Author Topic: Clicking cherry stabilizers, really loud. Help!  (Read 3972 times)
Offline masher997
« on: Sat, 05 April 2014, 16:25:48 »
I have a corsair k70 and the stabilizer on the right is making a loud clicking noise while the one on the left is fine. Has anybody else had this problem? and if so how did you fix it? It is to loud for me and I cant stand it at all. Btw switches are cherry MX browns and the stabilizers are cherry's.
here is a video of it
feature=youtu.be
Offline thesentinel
Re: Clicking cherry stabilizers, really loud. Help!
« Reply #1 on: Sat, 05 April 2014, 17:28:14 »
I have the exact same problem and it's annoying the hell out of my on my QFR reds.
EDIT: oops, how'd that show up there?
Keyboards are the only thing keeping me from consuming human flesh.
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #2 on: Sat, 05 April 2014, 17:30:37 »
You can fix this by lubing the stabilizers. Ripster has a guide here. I use this stuff or Krytox GPL 205 grease mixed with a small amount of Krytox GPL 103 oil, probably a 70/30 or 80/20 mix.
Offline masher997
« Reply #3 on: Sat, 05 April 2014, 17:39:11 »
Yeah it is really annoying. I thought that lube would only work for squeaking keys but ill try it  thanks!
