Author Topic: Key constantly being actuated internally in model m [solved]  (Read 2759 times)
Offline Vanilla
  • 110% Snuggable
« on: Sun, 27 April 2014, 02:48:39 »
I acquired another model m spacesaver earlier this week and it has started having problems with its left shift key remaining actuated internally. I.E. physically, the key is not stuck and clicks as normal (as it did this entire time up until now) but the keyboard outputs a constant left shift key press no matter the position of the key.
I've been able to confirm this by hitting caps lock and observed that this would be the only way to type in lower case. And upon replacement of the problem keyboard with a confirmed working keyboard, it takes a hit of the left shift key to put things back to normal on the system.
This only started recently, at first it was a solid performer with no problems whatsoever. Then the problem described above would occur sporadically and I thought it was my motherboard with a dying PS2 port as a restart usually fixed it. Then that wouldn't even fix it.
I've tried reseating the problem key multiple times and even replaced the spring to no avail and I'm starting to think it's something else.
Thoughts/ insight?
« Last Edit: Fri, 18 July 2014, 01:51:03 by Vanilla »
Offline E TwentyNine
    • Some of My Keyboards
Re: Key constantly being actuated internally in model m
« Reply #1 on: Sun, 27 April 2014, 08:02:44 »
Taking some shots in the dark before the inevitable...
Do you have another M to test with?  M's draw more power and may freak out an adapter or the PS/2 port on modern boards that have them.  Try it on a different computer if possible.
Could be debris in the matrix causing it to short.   I'd give the keyboard a good thwack while positioned vertically a few times and see what happens.
If you have another M, switch controller boards.  This is a longshot but worth investigating before the inevitable...
Bolt Mod.
« Reply #2 on: Sun, 27 April 2014, 10:07:41 »
Bolt Mod.
I would bet money that this is it, and why I always take these things completely apart when when I mod them.
- D Trump 2026-10-24
Offline Vanilla
  • 110% Snuggable
« Reply #3 on: Sun, 27 April 2014, 11:03:44 »
That sounds quite plausible.
Yeah I tried it with another desktop and my laptop and my wife's laptop with a blue cube. Same outcome. :(
Yes I have different m's and I'll give a controller swap a go.
Offline orihalcon
« Reply #4 on: Wed, 16 July 2014, 21:34:51 »
Yeah, everything seems to point to a membrane problem that should be fixable if you want to take the keyboard apart and clean between the membranes.
Offline Vanilla
  • 110% Snuggable
« Reply #5 on: Fri, 18 July 2014, 01:43:22 »
Wow I totally forgot about this thread.
This was indeed the case!
Thanks to this thread, I unwittingly learned how to bolt mod m's.
« Last Edit: Fri, 18 July 2014, 01:55:59 by Vanilla »
« Reply #6 on: Fri, 18 July 2014, 01:44:30 »
A valuable skill to have :)
Offline Vanilla
  • 110% Snuggable
« Reply #7 on: Fri, 18 July 2014, 01:50:11 »
Added a picture^; would've been faster if imgur wasn't down
Re: Key constantly being actuated internally in model m [solved]
« Reply #8 on: Fri, 18 July 2014, 01:53:07 »
Ooh a SSK too, I missed that bit!
Definitely worth spending that extra bit of time and effort to rejuvenate!
Offline CaptLock
« Reply #9 on: Fri, 18 July 2014, 09:20:51 »
Nice job!  I want to try a Model M someday.
« Reply #10 on: Sat, 19 July 2014, 03:16:27 »
A worthy goal ;)
Offline hamenoskili
« Reply #11 on: Sat, 19 July 2014, 12:20:29 »
maybe "sticky keys" is enabled??
press the shift key 5 times in a row and it will prompt you if you want to enable them. Press no, i know it's a long shot, but still worth a try i suppose.
Cheers.
