Author Topic: bare wire Custom keyboard  (Read 2061 times)
Offline margo baggins
  • Dungeon Dweller
  • Get back to work!
« on: Wed, 23 April 2014, 09:12:27 »
Hello,
while I would love to design a PCB, I don't really know enough about designing electronics. I do have a teensy, and a million switches, and some acrylic plates.
I am fine with how to put that lot together phyiscally, in the real world - but I have absolutely zero idea of how I am going to get a firmware on my teensy that will make all the bits I put together a keyboard.
Is it literally just a case of editting the TMK firmware to the specifics of your keyboard/matrix and then editing the layout that way? Is that easily enough done?
I have messed about with lots of custom boards, firmwares, programming said boards etc. but don't really know how to apply that to doing my own board, from the ground up, if that makes any sense....
Any pointers welcome, I do intend on making a pcb at some point - I just need to learn a bit more/have a bit more time on my hands before I undertake that.
I got boards.
Re: bare wire Custom keyboard
« Reply #1 on: Wed, 23 April 2014, 09:15:10 »
Yes, that's all you need to do to get your handwired keyboard working.
matt3o made an excellent guide at Deskthority.
http://deskthority.net/workshop-f7/how-to-build-your-very-own-keyboard-firmware-t7177.html
  • Dungeon Dweller
  • Get back to work!
« Reply #2 on: Wed, 23 April 2014, 09:22:07 »
ah man thanks very much! that's perfect.
I got boards.
Offline RabRhee
« Reply #3 on: Wed, 23 April 2014, 10:18:42 »
Cool, I was idly wondering this too, for when I get a break from cutting square holes in things. Thanks to JDCarpe and Matt3o.
-Life is good-          Crafting: |  Keychains |  More.   .Keychains | Crowdsource Key | Budget Keycap Board |
