Author Topic: Filco height replacement keycaps  (Read 4191 times)
Offline vario
« on: Mon, 07 April 2014, 17:08:24 »
Hi guys,
New member and first time mech kb owner...
I just purchased a used Filco Ninja Majestouch TKL keyboard for gaming. Really happy with it so far but would like to replace a missing fn key-cap (R1 1x1.25) and considering a tactile key-cap for W (WASD).  It has the cherry mx brown switches.  I love how they operate.
I looked at WASD Keyboards but I have read that they are slightly taller than the stock Filco key-caps.  Also, they offer several textured keys, does anyone have a recommendation as to which of those is the least "fatiguing", as in smoothest but still easy to locate?
Where can I get a FN key and WASD keys that are the same height as the Filco?  Do any sites sell front facing lettering like the oem keys?
Offline vario
Re: Filco height replacement keycaps
« Reply #1 on: Mon, 07 April 2014, 19:25:55 »
Well I ordered from WASD anyway, I read that the height difference was due to not seating them fully.  I am looking forward to getting these keys :)
« Reply #2 on: Mon, 07 April 2014, 19:32:18 »
WASD keycaps and Filco keycaps are both OEM profile, you'l be fine.
« Reply #3 on: Mon, 07 April 2014, 19:33:57 »
Welcome to Geekhack!
A good start - answering your own question ;)
Filco keys are (usually) OEM profile, WASD are also OEM profile AFAIK, so they should be a fairly close match.
You'll probably end up replacing the whole keycap set eventually anyway.  Pretty much everyone does at some stage :))
Offline vario
« Reply #4 on: Mon, 07 April 2014, 20:45:12 »
Thanks guys! Liking the keyboard so far!  Much better for gaming!  :thumb:
Offline vario
« Reply #5 on: Thu, 10 April 2014, 13:49:36 »
Very nice!  The WASD keycaps are identical to the Filco in texture, height, shape.  I ordered engraved red key caps and a blank key cap for the missing menu fn key.  They might be just slightly rougher, which is nice to differentiate the WASD movement keys from the surrounding.
Mousepad is a MM600.
Mouse is a Microsoft MSK-1094(B)
« Last Edit: Thu, 10 April 2014, 13:54:02 by vario »
