Author Topic: Looking for a good solid tenkeyless  (Read 1625 times)
Offline exapted
« on: Mon, 07 April 2014, 12:02:14 »
I want to get a tenkeyless (87 key) that doesn't suck.
My criteria, from most important to least:
1) Hardware configuration for using "caps lock" key as LCONTROL.
2) Hardware switch for switching META and ALT keys.
3) Availability of PBT spacebar, possibly (probably) from a 3rd-party.
Here's an example of the layout I am looking for: http://cdn.wasdkeyboards.com/media/catalog/product/cache/1/thumbnail/492x/040ec09b1e35df139433887a97daa66f/v/2/v2-87-barebones.jpg
Since most normal people don't care at all about the above 3 criteria, I have no idea whether I can find a board like that.
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #1 on: Mon, 07 April 2014, 12:04:11 »
The WASD v2 supports everything you need :thumb: (through a set of dip switches). It's widely considered to be a very good board with a solid construction. Also, you can buy a barebones version if you plan on getting PBT caps.
You'll need a keycap set from a third party for your PBT spacebar though.
Offline exapted
Re: Looking for a good solid tenkeyless
« Reply #2 on: Mon, 07 April 2014, 12:18:50 »
Thanks! How can I determine if a cherry keycap set will fit that board (especially the space bar) ? I guess there are some standards or series of sizes and placements, but I'm not sure where to begin.
  • Cherry Peasant
  • keycult.com
« Reply #3 on: Mon, 07 April 2014, 12:25:02 »
The WASD v2 has a completely standard, modern layout. You want to look for the following bottom row sizing:
1.25u - 1.25u - 1.25u - 6.25u - 1.25u - 1.25u - 1.25u - 1.25u
For instance, mechanicalkeyboards.com sells a doubleshot PBT set from Vortex that will fit this perfectly. Almost every group buy here as well will have this layout in the "basic kit."
Edit: in case you're unfamiliar with keycap unit sizing, everything is measured relative to a single alpha key, which is 1u.
« Last Edit: Mon, 07 April 2014, 12:47:31 by riotonthebay »
Offline exapted
« Reply #4 on: Mon, 07 April 2014, 12:38:31 »
That's what I was wondering. Thanks for explaining to a newbie.
Offline Linkbane
« Reply #5 on: Mon, 07 April 2014, 13:20:53 »
Ducky keyboards (especially the Pro) are some of the best. Thick PBT, very nice color choices, and DIP switches supporting the changes you'd like. Also, the V2 is quite nice as well.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
  • Cherry Peasant
  • keycult.com
« Reply #6 on: Mon, 07 April 2014, 13:39:32 »
Good point. That CCnG Ducky will fit your needs well when it's released.
