Author Topic: Modding a QFR Case for a Phantom PCB  (Read 1819 times)
Offline metal1091
« on: Mon, 21 April 2014, 16:42:08 »
Has anyone modded a CM QFR case for use with a Phantom PCB? I'm buying one off reddit for extremely cheap and was woundering if anyone could give some advice or point me in the right direction for a tutorial or just some tips in general
-Mark
« Last Edit: Mon, 21 April 2014, 16:44:16 by metal1091 »
Re: Modding a QFR Case for a Phantom PCB
« Reply #1 on: Mon, 21 April 2014, 16:48:53 »
Quote from: esoomenona
I've modded a Filco to fit in a QFR case. Being that the Phantom was designed to fit directly in a Filco case, I'm going to assume the modifications for the two are exactly the same. All it requires is some sanding of a couple of the standoffs. Lining them up, you can see which two need to be sanded. I believe it's one each on the top and bottom portion of the case. If you can't figure it out, I can find out exactly which two for you.
Offline metal1091
« Reply #2 on: Mon, 21 April 2014, 16:57:30 »
THANK YOU! exactly what I was looking for!!  :thumb: :thumb: :thumb:
