Author Topic: Why there are so few topre keycaps?  (Read 13646 times)
Re: Why there are so few topre keycaps?
« Reply #50 on: Wed, 23 April 2014, 18:20:40 »
MX stems are round with a "+" in the middle.
Can you drill out the "+" to make it "O", then cut a notch in the top and bottom to turn it into Topre compatible?
I would imagine a makeshift staff like that wouldn't fit very well.
I have a box full of Crap Bag keycaps - this might make an amusing project for the long weekend.
Offline Lu_e
« Reply #51 on: Wed, 23 April 2014, 18:28:33 »
I feel like MX stems aren't a big enough diameter
Just say NO to ABS keycaps
« Reply #52 on: Wed, 23 April 2014, 18:53:20 »
I had a few caps with an MX-like stem, but somewhat wider.  Still with the "+" in the middle.
Offline exitfire401
  • The Force is Re/\l
« Reply #53 on: Wed, 23 April 2014, 18:56:40 »
You probably could, but it wouldn't be stable enough to support constant typing.
« Reply #54 on: Wed, 23 April 2014, 19:03:48 »
Just making me more curious now :p
« Reply #55 on: Wed, 23 April 2014, 19:08:44 »
doesn't work at all, actually
the stem on MX caps is too small
« Reply #56 on: Wed, 23 April 2014, 20:22:11 »
You lot are a bunch of wet blankets :))
Offline beartung
« Reply #57 on: Wed, 23 April 2014, 21:18:12 »
Only I can tell there are many fans of hhkb in China. :)
Looking for Topre Orangesicle CC & Topre Limoncello CC
Offline iLLucionist
  • Topre is Love.
« Reply #58 on: Thu, 24 April 2014, 15:17:09 »
Why actually DID Topre stop making keycaps?
Offline atlas3686
  • HHKB Elite
« Reply #59 on: Fri, 25 April 2014, 01:49:45 »
I don't think anyone knows for sure.
« Reply #60 on: Fri, 25 April 2014, 02:00:32 »
So I went ahead and tried anyway.
The MX stem is about the same width as the Topre stem.
The hole in the middle of the Topre stem is about 5/32" (or that is the drill bit that most tightly fitted).
I drilled out the middle of a couple of MX keycaps from a Crap Bag - no big deal.
The problem was carving the slot in the upper and lower "edges" of the stem.  On Topre this is narrower at the end of the stem and widens as you go up towards the typing surface of the keycap.  Careful inspection of the Topre slider reveals a triangular bit that presumably the stem clips over to hold the keycaps on.
I carved a slot and the keycap went on, but wouldn't stay on.
I tried to carve it wider at the top of the keycap and narrower at the bottom, but that was kinda awkward.
One attempt sort of clipped on at the bottom of the keycap, but not the top.
The other one sort of went on and stayed on, but was really loose.
Also the MX stems are not as long as the Topre stems.  The Topre ones extend out past the bottom of the skirt.
So I guess with a bit of care, some more time, and some proper tools, it would be possible.  More or less.
Offline thestage
« Reply #61 on: Fri, 25 April 2014, 16:45:16 »
the cynic in me says topre wants people to shell out for new boards when they want new caps
but then again, they don't produce boards with any caps besides white/biege and black, so who knows.
