Author Topic: Quickfire XT Replacement Case  (Read 48540 times)
Offline MsYutai
« on: Wed, 02 April 2014, 15:06:49 »
Hi there,
I've always been a huge proponent of the QFR not only because it is a high-quality and affordable board but also because the board is easily customizable.
One of the main things making the board so customizable is the replacement case. The standard keycap layout also allows for easy replacement.
The QFR replacement case looks nice by itself of course, but it really becomes something special with a couple coats of spray-paint!
However, not everyone likes a TKL board (I fall into this category)!
I would really like to see a replacement top case for the QF XT-- the rubber on mine has worn off a bit near the arrow key area-- it looks kinda grey and washed out. If I were able to buy a replacement case, I could go spray-paint crazy without fear!
Thanks for reading!
TLDR: Replacement top case for QF XT please!
CM Storm Quickfire XT - MX Reds
Roccat Kone Pure Optical|Kana v2|Zowie FK|Logitech g500s|Mionix Naos 7000|CM Spawn|Logitech Performance MX
