Author Topic: Is it possible to remap poker II's caps lock to LCtrl  (Read 1623 times)
Offline bigwillystyle
« on: Sun, 06 April 2014, 13:02:22 »
I know the DIP switches don't cover this, but is a hardware mod possible or is this circuitry baked into the pcb?
Offline mougrim
Re: Is it possible to remap poker II's caps lock to LCtrl
« Reply #1 on: Sun, 06 April 2014, 13:30:43 »
Just remap it with some soft.
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Offline ideus
  • Björkö.
« Reply #2 on: Sun, 06 April 2014, 14:05:42 »
I used SharpKeys to swap left control and caps lock in all my computers, in that way I have any keyboard, even the one in my lap to work the same. It is very easy, it is based on registry, thus it does not require any hardware.
« Last Edit: Sun, 06 April 2014, 14:18:34 by ideus »
« Reply #3 on: Sun, 06 April 2014, 14:58:53 »
Software is plan B, but if I can do it in hardware that'd be great so it'd work on every computer regardless of OS etc
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #4 on: Sun, 06 April 2014, 15:07:05 »
Then sure.  Four jumpers and some trace cuts and the switch is moved.  I moved a switch on my first Poker, although not on my Poker II.
The only thing to be really careful about is ensuring the diodes stay in their proper places in the new circuits.  Well, and not burning or lifting traces, or otherwise toasting your board.
Solder doesn't forget its remapping!
 - Ron | samwisekoi
« Reply #5 on: Sun, 06 April 2014, 15:18:01 »
Neat, I'll look into that
Offline mougrim
« Reply #6 on: Sun, 06 April 2014, 15:30:10 »
But still - software mod is revertible :) Hardware isn't - well... it is, just not so easy. Although it is indeed possible.
« Reply #7 on: Sun, 06 April 2014, 16:10:53 »
Yeah, but why would I ever want a caps lock key :P
Offline mougrim
« Reply #8 on: Sun, 06 April 2014, 16:14:36 »
Anakin Skywalker thought he never ever will embrace the Dark Side... But is his wishes mattered in the end? :)
