Author Topic: Replacement FC660C feet / aftermarket rubber pads  (Read 1947 times)
Offline intelli78
« on: Sat, 05 April 2014, 14:22:11 »
One of the rubber feet on my FC660C popped off and is lost. Is there a source of original replacement parts? I have emailed EK, waiting for a response.
if not, has anybody found a good self-adhesive rubber pad product that can be used to upgrade/replace KB feet? I have several keyboards, in fact, that could use an upgrade, but it has been surprisingly hard to find a plain square, flat, self-adhesive pad. Most of the options I've found, like self-adhesive rubber feet, are too thick.
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
Re: Replacement FC660C feet / aftermarket rubber pads
« Reply #1 on: Sat, 05 April 2014, 14:27:45 »
I have been using these on the bottom of my JD40 and HHKB for a fair while now, and they've worked great. I imagine there's a chance of them falling off eventually, but so many come in a pack that I can easily replace them.
Offline intelli78
« Reply #2 on: Tue, 08 April 2014, 04:11:50 »
Thanks for the reply. Those are reasonable but not so bueno in conjunction with my line of carrying cases.
I ordered some flat adhesive rubber pads from a site called AllElectronics. They look promising for a lower profile solution.  Will update when I try them.
