Author Topic: a dying key?  (Read 2535 times)
Offline Neo.X
a dying key?
« on: Tue, 22 April 2014, 21:42:19 »
One key of my keyboard acts wierd. If I don't use the keyboard for couple days, when I connnect the keyboard, this key won't register at all. But if I leave the keyboard connected for a while, it starts working. It looks like it needs some warming up.  ;)
Could this be a switch problem, or soldering problem, or worse,a trace of pcb problem?
Thanks
All those keyboards will be lost in time....
Offline Pacifist
  • on hiatus
Re: a dying key?
« Reply #1 on: Tue, 22 April 2014, 21:42:49 »
take it apart and resolder the switch
Offline Neo.X
Re: a dying key?
« Reply #2 on: Tue, 22 April 2014, 21:49:16 »
I might end up doing this. But I like to know what's the possible cause for this kind of issue before I disassemble it.
Thanks
Re: a dying key?
« Reply #3 on: Tue, 22 April 2014, 21:56:50 »
Thanks
most likely an intermittent solder connection. I would reflow the solder on the switch and replace it if that doesn't fix things.
Offline Neo.X
Re: a dying key?
« Reply #4 on: Tue, 22 April 2014, 22:00:56 »
Thanks, I hope it just a solder issue, which is easy to fix.
So it shouldn't be the trace of the PCB because the switch registers fine after it starting working, right?
Re: a dying key?
« Reply #5 on: Tue, 22 April 2014, 22:31:15 »
Oh no it's not the ergodox I worked on is it
Offline Neo.X
Re: a dying key?
« Reply #6 on: Tue, 22 April 2014, 22:51:34 »
no, my friend. That one works fine. It's a Korean Customize, bad luck of me.  :(
I might need your help for this one as well.  :)
« Last Edit: Tue, 22 April 2014, 23:01:01 by Neo.X »
