Author Topic: Plate Mounted White MX and Clear MX in!  (Read 5937 times)
Offline JoshMK
  • * Commercial Vendor
  • MechanicalKeyboards.com
Josh McConnell
Josh@mechanicalkeyboards.com
615.266.1420 ext303
Re: Plate Mounted White MX and Clear MX in!
« Reply #1 on: Wed, 23 April 2014, 11:37:10 »
Ducky is making switches now? I noticed the 100 packs of Whites are listed with Ducky as the supplier.
Edit: That's awesome that you got a hold of Whites though :D
« Last Edit: Wed, 23 April 2014, 11:39:17 by CPTBadAss »
« Reply #2 on: Wed, 23 April 2014, 11:37:27 »
Offline JoshMK
« Reply #3 on: Wed, 23 April 2014, 11:41:01 »
lol, no. Looks like we both caught my mistake at the same time.
Josh McConnell
615.266.1420 ext303
« Reply #4 on: Wed, 23 April 2014, 11:41:57 »
Haha hooray for teamwork then! Excited that others will be able to get to try Whites, which I love :D.
« Reply #5 on: Wed, 23 April 2014, 11:43:39 »
I wish they were PCB mount whites :'(
« Reply #6 on: Wed, 23 April 2014, 11:45:51 »
Find PCB mount switches, then swap in the stem and tops from the Plate Mount Whites into the PCB mount bottoms?
« Reply #7 on: Wed, 23 April 2014, 11:46:10 »
Effort :'(
Offline Zeal
    • Zeal Generation Inc.
« Reply #8 on: Wed, 23 April 2014, 11:54:37 »
Awesome! So linear grays are the only switch left?
Offline Grendel
« Reply #9 on: Wed, 23 April 2014, 14:08:49 »
Nope, also missing MX Lock (hint, hint ! ;))
- I'm game !
Offline Zeal
« Reply #10 on: Wed, 23 April 2014, 14:12:23 »
I thought we established this the last time in the MX Green thread. :))
Ooh! Are MX whites next on the list?  ;D
Linear Grays?
Anything else missing?
MX Lock ! :D
Not able to receive any more lock switches.
Urgh, missed that one. Sticking w/ my preorder here then :) Actually, MK could get some for their store there too -- 800 pack is 799€ (200 pack is 219€.) ;p
Offline Grendel
« Reply #11 on: Wed, 23 April 2014, 14:16:38 »
Some things are worth repeating at least once ;)
Ordered a pack of whites, thanks !
- I'm game !
Offline Reckthor
    • PC Stuff
« Reply #12 on: Sun, 27 April 2014, 03:51:36 »
YES!
