Author Topic: LED Color Caps?  (Read 2067 times)
Offline Blackehart
LED Color Caps?
« on: Mon, 21 April 2014, 13:13:12 »
A while back I saw some plastic doohickeys that went on top of the led bulb to change the glow color.
It looked like a little plastic-ish clamp that covered the led but didn't interfere with the key bottoming out.
Does anyone know what these are called?
Offline Blackehart
Re: LED Color Caps?
« Reply #1 on: Mon, 21 April 2014, 13:19:35 »
oops!
I see there have been group buys for these before.
EDIT: I don't suppose you can get these stateside? 120.00 shipping is a little nuts.
« Last Edit: Mon, 21 April 2014, 13:45:11 by Blackehart »
Offline Lu_e
Re: LED Color Caps?
« Reply #2 on: Mon, 21 April 2014, 13:45:02 »
Looks like you found your answer; LED color changers. They were also sold on massdrop.com
Just say NO to ABS keycaps
Offline Blackehart
Re: LED Color Caps?
« Reply #4 on: Wed, 23 April 2014, 12:27:23 »
Qtan also has these up on his shop.
Offline ajx
Re: LED Color Caps?
« Reply #5 on: Wed, 23 April 2014, 13:26:04 »
Need to solder LED into switches?
Re: LED Color Caps?
« Reply #6 on: Wed, 23 April 2014, 16:57:26 »
Only if you do not already have them fitted, and only if the PCB supports them.
Offline ajx
Re: LED Color Caps?
« Reply #7 on: Wed, 23 April 2014, 17:24:42 »
Dunno but i maybe buy non backlit Pure version, does i need to solder LED?
Re: LED Color Caps?
« Reply #8 on: Wed, 23 April 2014, 18:20:02 »
Most non-backlit keyboards do not have provision for adding LEDs.
Maybe someone more familiar with that Pure could respond.
Or, just get a backlit keyboard up front.
