you will find a lot of GB for 60% plates because of this and some other 60 models that had no plate in their stocks versions.
Offline mougrim
« Reply #17 on: Wed, 02 April 2014, 15:07:50 »
Yeah, plate-mounted board are the best. It sturdy feeling when you're typing on one... incomparable with the PCB-mounted ones.
  • Cherry Peasant
  • keycult.com
« Reply #18 on: Wed, 02 April 2014, 15:09:12 »
For what it's worth, many people prefer PCB mount to plate mount, the idea being that the flex of the PCB makes bottoming out softer.
Offline ideus
  • Björkö.
« Reply #19 on: Wed, 02 April 2014, 15:11:57 »
I used the Poker X with no support for a year. I may say that the sound was not different at all after I installed a sound dampener under the PCB, but the firmer feeling with it was much better, than with out it.
Offline Jalberstone
« Reply #20 on: Wed, 02 April 2014, 15:34:54 »
It turns out that qtan is out of stock of a Poker II with Cherry MX Blacks. Does anyone know where I can get one?
Offline Jalberstone
« Reply #21 on: Wed, 02 April 2014, 18:24:03 »
I found another one here: http://www.banggood.com/KBC-Poker-2-Mini-Mechanical-Gaming-Keyboard-Cherry-MX-Black-Switch-p-85373.html
Does anyone know if this is a reliable place to buy from?
Offline ideus
  • Björkö.
« Reply #22 on: Wed, 02 April 2014, 18:28:47 »
Cannot comment on its realiability, I bought a cheap set of blank caps and everything was OK, but that's it.
Offline Pacifist
  • on hiatus
« Reply #23 on: Wed, 02 April 2014, 18:31:49 »
bg is slow but reliable
Offline saltdiscus
« Reply #24 on: Wed, 02 April 2014, 18:36:46 »
difference between pure poker and poker 2?
Offline ideus
  • Björkö.
« Reply #25 on: Wed, 02 April 2014, 18:42:30 »
The KBT Pure pro is the current model. It has dedicated arrows, and many non standard ANSI keys. It is also programmable, and it has a plate.
Offline mougrim
« Reply #26 on: Thu, 03 April 2014, 05:08:07 »
Got today my white Poker II with MX Blues from them. Works OK. Ordered on 12 of March, so it was roughly 3 weeks.
Offline Razor Lotus
« Reply #27 on: Thu, 03 April 2014, 08:50:20 »
And awesome PBT keycaps
Offline mougrim
« Reply #28 on: Thu, 03 April 2014, 09:09:43 »
Thick and sturdy, yes. And doubleshot RGB mod in box :)
Offline ideus
  • Björkö.
« Reply #29 on: Thu, 03 April 2014, 09:12:28 »
It may be said, that either the Poker X or the Poker II are pretty similar as keyboards. However you should consider Poker X is easier to cutomized with different switches, but it is not programable. The Poker II has a plate, so if you want to customize it, it would be a little harder, but it is programable.
