Author Topic: BSP PBT keyset with dyesub printed 103 pcs keycaps Group buy  (Read 543952 times)
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
Re: BSP PBT keyset with dyesub printed 102 pcs keycaps Group buy pre order
« Reply #100 on: Mon, 21 April 2014, 03:29:43 »
here's the images that token on a keyboard. but should forget the green esc key.
Oh all key is pbt dye-sub except green esc? And all is Cherry old keycaps or BSP keycaps? If that is BSP, BSP fixed arrow issue on Enter cap?
Hi Friend, I believe that:1. The set are all PBT caps; 2. The keycaps are ordered from BSP (Blank Set); and 3. All print is carried out by IMSTO himself thus for the font you can refer to the sample pics
You misunderstood his question, he talked about the sample picture so the green Ecs is ABS double-shot, the thing we're wondering is the keycaps in the photo were BSP made or just the original set from Cherry
He answered it what, it is bsp made blank caps and dye sub done by imsto.
OK ok i understood :) That photo is prototype
Offline cphead
« Reply #101 on: Mon, 21 April 2014, 04:10:30 »
imsto, do you have an estimate for when these will ship? I would like to order but my summer schedule is not set yet  :D
Offline intelli78
« Reply #102 on: Mon, 21 April 2014, 16:49:54 »
How many sets have been ordered?
Also, a GMK spacebar would be great, but is there any realistic way to get a Moogle set made for these? BSP doesn't have the molds, GMK doesn't do PBT as far as I know, Imsto can't match the color, and I don't think SP has any Cherry molds either. If GMK does a doubleshot ABS moogle set, would we be able to match the color? Its hardly ideal, and I am loathe to spend even more money, but this would just be so much more compelling as a complete set.
Edit: or does SP have cherry molds? They did do these: http://geekhack.org/index.php?topic=33562.0
« Last Edit: Mon, 21 April 2014, 16:54:47 by intelli78 »
Offline lightsout714
« Reply #103 on: Mon, 21 April 2014, 17:13:41 »
Sp profile is similar to cherry but not the same.
Offline chaosstep
  • From Hell
« Reply #104 on: Mon, 21 April 2014, 21:53:36 »
Just quick question.
What is difference between the weight based shipping and the flat rate shipping?
Both with tracking service internationally?
Offline YongJK
« Reply #105 on: Mon, 21 April 2014, 21:56:35 »
There is no way.
Either you find your own 6.25 space bar and rgby set to complete bottom row.
Keyboard: PLU ML87 Mx Blue
Offline imsto
  • * Moderator
    • imsto.cn
« Reply #106 on: Tue, 22 April 2014, 04:39:40 »
not clear yet. but should be after few weeks when GB closed
deadline 20 May
imsto.cn
imsto's AiKB Taobao Shop
IBM Model M*3, IBM M13,M5, IBM with balls.Cherry   3000  3494 3700 4100*6 700*2 11900 8113 DAS4 TG3 KBC PokerDucky09Ducky1087 apple pink alps Ducky bull,tiger,rabbit,dragon version No:0000002
Offline imsto
  • * Moderator
    • imsto.cn
« Reply #107 on: Tue, 22 April 2014, 04:40:23 »
both got tracking number.
imsto.cn
  • Frenzy Classic.
« Reply #108 on: Wed, 23 April 2014, 02:45:37 »
I found some photos on otd. I think that is belongs to imsto
Offline kekkon
« Reply #109 on: Thu, 24 April 2014, 04:52:27 »
The keycaps was produced by IMSTO, but not the keyboard and keycaps.  :)
*Edit: Typo
Offline kekkon
« Reply #110 on: Thu, 24 April 2014, 04:53:20 »
Tony How be friends.  :-*
Offline pinyrx
« Reply #111 on: Thu, 24 April 2014, 12:53:26 »
hmm, I'm wondering if bsp corrected the crooked stems?
Offline chaosstep
  • From Hell
« Reply #112 on: Fri, 25 April 2014, 01:22:09 »
I think if that problem was already fixed or solved later, a lot of people especially Korean guys gonna join this GB more and more.
But I wonder whether BSP even notice that problem or not haha
Offline jonathanyu
« Reply #113 on: Fri, 25 April 2014, 18:32:13 »
how does the Russian set look compare to the original one?
« Reply #114 on: Fri, 25 April 2014, 19:06:42 »
Rough comparison :
Imsto on BSP (not sure who took the photo):
Original (photo from eungsam):
Offline jonathanyu
« Reply #115 on: Fri, 25 April 2014, 21:08:38 »
Rough comparison :
Thanks! seems the color of the imsto one is sharper, but the legend is rougher
« Reply #116 on: Fri, 25 April 2014, 21:16:07 »
Rough comparison :
Well, aged caps and youthful caps, so take that as you will.  The OG caps are much much sharper and cleaner looking in that photo.
Offline jonathanyu
« Reply #117 on: Fri, 25 April 2014, 21:33:48 »
Rough comparison :
That's true
BTW, imsto, will blank keycap also available in this GB?
Offline imsto
  • * Moderator
    • imsto.cn
imsto.cn
  • Frenzy Classic.
Offline Pacifist
  • on hiatus
« Reply #121 on: Mon, 28 April 2014, 22:41:50 »
ooo that RGB will go nice with an OG set
Offline findingthelimit
  • Rawr
« Reply #122 on: Wed, 30 April 2014, 16:08:24 »
Hey guys, I'm interested in buying a set but I don't have a decked out Korean custom. Does anyone know how I can find Cherry A-profile RGBY sets for Winkey layouts, that would match the quality of this set? (preferrably PBT). I believe most of the GBs here are ABS.
Poker 2 reds, GH60 42g ergo clears
« Reply #123 on: Wed, 30 April 2014, 16:14:56 »
A profile 1.25x modifiers don't exist anywhere.
  • Rawr
« Reply #124 on: Wed, 30 April 2014, 16:31:43 »
Thanks. What if I'm looking for B profile? Sorry; inexperienced.
« Reply #125 on: Wed, 30 April 2014, 16:35:21 »
http://imsto.cn/index.php?route=product/product&path=59&product_id=53
There's no yellow though.
Offline intelli78
« Reply #126 on: Wed, 30 April 2014, 16:42:46 »
Are those the original Cherry colors? Seems like the blue is a bit light.
Offline Photoelectric
« Reply #127 on: Wed, 30 April 2014, 16:44:56 »
Those are IMSTO's more standard colors of PBT.  They are not made by BSP.
Offline intelli78
« Reply #128 on: Wed, 30 April 2014, 16:47:57 »
Thanks.
Offline imsto
  • * Moderator
    • imsto.cn
« Reply #129 on: Fri, 02 May 2014, 10:29:41 »
it is BSP keycaps, not the 1.25 rgb that i got.
imsto.cn
« Reply #130 on: Fri, 02 May 2014, 17:12:47 »
Interesting, they look like your colors, especially the light blue.
Offline Candyflip
« Reply #131 on: Fri, 02 May 2014, 17:16:35 »
The 1.25 is not BSP while the 1.5 is. Right?
« Reply #132 on: Fri, 02 May 2014, 17:22:19 »
Yep, correct. 1.25 is regular imsto. BSP doesn't do 1.25
Offline intelli78
« Reply #133 on: Fri, 02 May 2014, 17:28:32 »
It's like McDonalds not doing fries  :rolleyes:
I get that the mold would be expensive, I really do, but I find it very hard to believe it would not pay off quickly.
« Reply #134 on: Fri, 02 May 2014, 17:30:43 »
I'd rather they fix their right shift mould.. :rolleyes:
  • Rawr
« Reply #135 on: Fri, 02 May 2014, 20:17:09 »
Ai, do you guys know what is the closest I can get to 1.25 RGB modifiers that are Cherry B profile with the original GKM colors? IMSTO's colors seem rather off.
« Reply #136 on: Fri, 02 May 2014, 20:20:49 »
Buy GMK 1.25 RGBs.. They are doubleshot ABS. The only 1.25x thick PBT RGB set is the one that imsto sells.
Offline intelli78
« Reply #137 on: Fri, 02 May 2014, 20:22:04 »
Is there a place where they are readily available for sale? EK has some but the colors are way off.
« Reply #138 on: Fri, 02 May 2014, 20:23:04 »
Yeah I'm guessing IMSTO misunderstood what we were referring to.  The $25 RGB set looks like IMSTO's PBT and is using 1.25x modifiers--not BSP.
« Reply #139 on: Fri, 02 May 2014, 20:26:02 »
Originative used to stock them. kbdmod might still have some sets : http://kbdmod.co.kr/product/list.html?cate_no=12
I believe feng? is running a GB for them soon. You could also look for them on the classifieds.
« Reply #140 on: Fri, 02 May 2014, 20:54:27 »
I think Feng's GB is done taking orders and possibly just paid for production or is about to. Never know though may still have a chance.
« Reply #141 on: Fri, 02 May 2014, 20:59:43 »
Ah right.. Well in that case there should be some sets on his ebay store soon.
Offline phoenix1234
« Reply #142 on: Fri, 02 May 2014, 21:48:31 »
Maybe the colour of the RGB is not what you expect. But I think if you really need 1.25 PBT modifiers, you should go for Imsto's PBT one.
63398-0
The roughness, thickness and the construction of Imsto PBT are the best Cherry Profile RGB PBT replica set for winkey, IMO. It is very close to Cherry PBT. So you can mix it with BSP PBT without any problem. Even better, it can be a potential replacement for BSP shift key if you are not satisfied with it.  ;D
63400-1
* The Imsto shift key is a bit higher because it has Costa clips mounted
Eventually, you can have a full PBT set for winkey keyboard.
« Last Edit: Fri, 02 May 2014, 22:04:18 by phoenix1234 »
I like linear switches
Offline anoxy
  • Deal with it
« Reply #143 on: Sat, 03 May 2014, 03:02:22 »
So this "group-buy" is just basically a static priced pre-order? No chance of actually lowering the price if more people commit?
  • Frenzy Classic.
« Reply #144 on: Sat, 03 May 2014, 03:55:45 »
Yeah sure because keyset is not made by SP  :p
Offline bazh
« Reply #145 on: Sat, 03 May 2014, 05:43:12 »
sure will be lowering price, but that's the story of a lot of orders, and by "a lot" I mean >400
HHKB Pro2 white
Newbie again
Offline imsto
  • * Moderator
    • imsto.cn
« Reply #146 on: Sat, 03 May 2014, 09:40:03 »
yes, right.
that's right... I know the gb is realy hard to reach 300, not even 400. just like Ivan's black keys GB.
what I can do is provide a lower price that I can do then make it.
imsto.cn
Offline imsto
  • * Moderator
    • imsto.cn
« Reply #147 on: Sat, 03 May 2014, 10:37:34 »
ok, to make it lower. here's a GB price
basic price 135$
orders----> 100    -5$
orders----> 200    -10$
orders----> 300    -15$
imsto.cn
Offline imsto
  • * Moderator
    • imsto.cn
« Reply #148 on: Sat, 03 May 2014, 10:40:22 »
as to the GB of the plate. I think it is cheap enough, the ammount that will be produced depends on the orders.
imsto.cn
  • Rawr
« Reply #149 on: Sat, 03 May 2014, 10:40:32 »
basic price 135$
orders----> 100    -5$
Hey Imsto, should I check out now from my shopping cart, or wait? I'm not sure how the lowering price works. Is there a coupon code?
