Author Topic: LightSaver V2 Group Buy  (Read 744776 times)
Offline digi
  • elite af tbh
  • keyboard game on fleek
Re: LightSaver V2 Group Buy
« Reply #200 on: Sat, 19 April 2014, 14:42:22 »
Elton, do you know what the spring options are? Any chance we can get 60g gold springs?
« Last Edit: Sat, 19 April 2014, 14:48:10 by digi »
Offline elton5354
« Reply #201 on: Sat, 19 April 2014, 15:26:26 »
You can get more colours for custom LED option.  Just provide a picture for us.
Available are 50g and 62g.  For others, he'll have to check for availability
Offline Ronnn
« Reply #202 on: Sat, 19 April 2014, 17:19:54 »
Hey Elton, can I use this layout(space row: 1.25x,1.25x,1.25x,6.25x,1.5x,1.5x,1x,1x)? This layout can let me keep left win key and arrow keys. I didn't see this in the form, so I just want to confirm .
Offline codyeatworld
« Reply #203 on: Sat, 19 April 2014, 17:35:52 »
Just curious, did duck help design the kmacs?
I also might be offering assembly for a couple boards (conus), let me know if anyone is interested.
I'll probably be getting some clears and stocking up on more leds/resistors.
Also, Margo from CTRL ALT can assemble if your outside conus.
Offline pasph
« Reply #204 on: Sat, 19 April 2014, 17:54:30 »
Elton can you please tell me what color i have choosen?
Offline elton5354
« Reply #205 on: Sat, 19 April 2014, 18:25:36 »
I don't think you can get that layout as each side should equal..
Black case
Probably helped with the PCB?
Offline digi
  • elite af tbh
« Reply #206 on: Sat, 19 April 2014, 18:40:03 »
But you can still do the 1.25x1.25x1.25 6.25 1.25x1.25x1.25x1.25 option and keep the 1800/arrow key layout tho, right? It should be the same length as both 7x options.
Offline elton5354
« Reply #207 on: Sat, 19 April 2014, 18:47:01 »
you are right.. sorry.
That template was given to me, so I think that's the limit of the layouts you can do..
Offline dragonken
« Reply #208 on: Sat, 19 April 2014, 20:02:53 »
I am still thinking to join the assembly service or not... Sad that no mx clear option.
Offline Lastpilot
  • Power stance
« Reply #209 on: Sat, 19 April 2014, 20:09:43 »
So by custom LED, does that also include customizing the side SMD LED?
Offline Kfactork
« Reply #210 on: Sat, 19 April 2014, 20:09:50 »
Think of it as a chance to try ergo clears..
Unless you already have Browns, then no comments.
Offline Pacifist
  • on hiatus
« Reply #211 on: Sat, 19 April 2014, 20:13:13 »
wat. Are you saying browns=ergo clears?
Offline digi
  • elite af tbh
« Reply #212 on: Sat, 19 April 2014, 20:13:28 »
Elton, would it be possible to follow up with Duck and find out what it would take to get clear switches as an option please? <3
Offline Kfactork
« Reply #213 on: Sat, 19 April 2014, 20:24:04 »
Nope. I was merely thinking along the lines of the non-clicky tactile switch category.
Don't they feel similar except for the spring weight? That's my experience with Black/Red and Blue/Green.
Offline cphead
« Reply #214 on: Sat, 19 April 2014, 20:45:43 »
Woaaaahh. You're missing out if you've never tried ergo clears. They are not alike at all. Clear bump is so much more satisfying than that brown scratchyness.
Offline Pacifist
  • on hiatus
« Reply #215 on: Sat, 19 April 2014, 20:49:09 »
lolnope
bigger bump, and different spring constant k
Offline Kfactork
« Reply #216 on: Sat, 19 April 2014, 21:51:47 »
Hmm now I'm curious about ergo clear. ::)  Is the bump more noticeable than blue? I didn't want brown because people say it's scratchy red and I don't like it.
Offline Sniping
« Reply #217 on: Sat, 19 April 2014, 22:09:49 »
The ergo clear is really different from the blues. Blues are clicky but ergo clears are tactiles. If you're looking for a tactile keyboard you should definitely give the ergo clears a try, they're usually the preferred MX tactile switch.
Offline Kfactork
« Reply #218 on: Sat, 19 April 2014, 22:14:15 »
Oh I understand that the clears are non-clicky & tactile. I'm not exactly sure what they feel like though; like if you never tried Topre how would you know what you are missing kind-of-thing y'know? My impression is they the bump is similar or greater than blues, and a larger activation / bottom out force.
Maybe I really should get some and try for myself.
Offline Sniping
« Reply #219 on: Sat, 19 April 2014, 22:20:15 »
I see what you're trying to say. I say that the point of resistance for the click on the blues is very pronounced, whereas it's a bit more gradual for tactile switches. A bump, like I said previously. The resistance on MX switches right before the point of actuation (so the click/tactile part of the switch) is snappier than Topre. Topre feels more smooth and gradual, but super tactile at the same time. You're are missing out if you haven't tried a good tactile switch yet :p
Offline Kfactork
« Reply #220 on: Sat, 19 April 2014, 22:30:43 »
Well that's it then! My next board will be ergo clear.
Hopefully duck will add the clear switch option.
Offline Sniping
« Reply #221 on: Sat, 19 April 2014, 22:38:42 »
You shouldn't count on it. I think that the best option for you is to send it to someone in the US to assemble the keyboard, and then send them clears, springs, and lube as well. You can buy clears and springs off of mechanicalkeyboards.com
Offline Pacifist
  • on hiatus
« Reply #222 on: Sat, 19 April 2014, 22:39:26 »
mk has springs??? shieetttt
Offline Kfactork
« Reply #223 on: Sat, 19 April 2014, 23:45:50 »
I should just hold off on filling in the form then. We are still some time away from the actual deadline so I have time to save up a little. :)
Offline Sniping
« Reply #224 on: Sun, 20 April 2014, 00:19:09 »
Whoops. Meant lube. Sorry to get your hopes up lol
Offline ranker
    • keyboard porn
« Reply #225 on: Sun, 20 April 2014, 09:41:41 »
Are these 15 units sold out?  If not, I would like to place an order.
Offline LechnerDE
« Reply #226 on: Sun, 20 April 2014, 09:53:40 »
It was increased to 30 units, but these are sold out as well :(
Offline witbliz
« Reply #227 on: Sun, 20 April 2014, 11:06:38 »
So much customization possibilities ! I spent 2 hours thinking of what switches , leds and keymapping and I still cant confirm the layout and final form..
I am wondering of those who have submitted the form - what pro / cons are there in your design choice and the reason behind the choice of layout.
Elton is there a way to view the polls / what everybody is choosing for their final lightsaver ?
If i order those duck blockers - would that mean there is no mx switch there ? or is it placed on top of it and just restricting the switch from being pressed ?
Offline elton5354
« Reply #228 on: Sun, 20 April 2014, 11:10:56 »
There's only 2 that submitted so far.
https://docs.google.com/spreadsheet/ccc?key=0Akw9rY8oi1o6dGpBUFV5eXBMNVVIRjRGcE8zUElld3c&usp=sharing
If there is a blocker, there can't be a switch there since the blocker uses the switch hole to stay in place.
« Last Edit: Sun, 20 April 2014, 11:14:16 by elton5354 »
Offline yicaoyimu
« Reply #229 on: Sun, 20 April 2014, 11:14:42 »
You should be blamed... I even went through the whole list of keyboard accessories on MK after reading your post...
Offline tadbitnerdy
« Reply #230 on: Sun, 20 April 2014, 12:08:23 »
Any word on the black blockers?
Offline elton5354
« Reply #231 on: Sun, 20 April 2014, 12:19:26 »
There aren't enough orders.  We have 76 silver blockers so far. We need over 100 silver blockers for them to make black ones..
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #232 on: Sun, 20 April 2014, 13:22:45 »
I just want to put 1800 Keys on this puppy, do I need to fill out the customization assembly to make sure I get the correct plate? I will build this myself and provide my own switches/stabilizers.
Offline nuclearsandwich
« Reply #233 on: Sun, 20 April 2014, 13:34:50 »
I assume the plate has to support every layout the PCB does right?
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #234 on: Sun, 20 April 2014, 15:14:55 »
If they are universal plates, they could be specific to layouts though. I'm not familiar enough with the plate.
Offline elton5354
« Reply #235 on: Sun, 20 April 2014, 15:19:27 »
Pretty sure there's only 1 universal plate otherwise they would have asked me to add an option for the plates in the order form.
Also this layout 1.25x,1.25x,1.25x,6.25x,1.5x,1.5x,1x,1x won't work..or so I've been told.
« Reply #236 on: Sun, 20 April 2014, 15:59:57 »
The Duck Mini plate had wide cutouts for the switches with multiple possible positions like Caps lock and the bottom row. I'll snap a picture of it when I get home since it's currently disassembled
Offline elton5354
« Reply #237 on: Mon, 21 April 2014, 08:27:04 »
Do you have a whole collection of duck's keyboards or something? :P
« Reply #238 on: Mon, 21 April 2014, 08:28:29 »
Maaaaybe
« Reply #239 on: Mon, 21 April 2014, 08:35:20 »
Here is the worst picture that could possible show what I mean.
Offline digi
  • elite af tbh
« Reply #240 on: Mon, 21 April 2014, 09:22:13 »
any update on the possibility of adding clears to the assembly options? plss  ;D
Offline elton5354
« Reply #241 on: Mon, 21 April 2014, 11:47:07 »
I've already asked and it's a no unfortunately
Offline digi
  • elite af tbh
« Reply #242 on: Mon, 21 April 2014, 11:53:41 »
ah ok, well thanks for trying. Is there a tentative due date for getting the assembly form completed? Not sure what I'm going to do yet..
Offline Ronnn
« Reply #243 on: Mon, 21 April 2014, 11:54:33 »
Hey elton, sry for being so annoying. For the layout I have been asking for. 1.25x,1.25x,1.25x,6.25x,1.5x,1.5x,1x,1x. Why is this infeasible? Is it the software limitation or the pcb doesn't support it?
The mid row in the following graph shows the layout I want.
Is it because when I use 1.25x,1.25x,1.25x,6.25x in the left, the current will only go through the circuit where 1.25x,1.25x,1.25x,1.25x lies in the right. Then even I put the switches in the 1.5x,1.5x,1x,1x, there would be not current passing these paths, thus these four keys can't be detected.
Offline digi
  • elite af tbh
« Reply #244 on: Mon, 21 April 2014, 12:00:31 »
Sorry, one more question..If we decide to opt out of the assembly option, could we possibly have the option to buy the cherry pcb mount stabs?
Offline elton5354
« Reply #245 on: Mon, 21 April 2014, 13:41:14 »
You are right Ron, you can get that layout.  Just specify that in the forms.
I've asked in the previous group buys, and he said no. I asked again, let's see..
I'll add that layout to the form
EDIT: You can order 1 stabilizer set for one unit ordered
Just PM me if you want to add a set.
Also for that layout, Ron, I don't think you can use the plate..
« Last Edit: Mon, 21 April 2014, 14:29:58 by elton5354 »
Offline tadbitnerdy
« Reply #246 on: Mon, 21 April 2014, 14:13:58 »
Hey Elton,
Not that it really matters, but out of curiosity, will the orders without assembly services be shipped before those that requested assembly services, or will they all be shipped in the same go?
-Tad
« Reply #247 on: Mon, 21 April 2014, 14:50:00 »
Is this just if we order assembly service or can we get a stabilizer set if we are assembling it ourselves?
Also, what is the cost?
Offline Sniping
« Reply #248 on: Mon, 21 April 2014, 16:16:43 »
Is there no possibility that the order limit can be expanded again? I'd really like one of these keyboards, and since the initial orders filled in a day, I'm sure I'm not the only one that still wants one.
Offline Photoelectric
« Reply #249 on: Mon, 21 April 2014, 16:18:05 »
There's still Originative.
