Author Topic: Poker II Caps Lock  (Read 2903 times)
Offline ynrozturk
Poker II Caps Lock
« on: Thu, 03 April 2014, 07:14:53 »
Probably a very simple question but I couldn't solve it.
The Caps Lock on my Poker II has stopped working for some reason. I've done a factory reset to no avail, and all of the DIP switches are set to their default OFF positions.
Any ideas?
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
  • Live long and prosper
Re: Poker II Caps Lock
« Reply #1 on: Thu, 03 April 2014, 07:17:23 »
Did just the LED stop working, or the switch itself?
tp thread is tp thread
Offline ynrozturk
« Reply #2 on: Thu, 03 April 2014, 07:39:43 »
Sorry, should have specified.
The switch itself stopped working. To give some more info, I changed the space bar on my keyboard today, and before that it was working perfectly fine. So I probably messed up with a Space+FN combination but I have no idea what, and I know my way around my Poker fairly well, when it comes to layers and programming keys and all that. And I can't find anything in the user manual either, which is a bit odd.
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #3 on: Thu, 03 April 2014, 08:09:40 »
Can you use a keyboard event viewer to see if any key codes are being sent at all?
Offline mougrim
« Reply #4 on: Thu, 03 April 2014, 08:12:47 »
It was powered down when you've changed Space or not?
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Offline ynrozturk
« Reply #5 on: Thu, 03 April 2014, 08:18:23 »
It seems to be registering as Ctrl.
« Reply #6 on: Thu, 03 April 2014, 08:19:52 »
I thought that's what was happening, wasn't sure though...
Recheck your DIP switches, etc. One of them might not be functioning properly.
Offline ynrozturk
« Reply #7 on: Thu, 03 April 2014, 08:20:47 »
Will do, thanks guys.
Offline mougrim
« Reply #8 on: Thu, 03 April 2014, 08:21:28 »
Hmm... if I remeber correctly, 1 DIP have something to do with CapsLock swapping.
  • Cherry Peasant
  • keycult.com
Poker II Caps Lock
« Reply #9 on: Thu, 03 April 2014, 08:23:02 »
Yep, I believe you're right. OP is in luck though: this is a much better layout! Caps Lock is for casuals.
Edit: before the jimmies rustle, I'm joking.
Offline ynrozturk
« Reply #10 on: Thu, 03 April 2014, 08:27:28 »
To be honest I don't care about Caps Lock, I never use the thing. I was just curious as to what went wrong.
Offline ynrozturk
« Reply #11 on: Thu, 03 April 2014, 08:33:08 »
Very strange, I can't seem to correct it with the DIP switches, either.
dafuq
« Reply #12 on: Thu, 03 April 2014, 08:37:29 »
dafuq
Dafuq indeed...
Do any of the other DIPs seem to be working properly? Or not-properly, for that matter...
Offline ynrozturk
« Reply #13 on: Thu, 03 April 2014, 08:39:38 »
That's the strange thing. DIP's 2, 3 and 4 seem to be working fine, just DIP one seems to be problematic.
Maybe doing the firmware update would help? Though I can't see how, if it's something physical.
Offline GreeDyloO
« Reply #14 on: Thu, 03 April 2014, 08:40:00 »
Hey there, does the Poker II have a fn + w layer like the pure pro ?
The problem might come from here :)
« Reply #15 on: Thu, 03 April 2014, 08:41:19 »
Couldn't hurt at this point. If anything, update it just to eliminate firmware as a possible cause.
Offline ynrozturk
« Reply #16 on: Thu, 03 April 2014, 08:42:08 »
Thanks for the post, though FN+W on the Poker II is simply just the up arrow.
Offline ynrozturk
« Reply #17 on: Thu, 03 April 2014, 08:42:38 »
Yup, I will do that when I get home from work. Feel better working on my on hardware.
