Author Topic: Right angle mini USB to regular USB  (Read 2159 times)
Offline uzoc
« on: Wed, 16 April 2014, 16:03:25 »
Just got a Vortex Pure PRO, but I hate the standard straight mini USB connector which gets in the way.
Found some standard ones on EBay that will work...
Any recommendations on others and/or elsewhere?
Re: Right angle mini USB to regular USB
« Reply #1 on: Wed, 16 April 2014, 22:30:50 »
My recommendations:
1.  Is it cheap?
2.  If yes, buy it.
3.  If no, check Amazon, Monoprice, Google, and the entire internet.
4. Repeat step 1.
5.  If you can't find it cheap, get someone to make a short adapter for you.
« Reply #2 on: Wed, 16 April 2014, 22:31:38 »
Get one custom made at http://mimic-cables.com !
Offline uzoc
« Reply #3 on: Thu, 17 April 2014, 00:04:37 »
Thanks for the tips guys!
