Author Topic: Poker 2 backlit plus blank pbt keyboards  (Read 5176 times)
Offline roaming pear
  • THE Roaming Pear
« on: Sun, 27 April 2014, 14:04:01 »
Hello,
I was wondering should I get the back-lit version of the white poker 2 if I am also getting blank keycaps (in addition to a set of black poker 2 key caps)?
I understand the light wouldn't come through the keys once I replace them, but would the light still come through the sides of the keys?
Does anyone have any accessories or key caps or other poker 2 related things lying around that they are not using?  I don't mind taking it off your hands if you no longer want it...
Offline hjkl_over_wasd
Re: Poker 2 backlit plus blank pbt keyboards
« Reply #1 on: Sun, 27 April 2014, 14:37:25 »
I do not have an answer to your question, but I thought I would share some insight I have had after getting my Poker II.
I went from a Logitech G710+ which has MX brown switches and abs keycaps with orings, to a Poker II with brown MX switches. The poker is so much more comfortable to type on and is far more silent. It really feels like I'm typing on different switches and the only thing which separates the keys is the keycaps. PBT keycaps make such a huge difference with regards to the typing experience.
Having said that, people buy keyboards for very different reasons, so if the aesthetics is of higher importance to you, then by all means use ABS. Just make sure that you try PBT keycaps before making the decision.
Hope you find something you'll be satisfied with.
  • THE Roaming Pear
« Reply #2 on: Sun, 27 April 2014, 14:53:23 »
Well I am planning on buying these blank keys ( http://www.vendio.com/stores/E-sports-Gaming-equipments/item/pbt-key-caps/104-105-pbt-white-blank-key-ca/lid=19240210 ) alongside the keyboard which seem to be PBT, the better feeling type.
But I was thinking that maybe if I get the back lit one and replace the keys I would have a blank keyboard with lighting coming in between the keyboards... But I wasn't sure how that would look since I hadn't really see anyone do that...
Offline Oobly
« Reply #3 on: Sun, 27 April 2014, 15:09:40 »
Depending on the colour, thickness and material of the keycaps and the brightness of the LED's the light may still shine through the keycaps. It will also bleed out around the bases of the caps and provide a nice glow behind the caps :)
Like this:
Or this if they are white and medium or thin:
Buying more keycaps,
it really hacks my wallet,
but I must have them.
  • THE Roaming Pear
« Reply #4 on: Sun, 27 April 2014, 15:17:13 »
That is pretty cool.  Thanks for the picture.  That helps ^_^
Now, I just have to figure out where to find a back-lit version.  I could be wrong, but I don't see any backlit white poker 2 on Qtan's site...
Offline intelli78
« Reply #5 on: Sun, 27 April 2014, 15:28:21 »
http://mechanicalkeyboards.com/search.php?switch_id=ALL&size=ALL&keyword=poker&in_stock=on
MK is usually a good source for backlit Poker IIs. Right now the stock is low, only the models seen in this link.
  • THE Roaming Pear
« Reply #6 on: Sun, 27 April 2014, 15:37:32 »
What is usually more expensive?  Back lit? or PBT keys?
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #7 on: Sun, 27 April 2014, 16:28:19 »
I have a Poker II with the Thick PBT keycaps. I think it's better to get the non back-lit one and mod it yourself.
I've swapped it out tho with some black keycaps.
Here is how it looks under LEDS.
Offline tbc
« Reply #8 on: Sun, 27 April 2014, 19:40:43 »
why would it be better to add the leds yourself?
« Reply #9 on: Sun, 27 April 2014, 19:46:56 »
also, white imsto PBT keycaps let a lot of light through. I really like them over backlit.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #10 on: Sun, 27 April 2014, 20:06:02 »
I mean if he wants the thick pbt keycaps that comes with it.
  • THE Roaming Pear
« Reply #11 on: Sun, 27 April 2014, 23:54:10 »
I was planning on getting the blank keys offered on Qtan's website.  Do you know if those blank keys are the same thickness?
Thank you
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #12 on: Mon, 28 April 2014, 07:34:32 »
Thank you
I can't say. But usually if it's thin white, then sometimes the leds are able to shine a little on the top of the keycap. just a very slight one though.
Offline Razor Lotus
« Reply #13 on: Mon, 28 April 2014, 11:00:35 »
Like this:
Wow this is a really helpful picture! Thanks alot! :)
