Author Topic: Stabs Question :)  (Read 2069 times)
Offline Harms
Stabs Question :)
« on: Fri, 04 April 2014, 00:36:28 »
Hi everyone, how hard is it to remove keycaps from costar stabs vs cherry stabs? I'm afraid of buying a KB with costar stabs; that its going to be hard to remove the keycaps and I might break something. I'm asking this because I'm going to install o rings in all of the keys.
Speaking of o rings, why cant you put them onto the switch stem instead of the keycap? Lastly whats better a normal plastic keycap puller or a wired keycap puller? Thank you everyone for all the help :D.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
Re: Stabs Question :)
« Reply #1 on: Fri, 04 April 2014, 00:38:49 »
Removing costar caps isn't bad just a slightly different process.
Orings won't fit on the stem plus the cap bottoms on the stem cruciform and it would also prevent the switch from activating.
Wire cap pullers are far superior to plastic ones.  Plastic pullers have been known to scratch caps especially coated back light friendly caps.
« Reply #2 on: Fri, 04 April 2014, 00:39:00 »
Not harder, just a bit more fiddly.
From Costar you have only the centre stem fixed to the switch, with Cherry all three stems have to be removed at once.
But, having removed the keycap, with Costar you then have to extract the stabiliser thingies from under the keycap, whereas with Cherry you do not.
Installation is the reversal of removal process, with the fiddly bit of Costar having to hook the ends of the stabiliser bar through the clips under the keycap.
Offline Melvang
« Reply #3 on: Fri, 04 April 2014, 00:39:49 »
inb4 rowdy hehe
« Reply #4 on: Fri, 04 April 2014, 01:07:41 »
inb4 rowdy hehe
I covered the installation process too :p
Offline mougrim
« Reply #5 on: Fri, 04 April 2014, 03:09:21 »
I found Cherry stabs more smooth... and in general they've more pleasant feeling.
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Offline ynrozturk
« Reply #6 on: Fri, 04 April 2014, 06:47:27 »
Same, I prefer Cherry stabilizers.
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
« Reply #7 on: Sat, 05 April 2014, 00:07:35 »
I find Cherry stabs a bit stiffer than Costar, that is when using the same keycaps on several keyboards.
OTOH Costar stabs are more forgiving of slightly deformed modifier keys, especially the longer ones.
Offline Melvang
« Reply #8 on: Sat, 05 April 2014, 00:10:26 »
I would have to agree with the second statement here.  Just by the design of the Costar stab they are much more forgiving with length discrepancies and bent caps (I'm lookin at you Mr. PBT Spacebar) than Cherry.  The only stabs I don't like the feel of is non-clipped Cherry.  Anything else is fine by me.
