Author Topic: Question about cleaning keycaps  (Read 10266 times)
Offline SSIPAK
  • ★ Bootlegcaps ★
« on: Sat, 05 April 2014, 17:56:06 »
Is it safe to use disinfecting wipes like this one
to clean my keyboard/keycaps or will this damage it some how?
Offline Candyflip
Re: Question about cleaning keycaps
« Reply #1 on: Sat, 05 April 2014, 18:05:23 »
I believe this won't damage your keycaps but I would suggest using couple of denture cleaning tabs, easier and faster.
Offline SSIPAK
  • ★ Bootlegcaps ★
« Reply #2 on: Sat, 05 April 2014, 18:28:31 »
so use one tablet inside a bowl and put my keycaps in there?
Offline Candyflip
« Reply #3 on: Sat, 05 April 2014, 18:50:56 »
yea pretty much that, you can use maybe couple of tablets with warm water. Be careful not to use with too hot water as the plastic may warp, keep it below 60C.
Offline SSIPAK
  • ★ Bootlegcaps ★
« Reply #4 on: Sat, 05 April 2014, 19:19:43 »
Got it, I will definitely try this out. Thanks  :thumb:
« Reply #5 on: Sun, 06 April 2014, 00:50:01 »
And of course make sure that they are totally dry before you put them back on.
I usually spread mine out on newspaper and leave them to dry for a week (generally I only have to do this sort of thing on weekends).
Offline intelli78
« Reply #6 on: Sun, 06 April 2014, 02:07:04 »
Yes, the denture tabs are amazingly effective. Use 2-3 tabs depending on dirt level, hot tap water, and shake them around in a container a few times while they're sitting. 30 mins later, they'll be spic'n span.
Offline SSIPAK
  • ★ Bootlegcaps ★
« Reply #7 on: Sun, 06 April 2014, 02:17:56 »
so no need to scrub them at all?
« Reply #8 on: Sun, 06 April 2014, 02:23:12 »
I use the yellow one on things like mouses, cables, etc. for caps I use denture tabs, spearmint smell nice. I put 2 in a water bottle with warm water and the caps, shake it for 2 mins. Let them dry in the sun spread out over a towel. Clean and nice. Then I dry inside overnight too.
Offline Candyflip
« Reply #9 on: Sun, 06 April 2014, 02:27:10 »
That might be a bit paranoid, letting them dry for a couple of days will be more than fine.
Offline intelli78
« Reply #10 on: Sun, 06 April 2014, 02:28:07 »
I have used denture tabs on some seriously nasty keycaps, and I never had to scrub them. I just shake the container a little bit and let them soak. It really works.
« Reply #11 on: Sun, 06 April 2014, 02:30:02 »
not really. They fizz up a little which helps the clean.
Some keycaps, especially those with deeply engraved legends, you will have to scrub with a disinfecting wipe, but for most keycaps you won't need to.
I actually need to pick up more denture tabs to clean some more of my hall effect keyboards that are still dirty.
« Reply #12 on: Sun, 06 April 2014, 02:43:38 »
I generally only get the chance to do this on weekends.  So remove keycaps and clean one weekend, leave to dry for the week, replace keycaps the next weekend.
Offline mougrim
« Reply #13 on: Sun, 06 April 2014, 11:41:57 »
Isn't drying them for a week seems... excessive to you?
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Offline Candyflip
« Reply #14 on: Sun, 06 April 2014, 12:04:10 »
I actually agree with him, better be safe than sorry + it fits his schedule
« Reply #15 on: Sun, 06 April 2014, 12:37:33 »
I drop them out of the basket onto a T-shirt.
Then I pick up each key individually, give it a quick shake, and toss it aside. After shaking out the excess water, keys are fully dry in 10-20 minutes.
- D Trump 2026-10-24
Offline mougrim
« Reply #16 on: Sun, 06 April 2014, 13:28:47 »
Exactly. In an hour - tops.
Offline intelli78
« Reply #17 on: Sun, 06 April 2014, 13:42:46 »
This works OK for Alps and Cherry caps, but be careful of buckling springs. Tons of crevices in those guys; I have let them dry for many hours in dry AZ after slinging out the water, yet a blast of compressed air will still find more droplets inside.
One trick I have used to speed drying is to put keycaps in a pillowcase, tie it off,  and throw it in dryer with a few towels so the bundle isn't constantly smashing against the metal walls of the dryer. 30-45 minutes will usually dry them out. Of course, do this at your own risk. If you're not in a rush, air drying is probably safest.
Offline mougrim
« Reply #18 on: Sun, 06 April 2014, 14:51:01 »
Just get yourself two-part keys for BS keyboards and clean only keycaps :) No need to clean stems then ;)
« Reply #19 on: Sun, 06 April 2014, 15:17:17 »
Yes, but I don't have time to remove, clean, (dry,) and replace a set of keycaps in one weekend.
Hence the drying phase usually lasts a week.
No doubt then that they are dry :p
Offline mougrim
« Reply #20 on: Sun, 06 April 2014, 15:26:03 »
Yep, by that time they're sure very dry :) Like the sand in Sahara :)
